My Symbol never get full signal why ? (Always display 50% signal or less)
When using the same CF Symbol wireless card, it show 100% full signal.
Anyone know what wrong ??
*P.S. Same OS & driver installed.
Rating: 0%, 0 votes
For my Buffalo card, it is type II also.
The different between type I and type II is Type I CF cards are 3.3 mm
thick, compared to 5.5 mm for Type II cards. as the different on the
power, I think they maybe the same.
Was this solution helpful? Show your Appreciation by rating it:
Rating: 0%, 0 votes
http://www.symbol.com/services /downloads/documentation_drive rs.html
Your CF card should be a wireless networker, and a type 1 card, look at the
picture on this page:
http://www.symbol.com/products /wireless/wirelessflash.html
Is that it? That is what it would be here, at least.
David Hettel
Microsoft MVP Mobile Devices
This posting is provided "as is" with no warranties, and confers no rights.
You assume all risks for your use.
Rating: 0%, 0 votes
My CF wireless is Type II, how about ur Buffalo ?
Is Type II device consume more power than Type I ?
Rating: 0%, 0 votes
couple of issues, including better support for some peripherals. The
update was available free of charge from Casio Germany and I assume
other countries as well.
After the update, you should see the version number "1206" in the
bottom right corner of the second tab in the Settings/Backlight
applet.
Marc Zimmermann
Microsoft MVP - Mobile Devices
Pocket PC User Groups http://www.clubpocketpc.de
Personal Homepage http://www.zimac.de
Rating: 0%, 0 votes
Although I got 50% signal, I still able to get good through-put, so I think
it is driver problem.
Also I've check their web site but I can't find the newer version.
My CF wireless model is "Spectrum24"
"David Hettel MS MVP - Mobile Devices" <dhet @fuse.net> wrote in message
Rating: 0%, 0 votes
need a full signal. Then I would contact Symbol, if your getting noticeable
less through put. My guess is no, there is no solution if the E200 can't
handle the power requirements of the symbol card. If it is electrical noisy,
Symbol may have a newer version, of there card. They should be able to tell
you if this is a common problem or not. If it is not common, then you may
want to contact Casio and see what they say.
David Hettel
Rating: 0%, 0 votes
Rating: 0%, 0 votes
appeared. suggest you contact both casio and Symbol. it may be a problem
on the driver which has some problem running on E200.
Rating: 0%, 0 votes
power your Symbol needs. Or your E200 maybe electrically noisy
David Hettel
Post a New problem for Casio E200 Pocket PC
Email this problem
