When I inserted a disc on my home Sony DVD player my screen said" Playback prohibited due to area restrictions". It does play, however, on my office computer DVD player. Thanks, Natalie
  • natmae Aug 19, 2008
    Thank you very much. This is extremely helpful and totally explained the problem.
DVDs are encoded to a particular region and will only play on dvd players that are encoded to accept that region. Usually a computer dvd reader is region free meaning that it can play DVDs from any region without a problem. For example the USA is region 1 and Austrailia is region 5. A disc made for Australia (region 5) will not play in a standard USA player (region 1). see this link on Wikipedia for more information HERE . The good news is that sometimes you can set up your DVD player to accept discs from any region. If you are interested let me know the exact model of your DVD player and I will look it up. Please rate me well if this has helped.
Posted on Aug 19, 2008
Why ask me my DVD Playback prohibited by area limitations ??? Pls help me now I wane watch movie thanks
Most DVD players are region-locked, meaning they will only play disks encoded in the location they are from, or disks without region-specific encoding. For example, if I bought a DVD player in Europe and tried to play a disc from the United States, it would not play. Unfortunately, in order to get past the "area limitations" you will either have to buy a DVD encoded in the same format as your DVD player, or set the player to a different region code (which often will lock the player after a certain number of times).
Feb 27, 2013 | Televison & Video
Tip
Sony DAV-C700, DAV-S400, DAV-S500, DAV-S800, CMT-S9D region free unlock code
Introduction
The DVD Upgrade is an advanced modification to your DVD player, which adds extra features and enables you to get more from your machine. The upgrade supplements the DVD player and in no way harms the playback quality or removes any performance features of the machine.
Players Supported
The following DVD players are supported by this version of the DVD Upgrade:
 Sony DAV-C700
 Sony DAV-S400
 Sony DAV-S500
 Sony DAV-S800
 Sony CMT-S9D
Macrovision & CGMS disable
All DVD players have a system called Macrovision built in to the player, which is designed to stop the copying of DVD discs to video. However, this system can have adverse affects on some projectors. For this reason the DVD MOD Upgrade disables Macrovision to solve any problems.
User manual
Put your player into „Standby“ Mode and enter one of the following commands if necessary:
Remote control command Function
[0] [ENTER] Default Default region code on the player
[1] [ENTER] Region 1
[2] [ENTER] Region 2
[3] [ENTER] Region 3
[4] [ENTER] Region 4
[5] [ENTER] Region 5
[6] [ENTER] Region 6
[7] [ENTER] Region 7
[8] [ENTER] Region 8
[Arrow down] [ENTER] Only play DVDs with the selected region; auto switching OFF
[Arrow up] [ENTER] Default Auto switching ON
[PREV I<<] [ENTER] Enable video interference impulses (Macrovision ON)
[NEXT >>I] [ENTER] Default Disable video interference impulses (Macrovision OFF)
[Arrow left] [ENTER] Enable user operation prohibitions* and access restrictions
[Arrow right] [ENTER] Default Disable user operation prohibitions* and access restrictions
* The DVD can no longer prohibit you from using the fast-forward, chapter change or Audio-/Subtitle-/Angle switch. You can no longer be forced to watch intros. Just press [TITLE] or [DVD MENU] and select PLAY.
on Mar 02, 2010 | Electronics - Others
Is there a way to change the region code on a Sony HCD-S300 Please?
Unfortunately, you have a DVD player that is "Region Specific" and cannot be changed. Your system has a region code printed on the back of the unit and will only play DVDs that are labeled with identical region codes. DVDs labeled "ALL" will also play in this unit. If you try to play any other DVD, the message " Playing this disc is prohibited by area limits." will appear on the TV screen. Depending on the DVD, no region code indication may be labeled even though playing is prohibited by area limits.
Mar 26, 2012 | Televison & Video
Playback prohibited by area limitations - what does this mean?
you are trying to use a dvd from a different region then the player is set up for the player has to be unlocked to play multiple regional discs
Jul 17, 2011 | Sony DVP-SR200P DVD Player
I have a Sony DVP-SR200P dvd player..but I am not able to play in India...giving error "playback restricted due to Area limitations"...can any one please help
Hi:
Check the region code in your menu, region codes are for different country codes embedded in the system hardware for playing different countries DVD's.
Jul 02, 2010 | Televison & Video
My dvd player says playback prohibited by area limitations
Sounds like it's the wrong region disc. Try a disc that worked before and if it does than there is nothing wrong with your dvd player it is the disc you are trying to play that has the issue.
May 07, 2010 | Sony DVP-SR200P DVD Player
Pinnacle DVD's won't play in DVD players
The region code of your stand alone player is different from the region code on the disk. To resolve this Pinnacle should have an info tool that will allow you to check the region code. If not Nero has this tool available with thier software. You should be able to download it @www.download.com. Also most newer DVD players only read specific data types. For instance, you cant use DVD-RW in a player that only reads DVD-R. So make sure you are using disks that are compatible with your DVD player.
Mar 15, 2010 | Pinnacle Studio Ultimate 12 for PC
Dvd won't play
Try running a laser disc cleaner through the player. You could have dust on on your last lens. If that doesn't do it, go to your owners manual and make certain that your ratings are not set to high.
Oct 10, 2009 | Sony SLV-D350P DVD Player/VCR
'PLAYBACK PROHIBITED DUE TO AREA LIMITATIONS'
Check area code at your unit and usualy its printed at back side. If your unit belongs to code 1, it will play only region code 1 dvds and so on other codes.
Jul 23, 2008 | Sony DAV-IS10 System
Televison & Video Logo
237 people viewed this question
Top Televison & Video Experts
Electro Med Services...
