Print heads 6c does not print and head 6pc is streaked. Head deep cleaning does not correct the problem
  • 594 Answers
You will need to get new printer heads and or cartigdes. the 6c has something blocking the head probably dry ink. and the streak from 6pc is porbably because iit is low on ink.
Posted on Aug 19, 2008
My canon pixma 480 has thin horizontal lines. tried cleaning and deep cleaning where is the head alignment tool?
The instructions as copied from the Pixma 480 "onscreen manual." (Only the text -- not the images -- could be pasted into the solution. Hope you can follow the text.) Steve G.
Prepare 2 sheets of A4 or Letter-sized plain paper
1. Make sure that the power is turned on, and load 2 sheets of A4 or Letter-sized plain paper in the Rear Tray.
2. Open the Paper Output Tray gently, and open the Output Tray Extension.
3. Print the print head alignment pattern.
- Press the Menu button.
- Select Maintenance, and press the OK button.
- Select Print head alignment, and press the OK button.
Note: To print the current head position adjustment values, select Head alignment print in the Maintenance menu and press the OK button. See Selecting Menus on the Top Menu Screen.)
- Select Yes, and press the OK button to print alignment sheet.
- Check the pattern is printed correctly, select Yes and press OK button.
- Confirm the displayed message and press the OK button.
The Print head alignment screen appears.
4. Adjust the print head position.
- Check the printed patterns, and use the (Left) or (Right) button to select the number of the pattern that has the least noticeable streaks for column A.
Note: If it is difficult to select the best pattern, select the pattern that has the least noticeable white streaks.
(A) Less noticeable vertical white streaks
(B) Noticeable vertical white streaks
(C) Less noticeable horizontal white streaks
(D) Noticeable horizontal white streaks
- Repeat the same procedure to input the pattern number for each column from B to L, then press the OK button.
- Select Yes to continue printing, and press the OK button.
- The second page of print head alignment sheet will be printed.
- Confirm the message for print head alignment, and press the OK button.
- Check the printed patterns and use the (Left) or (Right) button to input the number of the pattern that has the least noticeable horizontal streaks for column M.
- Repeat the same procedure to input the pattern number for each column from N to R, and press the OK button.
Jan 12, 2011 | Canon Pixma MP480 All-In-One InkJet...
I have a Canon Pixma MP270 and I can only print in colour both the black and colour lights are lit up on the printer
f print quality does not improve by the standard cleaning of the Print Head, clean the Print Head deeply. Cleaning the Print Head deeply consumes more ink than the standard cleaning of the Print Head, so clean the Print Head deeply only when necessary.
1. Make sure that the power is turned on.
2. Clean the Print Head deeply. (1) Press the g0022565.png (Maintenance) button repeatedly until y appears. g0054776.png
(2) Press the Black or Color button.
The machine starts cleaning the Print Head deeply. Do not perform any other operations until the machine completes the deep cleaning of the Print Head. This takes about 2 minutes.
3. Check the print head condition.
When the deep cleaning is completed, the LED returns to the copy standby mode. To check the print head condition, print the nozzle check pattern.
See " Printing the Nozzle Check Pattern".
If the problem is not resolved, turn off the power and clean the Print Head deeply again after 24 hours.
If the problem is still not resolved, replace the FINE Cartridge with a new one.
See " Replacing FINE Cartridges".
If the problem is still not resolved after replacing the FINE Cartridge, contact the service center.
Print the nozzle check pattern to determine whether the ink ejects properly from the print head nozzles.
NOTE If the remaining ink level is low, the nozzle check pattern will not be printed correctly. Replace the FINE Cartridge whose ink is low.
You need to prepare: a sheet of A4 or Letter-sized plain paper
2. Load a sheet of A4 or Letter-sized plain paper in the Rear Tray.
3. Open the Paper Output Tray gently, and open the Output Tray Extension.
4. Print the nozzle check pattern.
(1) Press the g0020617.png (Maintenance) button repeatedly until A appears. g0054754.png
The nozzle check pattern will be printed.
5. Examine the nozzle check pattern.
See Examining the Nozzle Check Pattern.
Examine the nozzle check pattern, and clean the Print Head if necessary.
1. Check if there are missing lines in the pattern (1) or horizontal white streaks in the pattern (2). g0054755.png (1) Check if lines are missing in this pattern. If yes, the cleaning is required.
See " Cleaning the Print Head".
(A) Good
(B) Bad (lines are missing)
(2) Check if horizontal white streaks are present in this pattern. If yes, the cleaning is required.
(A) Good
(B) Bad (horizontal white streaks are present)
Post back!
Oct 26, 2010 | Canon Office Equipment & Supplies
Hi, (MX850) My blue ink has stopped printing. I
Performing Maintenance:
Note :
Be sure to install the ink tanks in the correct order indicated by the label on the Print Head Holder. The machine will not print if an ink tank is installed in the incorrect position.
Step 1
Printing the Nozzle Check Pattern.
If lines are missing or if white streaks appear
Step 2
Print Head Cleaning.
If the problem is not resolved after performing Print Head Cleaning twice
After cleaning the Print Head, print and examine the nozzle check pattern (Step 1) again.
Step 3
Print Head Deep Cleaning.
If Print Head Deep Cleaning does not resolve the problem, turn off the machine and perform another Print Head Deep Cleaning after 24 hours. If the problem is still not resolved and if you are sure that the ink didn't run out, then the Print Head may be damaged. Contact your Canon service representative.
Hope this helps.
All the best.
Mar 11, 2010 | Canon PIXMA MX850 Multifunction Printer
Canon Pixma IP4000 cyan ink will not flow even though I have repeatedly cleaned and deep cleaned and replaced ink tank.
If you have gone through the process of cleaning and deep cleaning, as described by canon, and you still get no ink flow after printing 2-3 pages, the print head needs to be replaced.
Here is WHO to contact and HOW to install the print head:
WHO: Purchasing a Print Head
You may purchase a print head* for this printer by calling 1-800-828-4040 Monday-Sunday 8:00 a.m. - 12:00 midnight. EST, excluding holidays. When calling, speak the term "order parts" when the speech routing system asks the reason for your call. You will immediately be routed to the Parts Desk for assistance. Be sure to have your model number (iP4000R) or part number (QY6-0049-000) ready for the sales person.
HOW: Install the print head and ink tanks correctly iP4000/iP4000R/iP5000
Seat the print head Below is the procedure for seating the print head and ink tanks:
  1. Power on the printer.
  2. Open the paper output tray and top cover.
    Note: Gently open the paper output tray while holding it.
  3. After confirming that the print head holder has moved to the center, open the inner cover.
  4. Remove the orange tape securing the print head lock lever, and raise the print head lock lever.
    Note: If the top cover is left open for more than 10 minutes, the print head holder will move to the right. If this occurs, close the top cover once and then re-open it.
  5. Remove the print head from its package and remove the orange protective cap.
    <1> Electrical Contacts and Print Head Face's Nozzle Area
    <2> Ink Supply Filters
    Note: To avoid any damage, do not touch the print head face's nozzle area, electrical contacts, and ink supply filters. After removing the protective cap, set the print head into the print head holder immediately. Do not re-attach the protective cap after it has been removed.
  6. Set the print head into the print head holder, and lower the print head lock lever until a click sound is made.
    Next, install the ink tanks.
  7. Remove the cyan ink tank (BCI-6C) from its package. Pull the orange tape in the direction of the arrow to remove the wrap film completely.
    Note: Remove the orange tape completely. If the orange tape is not completely removed, it may interfere with printing.
    <1> Removed correctly
    <2> Removed incorrectly
  8. Hold the ink tank as shown in the image below. Twist the orange protective cap in the direction of the arrow, and remove it.
    Note: Remove the protective cap while holding it, so that fingers will not be stained by the ink.
  9. Insert the ink tank into the slot at the right end, and push down on the PUSH mark on top of the ink tank until a click sound is made. Install the other ink tanks in the same manner.
  10. Close the inner cover and top cover.
    Note: Check that each ink tank is installed in the correct position:
    Properly installed:
Feb 08, 2010 | Canon PIXMA iP4000R InkJet Printer
Lines/streaks on paper even after deep cleaning and head alignment
Set the print head on a paper towel to dry, drying time will vary. ... Run a print head alignment and a regular cleaning followed by .... Normally you can clear up minor clogs and streaking by running the cleaning cycle found in .... After all the deep cleaning cycles I suspect I have now clogged ...
www.applefritter.com
Dec 06, 2009 | Canon BubbleJet i560 InkJet Printer
Photos printed come out faint and lines andblack streaks across the photos how do i solve this/
lean The Print Head Nozzles (Windows) The following contains instructions to check the nozzles for poor print quality and perform cleanings of the print head nozzles as necessary. If print results are faint or streaks are printed, the print head nozzles may be clogged. Print quality can be improved by performing print head cleanings or print head deep cleanings. aution: Only used the approved methods below to clean the print head. Use of other methods may further clog the nozzles on the print head and may cause permanent damage the print head.
Note: It is important to check the cleaning results by printing Nozzle Check Pattern after each cleaning. Cleaning and Deep Cleaning consumes a certain amount of ink. Only perform a cleanings when necessary.
Print a Nozzle Check Pattern
  1. Confirm that the printer is connected to the computer and the printer is turned on.
  2. Complete or cancel any print jobs in progress.
  3. Open the Printers folder.
  4. Click the Maintenance tab. (The Maintenance window opens.)
    Note: The layout varies depending on the printer and version of Windows you are using.
  5. Insert a piece of letter-sized plain paper in the paper tray.
  6. Verify the desired paper source for the Nozzle Check is selected on the unit by changing the Paper Feed Switch if necessary.
  7. Select 'Nozzle Check'.
Aug 27, 2009 | Canon PIXMA MP600 all-In-One InkJet...
6C cartridge space will not print regardless of cartridge
Replace print head by following manufacturer's instructions. These instructions can be found on-line at www.canon.usa.com under support for your particular printer. Enter "removing print head" into the search box.
Try removing your present print head and cleaning the electrical connections with soft brush or clean microfiber cloth (lens cleaner cloth for glasses). Replace your old head and see if this solves the problem. If not, you probably need to order a new print head from Canon, or you may decide it is better to just buy a new printer because of the price.
Larry
Jun 01, 2009 | Canon PIXMA iP8500 InkJet Photo Printer
Canon mp600 won't print every line
hi! there if streak came to your printed paper,try to go on maintenance menu.doing this left click crontol panel and then click your priter,on printer left click and click properties then click maintenance,on maintenance click clean,make it several time then click pattern test if this acquired quality print,if theres problem try the deep cleaning observe there are much ink to consume in deep cleaning,don,t try to clean your print head w/c not recommend on your manual,otherwise you will damage your printer head,if still streak bring this to your cannon service center to check printer head status,regads and havw a nice day thank's.
Mar 28, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Canon i860 won't print deep colors
I had similar problem: everything muted and with brownish tint. Tried everything, finally discovered that I installed wrong cartridge: 6PC instead of 6C. The "photo" cartridges are pretty much the same, make sure you have the right ones: 6C, 6M, and 6Y.
Nov 17, 2008 | Canon i860 InkJet Photo Printer
Printed gray looks pink
maybe the print heads need cleaning?
Jan 27, 2008 | Canon PIXMA MP600 all-In-One InkJet...
49 people viewed this question
k24674
