Question about Westinghouse LCM-19v5 Monitor
LCM-20V5 MONITOR IS BLACK, NO GREEN OR ORANGE LIGHT. COMPLETELY BLACK. CHECKED ALL CABLES. WHEN I RESTART COMPUTER, TAKES A FEW MINUTES FOR THE MONITOR TO COME ON BUT EVENTUALLY IT DOES.NOW WHEN I MANUALLY TURN IT ON ,IT COMES ON INSTANTLY. THANKS, TERESA
  • orlandoman20 May 11, 2010
    When my 20v5 monitors were starting to go like yours after a year. I had to play with the monitor's on off switch or reboot also for it to come up but in the end i needed to change the electroliytics caps inside, Mine did show yellow/green lights though so your problem may be a cap that didnt fail on sillybits or mine but a different one in the group that makes the failure mode different. see my post. "I had two westinghouse 20v5 monitors do this also just over a yr"
worldvet
  • 859 Answers
SOURCE: Monitor SEttings
Probably 1280 x 1024 at 32bit color depth assuming those are the settings you are asking about. If not, please be more specific with a follow up post.
Posted on May 10, 2008
  • 3 Answers
SOURCE: monitor goes black but green light on
i think this is the power supply i have same product and problem. i have completely dissembled the monitor and found taht there are three boards power/ input/ video conversion. there are four wires on the right side that go to the inside of the screen. well if you find where to get a new psu the me know
Posted on Nov 13, 2008
SOURCE: Westinghouse LCM-19V7 powers on, but picture only stays for a sec
It's probably bad capacitors on the power supply board. These monitors are notorious for having the electrolytic capacitors blow out; cheap components! I would suggest replacing the two 1000 mfd capacitors and the three 220 mfd capacitors with 35 volt components from Radio Shack. That fixed one of my LCM-19V7s but not a second one which seems to have some other power supply problem.
Posted on Apr 11, 2009
SOURCE: MY SCREEN ON MY LCM-17v8 MONITOR TURNS COMPLETELY
Found it! Follow this guide:
http://www.midnightmods.com/2008/11/westinghouse-lcm-17v8-repair_07.html
Essentially, you're going to take apart your monitor (you'll have to pop off the covers where the stand mounts onto the screen in order to do so), then you'll find bulging/popped capacitors on the motherboard inside.
You'll remove those capacitors, then replace them with the appropriate ones linked from that guide. They're incredibly cheap, so I went ahead and bought all of them. We'll see if it actually works for me, but it's supposed to, at least...
Posted on Jun 25, 2009
benwabnick
  • 2404 Answers
SOURCE: monitor will appear to come on a
could be a number of possibilities, lcd backlight is going bad, bad capacitors on the power board, lcd cable needs to be reseated, power board needs to be replaced. Best possibility would be to take it to a repair shop and see what the costs would run to fix it.
If its more then the cost of a new monitor then get a new monitor cause you would get the warranty.
Posted on Jun 28, 2009
My Acer AL2216W monitor this morning went blank. I woke up, turned on pc and went to sleep like an hour more, when I woke up, the screen was black and light orange, as usual, when pc is not used for a...
Go to Control Panel, (top right View Small Icons). Then look for Power Options. On this page, you'll have the option to leave the monitor on. You should also check "Advanced Power Options". Don't be afraid of the word, "Advanced." It only means "customizeable"
If your mouse isn't waking your monitor, try the keyboard's space bar. I found it works better than the mouse at waking a sleeping computer
Apr 04, 2017 | Acer AL2216W LCD Monitor
The screen goes on for a second and then turns off. If I then turn the power on and off numerous times it eventually stays on. I put the screen off to 60 minutes. Every time the screen is allowed to turn...
Hello Geoff,
The problem you are having is caused by a power supply board that is failing. Your monitor uses the Delta DAC-12M033 power supply board. We have a repair guide for the Westinghouse LCM-20V5 monitor that uses the same power supply board posted o our web site at: http://www.ccl-la.com/blog/index.php/repairing-the-westinghouse-lcm-20v5/ Check out the web article, it should get you back going again. If you don't want to do the repair yourself we do offer a repair service. We can get deatils on this service here: http://www.ccl-la.com/blog/index.php/service-request-form/
I hope this helps, if so please rate our solution.
CCL Tech
Corporate Computer
www.ccl-la.com
Oct 26, 2010 | ViewSonic VG2021m LCD Monitor
My Viewsonic VG2021m Monitor recently cut out every 5 or so seconds (the display came up and then went off) again and again and now it seems as though i cant turn it on at all even though the blue on light...
The intermittent image, dark picture or no power are all indications of a failing power supply. If you can solder you should be able to repair your monitor. We have an article posted on our web site at: http://www.ccl-la.com/blog/index.php/repairing-the-westinghouse-lcm-20v5/ The post is about repairing the Westinghouse LCM-20V5 but they both use the same power supply board, the Delta DAC-12M033 so the information is the same. If you don't want to do the repair yourself we do offer a repair service for this model for $32 plus return shipping. More information on this service can be found here. http://www.ccl-la.com/blog/index.php/service-request-form/
I hope this information helps, if so please rate our solution.
CCL Tech
Corporate Computer
www.ccl-la.com
Sep 19, 2010 | ViewSonic VG2021m LCD Monitor
Power light flickers green, no image
Check the capacitors in the power supply, see pictures here for a guide so you know what to look for.
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
I believe the 19v5 uses the same chassis as the 20v5.
Post back what you find so we can guide you further.
Apr 05, 2010 | Westinghouse LCM-19v5 Monitor
Screen goes black after fraction of a second
More likely to be bad capacitors in the power supply, see LCM-20V5 (almost the same chassis as used in LCM-19V5) example: http://s807.photobucket.com/home/budm/allalbums
Post back what you see insdie so we can guide you further.
Mar 15, 2010 | Westinghouse LCM-19v5 Monitor
LCM-17v8 Monitor Blacks out after a few minutes. Unplug power source and you have display again, for how long is anyones guess. Any suggestions
Does this happen ONLY when connected to YOUR computer,
or does this happen when conected to some other notebook/desktop?
If the former, your computer is entering "power-save" mode,
after a few minutes of inactivity. Just "wake-up" your computer,
and it will wake-up the LCD monitor.
If it is the latter, then you have a "hardware" problem with your LCD monitor. Take it to a qualified technician for trouble-shooting.
Jan 13, 2010 | Westinghouse LCM-19v1 Monitor
Black screen after a brief windows loggin screen
Hello
It's either the backlight, the inverter or the power supply. My shop would charge $50.00 + parts + shipping. I've repaired alot of Westinghouse monitors and I haven't junked one yet.
Jul 28, 2009 | Westinghouse L2046NV Monitor
Westinghouse Monitor Repair
you can look for other caps that are bad on the board that may have failed later.
hear is a list of replacements for all the caps on the 20v5 i have
http://www.fixya.com/support/t2576306-two_westinghouse_20v5_monitors_also_just
Apr 01, 2009 | Westinghouse LCM-19v5 Monitor
Blue Screen
chak the signal cable of u r monitor
Nov 30, 2008 | Westinghouse Computers & Internet
Westinghouse LCM-19v5 Monitor Logo
400 people viewed this question
Top Westinghouse Computers & Internet Experts
Jim Goldsmith
Jim Goldsmith
Alun Cox
Are you a Westinghouse Computer and Internet Expert? Answer questions, earn points and help others
