Question about Actiontec GT704WG Wireless Router (gs583ad3-01)
Cant access the Default gateway
Yesterday I just flashed the router firmware, then i tried to go onto the gateway and it wont let me it just gives me a unable to connect page. I used the Command prompt to check the default gateway but it showed up as nothing. So i tried a static IP and all i can access is the Home Page and nothing ELse everything else just gives me a 404 Error Saying Page not found.
Any help would be appreiciated~
  • Anonymous Feb 13, 2009
    me to i tried every thing
    Novelist:
  • 143 Answers
Since you're able to acces the home page but not the rest, it might be that the upgrade was not successful. try to manually reset the device if it has a reset button then power cycle it for like 30 seconds to a minute.
hope this'll help you
ciao!
Posted on Aug 21, 2008
I am unable to access my blitzz bwp611 router. I have tried 192.168.1.254 and 192.168.0.1 to no avail. How can I gain access to this router?
The router should be accessible from the Default Gateway IP Address of your network. Examples I have found are like this:
http://portforward.com/english/routers/port_forwarding/Blitzz/BWA611/Command_and_Conquer_Red_Alert_Counterstrike.htm
you can check you default gateway by opening a command window (Start CMD, right click CMD on the Menu for Vista/7, Start, run cmd for XP) on the command line type IPCONFIG
This will give you your IP address, Subnet Mask and Default Gateway IP address. Type the Default Gateway IP address in to you address line of the browser, you should get a sign in prompt. Unless you changed the default settings, the username and password should be left blank. That should give you access.
Jul 10, 2011 | Blitzz Technology (BWP712) 802.11g/b...
I can't access the configuration page. I've tried everything: disable the firewall, ping the IP 192.168.1.245 with no answer, when i run the command ipconfig, it doen't show the default gateway of te AP....
If it is not showing as the gateway on an ipconfig then the router is not, for some reason, handing out IP. Have you tried resetting the router and if so, are you plugged directly into one of the 4 port LAN's in the back. You may have a bad router or may just need to flash it with some firmware. Is your IP in IPCONFIG a DHCP (192.168), or is it windows internal (169.254) If not 192.168 then you just very well may have an adapter problem. There are so many variables to diagnose on different levels of networking, but it appears that you have enough knowledge to figure this out. Also....try to hard wire a different computer to diagnose an adapter problem with the one you are using.
Jan 25, 2011 | Cisco WAP200 802.11b/g Wireless Access...
I have a CDR-King LP-8186 router. I tried downgrading its firmware from v1.5a to v1.4d because all the firewall feature isnt working anymore. i download the firmware from...
You have to manually assign a compatible IP address on your PC which you used to update the router in order to access it. For example, if the router default is 192.168.1.254, then you have to assign the PC 192.168.1.200 (IP address), 255.255.255.0 (subnet), 192.168.1.254 (gateway) on the PC. You should be able to get in the flash the 2nd and 3rd parts of the firmware. After completing the firmware flash, do a factory reset on the router and you should re-configure it again by hand. Good luck!
Jan 16, 2011 | Encore Computers & Internet
Where do i find the wep key if every ip adress i type wont work?????????????????????????????????????????????? HELP!!!!!!!!!
Logon to the computer with the wireless router connected to the modem. Use the software that came with your router to select the Wireless setup. You will see the Wired Equivalent Privacy (WEP) key that you must use on all computers using the wireless connection. If the software is not installed you could access the firmware from Internet Explorer. If you do not know the router address you can find it by the next steps.
1. Select Run from the Start menu.
2. Type CMD and press Enter.
3. Type IPCONFIG /ALL and press Enter.
4. Note the Default Gateway on a piece of paper.
Open Internet Explorer and type the Default Gateway in the Internet Explorer address bar (example: 192.168.0.1). You may have to type a username and password to access the firmware settings. You should find the password listed in your manual, possibly on the bottom or back of the router. Once you are in the router firmware find the wireless settings so you can see your WEP key and note that value on a piece of paper. Exit internet explorer to save your settings and again try to scan for wireless networks on other computers. Select your router and type in the WEP key and you should be wired.
Apr 06, 2010 | Computers & Internet
Http://192.168.1.1 is not working anymore? i cant set up the router
so you can access the internet by getting connected by LAN cable. so now try to open the router by its default ip and look for the wireless securities setting and reconfigure them properly and if you are not able to access the router than there is reset button which reset the router to company default. and once you have reset the router than you have to configure it again as per your requirement.
Jan 08, 2009 | Linksys WRT54GX2 Wireless-G Broadband...
you can not access the internet - maybe you will not read this..
Definately reset your router - and setup as you did previously.
Omit setting passwords until you have full confidence in the router and your own settings.
Aug 17, 2008 | NetGear WGR614 Wireless Router
Cant access AirPlus DI-524 Wireless
Hello.
The router's software got corrupted which affected some of the feature on your router such as DHCP or the wireless. The only way to do it is to reflash/reload the firmware of the router then make sure you reset it back to its factory default. After that, it should work unless there is a problem already on your device.
Aug 03, 2008 | D-Link AirPlus DI-524 Wireless Router
well, since you said that 192.168.1.1 was working when you first got it, you should try to reset the router (the button is on the back, press and hold it for 5 secs). that would be the easiest way to put your router back together.
Jul 30, 2008 | NetGear WGT624 Wireless Router
Actiontec GT704WG Wireless Router (gs583ad3-01) Logo
145 people viewed this question
Top Actiontec Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you an Actiontec Computer and Internet Expert? Answer questions, earn points and help others
