Question about GPS
My screen has frozen, have only had it since May, cannot find a re-set button, and the set will not turn off.
  • 2 more comments
  • sjanebear2 Aug 19, 2008
    garmin nuvi 250
    Fantastic thanks, dont think I ever would have found the reset button! Seems to be working fine now.
    Thanks alot!!
  • Anonymous Nov 06, 2008
    made a mistake and unplug computer now send error report keep poping up and cannot click on start button
  • shenae_austi Nov 06, 2008
    made a mistake unplug computer while defragmenting now send error report keep popping up and csnt go to start button
Which model is it?
Posted on Aug 19, 2008
  • Anonymous Aug 19, 2008
    The reset button is located on the bottom bezel of the unit. Here is a link to a picture for reference. Click HERE. In this picture it is to the right of the bar code on the bottom right side of the unit. Let me know if resetting helped.
    Take Care,
    -WN
    Your welcome glad I could help!
System is frozen. Wont shut down or go to start screen.
Here are two things to try:
I- Using the Power button:
1 Press and hold the Power button for at least 4 seconds.
2 Swipe-down the shutdown confirmation screen to the bottom
edge of the display to turn off the tablet.
Using Charms:
1 Swipe-in from the right edge of the display to access Charms.
2 Touch Settings
Turning Off the Screen
Press the Power button to turn off the screen.
Using Charms:
2 Touch Settings
NOTE: If your tablet is in a standby state (tablet is on, but screen is off), press the Power button or Windows button once to turn on the screen.
12
Setting Up Your Tablet
? Power
? Shut down to turn off the tablet.
II- Unplug the battery, wait 30 seconds, then install the battery again.
Sep 04, 2015 | Dell Venue 8 Pro Tablet Computer
How to get back to settings on frozen samsung tablet
Tablet should have a "reset" button on top or side. Small hole. You need an object that would fit--it will take it back to factory specs. Make sure tablet is fully charged--or plugged in first. Worked for me.
Sep 06, 2014 | Samsung Tablets & eReaders
Frozen setting button
press and hold power button and menu button for about 10 secs, and when the screen turnes off, release both
Apr 09, 2014 | Apple iPhone 5c
Frozen display
hi on the remote control press the i button this should remove the caption, go into the menu on the tv select display setting check the time out hope it helps
regards
shaun
Apr 02, 2014 | Samsung Televison & Video
How do I reset LG P500
Factory Reset on Menu Setting
1. From the main home screen, tap menu
2. Select Settings, then Privacy
3. Select Factory data reset
4. Select Reset phone
5. Enter the password if required, then confirm by selecting Erase everything
Hope this helps,
If the phone is frozen, hard reset it through buttons
1. Turn the power off. If the phone is frozen, pull the battery out and inplace it back again
2. Hold the Home and Volume Down button
3. Press and hold the Power button until the phone turns on
4. Follow the on-screen instructions to hard reset the phone handset
The LG Optimus One P500 will then reboot to its factory fresh default state settings.
Sep 19, 2011 | LG P500 Cell Phone
I want to reset a HTC HD7 but i dont know how. can you help me?
1. From the Start screen, tap wp7arrow.png in the upper-right corner.
2. Tap Settings.
wp7settings.png3. Scroll down and select About.
wp7about.png4.Tap the Reset your phone button.
windows-phone-7-reset-button.png5. Confirm your selection by selecting Yes. Then tap Yes again.
Your HTC HD7 will then go through the process of resetting to factory default settings.
Option 2 - Resetting using the hardware buttons
You can also use the buttons to perform a hard reset. This comes in handy if the screen is frozen and you can't access the phone.
1. Turn the phone off. If it's frozen or unresponsive, pull then replace the battery.
2. Press and hold the Volume Up and Volume Down buttons and power the phone back on.
3. Continue to hold Volume Up and Volume Down until a factory reset screen appears.
Mar 08, 2011 | HTC Cell Phones
PS3 screen frozen.
when the system is powered on hold the power button down until you hear it beep twice, I am unsure if this is what you were talking about or not but it should reset the system to factory settings
Sep 29, 2009 | Sony Playstation 3 (PS3) Console
Cant enter pin or screen is frozen
Look near the SN # and press the reset button.
or
with the garmin off, hold down the right bottom of the screen and turn the garmin on, it will then ask you if you want to perform a hard reset. Choose yes and that should fix your problem.
Nov 11, 2008 | Garmin Nuvi 660 GPS Receiver
Touch screen frozen
the best solution to fix this problem is to get it repaired or replace if it is still under warranty.
I'll let you know if there is any other solution to fix this.
Apr 12, 2008 | Sony Cyber-shot DSC-N2 Digital Camera
Frozenj
The reset button is the tiny hole on the top of the player to the left of the volume wheel. Use a paper clip to stick in the hole and push in the reset button for a second. Your screen should turn black and then turn off. Hopefully that will work!
Jul 08, 2006 | Rio CE2100 MP3 Player
GPS Logo
243 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
