Question about GE JKP15 Electric Single Oven
GE JKP15 Electric Single Oven - Code F7
Just bought a house with this oven - overnight oven started beeping every few minutes displaying a code F7 - does anyone know what this means and how do you permanently fix - we just keep hitting clear/off button but in 1-2 minutes happens again ALL DAY!
  • jessicahnkns Aug 19, 2008
    JKP15AOW1AA - not sure where model stops and color begins!! Thanks so much
  • 594 Answers
If possible i will need the letter that come next after the JKP15.
Posted on Aug 19, 2008
  • Cameron Viseth
    Cameron Viseth Aug 19, 2008
    Why is the display showing E"#"-F"#," for example, E1-F2?
    Answer
    Is "PF" displayed on the control?
    A temporary power failure has been detected. Press the Stop/Clear keypad to reset your control. You may need to reset your clock.
    Is the display showing E0-F5?
    The Self-Cleaning latch may be interfering with the oven door causing the Self-Cleaning cycle not to work. If the oven door is open and will not lock, press Stop/Clear to clear the display, press and hold the door switch plunger (located in the upper-right corner of the oven front), and the door latch will unlock. If the oven door is closed and locked, press Stop/Clear to clear the display; apply pressure to the upper-right corner of the oven door, and the door will unlock.
    Is the display showing E"#"-F"#," for example, E1-F2?
    You will need to schedule service.
    Please do not forget to comment and rate about your experience today.
GE Oven Model # JRS04B0W3BB is showing an F7 code, how do I fix it? I can stop the beeping noise by pushing the stop button, but the beeping returns after about 30 minutes. I have pulled the breaker for...
Hi
F1 Error indicates a bad control board and the control board (electronic control) should be replaced to solve this issue. Hope this helps...please post back for further assistance.
Daniel
Aug 06, 2011 | GE 24" Built-In Single Electric Wall Oven
Model JRP15WOW1WW GE Oven beeping and showing code F-7. Help
Hi
F7 Error indicates a bad control board and the control board (electronic control) should be replaced to solve this issue. Hope this helps...please post back for further assistance.
Daniel
Aug 04, 2011 | GE JKP15 Electric Single Oven
GE model #JTP18SDSS electric wall oven displays F-7 and will not work. Tried disconnecting for a few minutes --- still doesn't work.
this is a function pad is jammed or stuck.Recommend that you try to un stick the pad or replace the electronic control
Dec 31, 2010 | GE JKP15 Electric Single Oven
JKP15 Electric Single Oven: Oven keeps beeping with F7 error...
F5 Loss of relay drive circuit If this fault code cannot be cancelled, replace the oven control (also called clock or ERC).
May 07, 2010 | GE JKP15 Electric Single Oven
F7 Code on my GE Profile Oven
F7 A = Function pad button stuck or
B = Bad clock Unstick button or
Replace Electronic Range Control (ERC)
Jun 17, 2009 | GE Profile JTP18 Electric Single Oven
Oven emitted black smoke and F7 beeping on display
F7 stuck keypad
Stuck keypad may mean relay is turned on.
Determine if problem is with the Key Panel or Control by:
1. Pushing CLEAR/OFF pad.
2. Disconnecting Ribbon Cable from control and waiting at least 32 seconds to see if Code recurs
If code recurs, problem is in the control. Replace control.
If code does not recur, problem is with the Key Panel.
Mar 30, 2009 | GE Profile JK915 Electric Single Oven
GE Profile Stove
I used what Charlie recommended ...” post-it” as insulation
And works PERFECTLY….
I have a Kenmore oven Clock…( built in the wall)
Thanks Charlie…you are a Genius!!!!
Jul 15, 2008 | GE JKP15 Electric Single Oven
F7 on the display with constant beeping
F7 for GE is either a stuck button on keypad or bad EOC. Try shutting breaker off 20-30mins and see if it resets itself.
Jul 12, 2008 | GE JKP15 Electric Single Oven
Set, Start and Time Beeps
im going to contack a friend of mine at ge technical about issues on this oven after holidays check back
Dec 31, 2006 | GE JKP15 Electric Single Oven
GE JKP15 Electric Single Oven Logo
497 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
Are you a GE Oven Expert? Answer questions, earn points and help others
