Question about Dirt Devil Reaction Twin Cyclone Upright Vacuum
Dirt Devil Reaction Vacuum belt replacement
I'm having trouble changing the belt. I've tried twice and the belt breaks, and there is a "burning" smell. I'm following the manual instructions, and my vacuum is only 6 months old. Any suggestions?
  • 2 more comments
  • jayparr Sep 10, 2008
    There is a burning smell and the belt wears quickly by the motor hook up
  • Brian Schoendorf Sep 25, 2008
    Used the vacuum for about a year with no problems except overheating sometimes. Now I can't get a belt to last more than a couple of uses. I replaced the sweeper roller and ordered belts directly from Dirt Devil. No luck. There seems to be too much play. Question? Should there be a gear or roller on the metal piece that comes out of the motor that drives the belt? Just putting the belt over the metal seems to give it too much room to move left or right.
  • jstaut Jan 09, 2009
    I have the same problem - it seems to be related to the switch used for vacuming bare floors.
  • Anonymous Mar 30, 2014
    not picking up
The manual is confusing - I had the same problem. Make sure you put the belt around the smaller motor axle, not the lever arm attached to the on/off foot switch. It's a bit counter-intuitive, but that was my problem with this. Jeff
Posted on Jan 15, 2009
Dirt Devil easy lite vacuum makes pop or a thunk and then the suction is bad the clog lite does not come on I know it works
Hi there! Sounds like that noise may have been your belt popping or breaking. Try checking the belt on the vacuum. If it has broken, replace with a Dirt Devil style 15 belt. Below is a link where you may go to purchase the belt if needed. Thanks!
Style 15 Belt 2 Pack
Apr 28, 2014 | Dirt Devil Easy Lite Quick Vacuum
My Dirt Devil Reaction will work with the hose attachment but will not pick up from the floor. What could be wrong?
With all upright vacuums the problem could be one of two things on it in this situation.
1) the belt may be broken or slipping and is needing to be changed.
2) the lower area below the hose attchment and the rotating brush may be blocked up.
It is also possible that both could be giving you a problem too, however if it is blocked up down below then you will most likely see some dirt and debris spitting back out as you vacuum.
Nov 04, 2010 | Dirt Devil Reaction Twin Cyclone Upright...
Brush doesn't move at all
You need to replace the belt. You can get replacement belts here:
Replacement Vacuum Belts
Jan 10, 2010 | Dirt Devil Reaction Twin Cyclone Upright...
No clogs, work fine, but makes a very loud wailing sound? what could it be?
My Dirt devil Reaction does the same thing. So I took apart the motor and it was crammed w/ dirt then I decided to clean it out. next time I vacuumed my house it was a lot quieter. The guy from Jones sew and vac said baggless vacuum filters most of the time fail and let dirt get in the motor and start to scream. I read a lot of things saying Dirt devil Reaction is the most common vacuum to get dirt in the motor and start to wail then get worse & worse and get to the point where they start to almost scream. P.S if you let it scream for along time of use it will give the motor permanent damage and you will smell electrical burning, if that happens it will be too late so you will half to buy a new machine. To get to the motor you can take the dust contaner off and take the black filter then use your down stairs vacuum and get a small attachament and stick it in and vacuum it out,if not have two vacuums borrow one. If that doesn't clean it out you will need to take all the plastic appart and realy get to the motor good. If my advice dosn't help it is ok to still use it, it will just be loud until the motor of it is totally fried. This should work it worked on my Dirt devil Reaction. I'm sorry if it doesn't work out. :D
Apr 17, 2009 | Dirt Devil Reaction Twin Cyclone Upright...
Dirt Devil vacuum M85845 broken belts. Can't get
call all-type vacuum &janitorial supply.lisa can help you.314-275-8006
Apr 08, 2009 | Dirt Devil M085850 Featherlite Bagless...
Dirt Devil M084600 Dynamite
Your roller won't turn. The belt is designed to break if anything threatens to keep the motor from turning. When you have the roller out, check the end caps to see if they rotate easily. If they do, then install a new belt being very careful that the belt is not pinched on the channel that it sits in. Once you have the belt installed, turn the roller by hand to make sure that there is no jamming or catching of anything. Install the plate and check the rotation again. Once you are satisfied that the roller turns easily, try the machine.
If the caps on the roller are jammed, as they will get from debris, hair and thread, etc., then you may have to replace the roller. The end caps on most of the Dirt Devils are carbon fibre and will break when you try to remove them.
Jan 30, 2008 | Dirt Devil M084600 Dynamite Bagless...
Brush on/off lever
Replacing a belt or how to get into the vacuum cleaner . It is a Dirt devil Reaction D2
Oct 09, 2007 | Dirt Devil M1100009 Reaction Soft Touch...
Dirt Devil Reaction Twin Cyclone Upright Vacuum Logo
1,603 people viewed this question
Top Dirt Devil Vacuums Experts
Nick Olsen
JoeVacs
Are you a Dirt Devil Vacuum Expert? Answer questions, earn points and help others
