Question about Hampton Bay 04379 Madison Avenue Ceiling Fan
Fan cuts off for no reason
I installed a Hampton Bay ceiling fan with remote control about 10 months ago in the master bedroom. We keep the fan on high every nite, and the fan cuts off unexpectedly 1-2 times a nite. Lately it has been happening even more frequently. It turns back on OK, but it's very annoying. What could be the reason for this? Thanks!
  • 25 Answers
It could be the capaciter, found in the light fixture area.
Posted on Aug 20, 2008
Ceiling fans on same frequency
There should be dip switches in/on both the remote control and the ceiling fan that enable you to change the control frequency. The only thing that you have to ensure is that the two components are set to a matching frequency.
The switches in the remote are located in the battery compartment just above the batteries. Remove the dome on the ceiling fan and you should find the switches for that unit. Just compare the two and match whatever changes you make from one unit to the other.
Originally answered by d0n0r in this question
May 25, 2009 | Universal Remote Control Hampton Bay...
My home is pre wired for a ceiling fan in the master bedroom. There are two light switches that control the pre installed wires. One for the light on the fan and one for the fan. There are four wires
The usual wiruing for these fan/light circuits is that the black wire on one switch is for the fan and the red on the other switch is for the light. If you are using a remote set up for both fan and light, then hook the remote wires to the black and white wires in the ceiling, You can cap off the red wire in the ceiling as this will not be used.
Apr 24, 2009 | Hampton Bay 24002 Ceiling Fan
Hampton Bay remote for ceiling fan caused an electrical fire
We just installed this fan and within 1 day the electrical wires in the receiver burned and would have caught fire had it not been caught!!!
Jan 07, 2009 | Universal Remote Control Hampton Bay...
Need remotes
In theory, they should. Try Hampton Bay first, and if not, check for aftermarket replacements. Those remotes are simple enough that there is no reason that they can't.
Dec 18, 2008 | Hampton Bay 24750 Huntington III Ceiling...
Bulbs burning out in Hampton Bay ceiling fan
I would suggest getting an electrician to check the current running through the wiring. I had installed a similar fan in my grandmother's house a couple of years ago and had the same problem. After a couple of months of constantly changing bulbs, I brought in an electrician to check the current and found that there was a short in the wire which kept causing just enough of a current surge to blow the bulbs.
Nov 29, 2008 | Hampton Bay 04345 Cruiser Ceiling Fan
Hampton Bay Remote
You must use the switch on the fan itself.
Aug 01, 2008 | Hampton Bay 52 In. White Redington...
Remote control
in the remote and the fan the little blue box is called a dip switch
you will have to open fans base to access the remote power sender
on both the fan and remote the dip switches have to match in order for the remote to work the fan properly
or your signal will never make it to remote box
Jun 05, 2008 | Hampton Bay 24002 Ceiling Fan
Bought a monte carlo ceiling fan. removed old fan and found 3 white and 3 black wires, plus grounds. Cannot figure out how to connect the unit up. breaker controls all ceiling lights in master bath,2nd...
Try this:
* All 3 black together, with black and blue from fan
* All 3 white together, with white from fan
* All grounds (earths) together, with all greens from fan
Apr 28, 2008 | Hampton Bay 24002 Ceiling Fan
Hampton Bay 04379 Madison Avenue Ceiling Fan Logo
151 people viewed this question
Top Hampton Bay Dryers Experts
Steve
Craig Butler
Craig Butler
Are you a Hampton Bay Dryer Expert? Answer questions, earn points and help others
