Question about Canon PIXMA iP3000 InkJet Photo Printer
Canon ip3000 Color problem
How come the printed colors are different than what's in my document?
  • hopew_1999 Aug 19, 2008
    I actually fixed the problem by removing the ink cartridges and wiping the "nozzle" (not sure what it's called) on the printer. Seems to be working fine now. Thanks for the response.
Canon pixma 3000,sn-FCBW87992 purchased AMAZON, NYC 12/04
Printer wont print but ibn green
cleaned heads deep cleaned heads
aligned heads
checked cartridges -ok
still no change, all green
advise at avmill@mindspring.com
Posted on Aug 19, 2008
  • Canon Master
  • 5,568 Answers
This is a frequent complaint and only high-end equipment provides the necessary tools to correct the differences between display and printed output.
If the output is otherwise pristine, you can't do much about it, although if there are clear defects (streaks, etc), you might try running the provided cleaning routine on the printhead.
If you play with the brightness and contrast controls of your monitor, you will see that these can influence the color and saturation of what you see and the printer is not capable of seeing the same thing as you.
  • Steve Allison
    Steve Allison Aug 19, 2008
    You can try removing the printhead itself and cleaning it with a mild cleaner such as window cleaner and cotton swabs.
    Blotting the print surface on paper towel will give you and idea if the cleaning was successful; the head will leave lines of color on the paper.
2 Suggested Answers
  • 258 Answers
SOURCE: IP3000 WILL NOT PRINT BLACK
Try Start --> Control Panel --> Printer and Faxes
Right click on the printer --> slect Properties
Look for maintenance and try "clean" or "Deep Cleaning"
If you cannot find "Maintenance" look for "Tools"
Posted on Jan 13, 2009
Canon Pixma ip3000 will not print in color. We recently replaced all three color cartidges and when I went to do a nozzle check, it only printed the black part of the test page. Several times. I went...
I find this an unusual problem but lets look at the logic.
It worked ok before your replaced the colour cartridges.
Your replaced only the colours and now it does not.
Did you replace the cartridges with like for like?
Are they compatables? Did you run the cleaning cycle?
Run the cleaning cycle at least 3 times.
If still no good buy 3 genuine canon cartridges and see what happens.
If still no joy then must assume the printhead is the problem.
A bit of a coincidence?
Aug 11, 2011 | Canon PIXMA iP3000 InkJet Photo Printer
Uneven color lines
That is because it is printing the document as text. Not have=ing used a canon I presume it is the same as epson & HP. Instead of clicking the print icon click file print. A box should open allowing you to change the properties, seleect photo
Sep 18, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Will not print blue
clean head cardrige and calibrate color cardriges.
Jun 01, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
Printer does not come out of the Manual color setting
When printing tell printer to use color space sRGB.
let printer determine color.
see if that works.
Mar 09, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
Jan 13, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
Poor color printing quality
do you have the canon print management software installed? it's located in the maintenance tab on that software.
www.canon.com has that by model number
Jun 16, 2008 | Canon PIXMA iP3000 InkJet Photo Printer
Printing in color
hi
often the printer 'driver' settings on your printer are set to greyscale only
on the pc open the control panel, printers
right click on the printer and select properties
open the control for the printer and go to the printing preferences (on the general tab)
on the next window (main) look down and ensure the setting is set to colour (not greyscale)
ok out and try printing again
these settings are from my iP5000 and should be similar
try looking in the preferences for similar options
D
Nov 21, 2007 | Canon PIXMA iP3000 InkJet Photo Printer
Canon PIXMA iP3000 InkJet Photo Printer Logo
140 people viewed this question
old marine
old marine
