Camera assistant software
I can't find camera assistant software,I have a 1.3 mp built-in camera.
  • Technova Aug 20, 2008
    i can see usb camera in my computer along with the partitions. But i dont have the correct software to operate it.
  • 186 Answers
If you wish, you can try Cyberlink Youcam which is available for latest HP Notebooks installed with Vista :
ftp://ftp.hp.com/pub/softpaq/sp39001-39500/sp39372.exe
Even though this application is meant for Vista, try installing if you are having XP in your machine.
Additionally, you can find the steps about how to use the Cyberlink Youcam to test the webcam from the link below :
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01414839&cc=us&dlc=en&lc=en&jumpid=reg_R1002_USEN
Also, if the application is not being installed in XP, you can try using the Webcam Preview application which is available from the link below :
ftp://ftp.hp.com/pub/softpaq/sp35001-35500/sp35414.exe
Better way is to save the file in the Notebook and double click on it to start installation.
You can also try the applications which are available from the links below :
http://www.yawcam.com/
http://www.manycam.com/
Hope this helps...
Posted on Aug 21, 2008
My nikon d100 picture is not 6mp it is only 1.5 & 2 mp
Nikon no longer has the D100 manual on line; but if it is like the more modern Nikons, you will be able to select the resolution in mp from one of your camera's built in menus.
Oct 25, 2015 | Nikon D100 Digital Camera
Image size too small - even when set on 5 MP
Hi, Although I prefer you getting it repaired, but there is a slight chance to get it working. 1) First you have to go through every single option in the Camera and change it. 2) Try using the Built-in memory instead of the external if you got any. 3) There is an option for the Picture quality, as "Standard, Fine, SuperFine". Try changing it. 4) Try using it on anothe PC just to be sure. If none helped, then a hardware component must be replaced, because there is not firmware update/upgrade. Good Luck
Jun 16, 2007 | Sony Cyber-shot DSC-W50 Digital Camera
How do you reduce the MP from the 14.1 that comes with the camera to a much lower MP....say 3 to 5 MP????
It depends on the make of camera, but there is usually a menu built into the camera's software, accessed vie the buttons on the back where you can scroll down or across to the picture quality setting. You can then set the camera to a lower MP setting and get far more pics onto the memory card. It is difficult to be more specific, not knowing the make and model of camera.
Apr 14, 2011 | Cameras
How do i take a picture on my Toshiba laptop
1. Open a program called"Camera Assistant." This is a Toshiba-supported computr program designed specifically for people with cameras built into their laptops.You can find this by clicking on the "Start" menu and then navigatingto the "Programs" sub-menu. 2. Press the"Picture" button in the "Camera Assistant" program windowto take a picture using your built-in camera. This will take one stillphotograph for every time you click the button. The image you are taking willappear on the right side of the main program window. 3. Press the"Video" button in the "Camera Asst" program window tobegin recording video using your built-in camera. This will record video untilyou press the "Stop" button. The video you are recording will appearon the right side of the main program window. 4. If you can't open"Camera Assistant," reinstall your drivers. Though the camera on aToshiba laptop is designed to work right out of the box, if it doesn't you mayneed to reinstall the driver that makes it work. Look for the CD labeled"Drivers and Software" that came packaged into the box with yourToshiba laptop. Pop it in your laptop's CD-ROM or DVD-ROM drive and install the"Digital Camera" driver contained on the disc.
Nov 11, 2010 | Toshiba Satellite A105 Notebook
I cant figure out how to access my built in webcam so i can take pictures
Please follow the steps below:
Camera Assistant Software:
a. On the taskbar double-click the Camera Assistant Software icon , or from the Windows® Start menu, point to All Programs, Camera Assistant Software, and then click Camera Assistant Software. The Camera Assistant Toolbar location briefly displays on the desktop.
b. On the Camera Assistant Toolbar, click the Start Camera button and click on the icons on the software.
NOTE: If you are not hearing the audio portion of the video you created, try the following: Verify that you do not have the audio capture muted. An X appears on the Mute button when Mute is selected.
Click the Functions button, and then click the Audio tab. In the Audio Output section, verify that the Digital Mic is selected from the Audio Device drop down list, and then click Apply. In the Audio Volume section, use the slider bar to increase the volume level. Verify that the notebook's volume is not muted. Pressing the Fn+End keys mutes the volume. Pressing the keys a second time restores the volume. Increase the notebook volume level by pressing the Fn+PgUp keys.
Thanks and regrds,
Anil.B.R
Aug 29, 2010 | Acer Extensa 4620 Notebook
The internal memory is full; how do I correct this?
Delete pictures until it is empty. Use a higher capacity memory card and switch to it in the menus.
How many pictures can be stored on the internal memory of the KODAK EASYSHARE-ONE Zoom Digital Camera? Question : How many pictures can be stored on the internal memory of the KODAK EASYSHARE-ONE Zoom Digital Camera? Answer : The camera has 256 MB internal memory (185 MB available for image storage)*. The number of pictures that can be stored depends on the Picture Size (picture quality) setting selected on the camera as well as the level of detail of the subject. The following information can be used to approximate the average number of pictures that can be taken at each setting: 4.0 MP: 150 pictures 3.5 MP (3:2) : 167 pictures 2.1 MP: 270 pictures 1.1 MP: 451 pictures NOTE: Internal memory can store up to 1500 images, tagged as Favorites, optimized for viewing on the camera. Favorites as such are added to the camera through synchronization with EASYSHARE Software on your computer. See the camera user's guide, or click the Help button in EASYSHARE Software for more information.
*1 MB equals one million bytes, 1GB equals one billion bytes
Aug 03, 2010 | Kodak EasyShare One Digital Camera
Hi i downloaded ares and it doesnt let me download music it sais i need a registration code how can i get it with out paying?
1. On the taskbar double-click the Camera Assistant Software icon , or from the Windows® Start menu, point to All Programs, Camera Assistant Software, and then click Camera Assistant Software. The Camera Assistant Toolbar location briefly displays on the desktop.
1. On the Camera Assistant Toolbar, click the Start Camera button .
2. In the Camera Assistant, click any one of the options.
Mar 14, 2010 | Acer Aspire One PC Notebook
How do i use the webcam on my emachine model e725?
If you are using EME725-4520, then this do not have web cam. or else follow the instructions below:
2. On the Camera Assistant Toolbar, click the Start Camera button .
3. In the Camera Assistant, click any one of the options.
Mar 12, 2010 | E-Machines M2350 Notebook
Computers & Internet Logo
182 people viewed this question
David Payne
David Payne
