Question about RCA L42WD22 42 in. LCD Television
Unusable Signal I've had this RCA L42WD22YX5, 42in LCD TV for 14 months. About a week ago, while viewing a program, it just went dark, with 'unusable signal' message jumping on the screen. This was the RF input that I was using. I tried the composite video input and still the same problem. Then I tried the component video input and that one worked. But I really need to get the RF input working since I have it connected to my dish receiver. I also tried the VGA input by connecting it to my computer. It worked for a couple of days and now I am getting the same 'unusable signal' message showing on the screen too. Are these all related to one faulty board? If yes, please let me know which board needs to be replaced. Thanks, Mike S.
  • 4 more comments
  • Anonymous Feb 12, 2009
    i have the same problem no signal
  • alvelez1961 Feb 15, 2009
    yes all of my inputs do not work it reads unusable signal
  • Johnny Washington Jan 21, 2013
    Check the fuse on your main board I think it might be bad
    The fuse is very small so you have to look for it really good to find it ok.
    I fix this tv with the same problem that's why I know what the problem is
  • bon Congleton Jun 27, 2013
    alvelez1961 did you ever figure out the issue? im having the same problem
    New Friend:
Check your fuse on the main board I think it is bad
Posted on Jan 21, 2013
    Problem Solver:
  • 53 Answers
Hello Mike:
The issue that you are having is with your small signal board and it needs to be replaced, it sounds like the microprocessor on that board is getting locked up.
Posted on Aug 19, 2008
42 RCA TV flashing unusable signal
Ur backlight video board it dead,must replaced.
Dec 05, 2009 | RCA L42WD22 42 in. LCD Television
I have an rca L42WD22YX5 that just went to a blank screen yesterday. The screen keeps reading unusable signal. It is only 14 months old.
i had this happen last year, now my tv is messed up again. when we had the problem with the unusable signal, the tv repair shop told us it was the main motherboard that caused it. ended up paying $250.00 to have it fixed. Now, our tv is broke again, this morning turned it on, got the green light, then just started flashing red, hasnt worked any at all today, reset it and everything. My suggestion, if you can afford to buy a new tv, do it, because I called the repair shop again this morning about the new problem, they said after the 1 year warrentt from rca runs out all they do is tear up. My tv isnt even 4 years old, bought it at the end of 2007, now its tore up twice, going to purchase a samsung in the morning from brandsmart. Good Luck!
Sep 29, 2009 | RCA L42WD22 42 in. LCD Television
I can not connect my rca dlp HDTV to my hp laptop. I tried using VGA wire, laptop is fine but TV is showing unuseable signal
A lot of TVs only accept limite PC resolutions. Try 1028x768 60hz this normally works.
The Error message doesn't mean the TV or PC is not working, only that the signal is not compatible. try all resolutions until something works.
Jun 23, 2009 | RCA L26HD31 26 in. LCD HDTV
RCA 46" LCD TV - HDMI Stopped working overnight
I don't mean to sound ignorant, but can I assume you have already checked your Source Selection just incase someone hit a different button on shutdown ?
Sometimes when I just set the remote down can sometimes change a setting on the TV, I thought maybe the same may have happened to you too.
Jun 03, 2017 | Televison & Video
Unusable signal
we had that problem last week.i bought a new remote control and it worked fine.
Jan 01, 2009 | RCA L37WD12 37 in. LCD HDTV
Unuseable signal
WHAT HAPPENS WHEN YOU USE A DVD INPUT (AV) OR A SAT/CABLE BOX CONNECTED TO THE AV INPUT'S ,,IF IT CLEARS UP YOU HAVE A SIGNAL BOARD BAD BUUUUUUT YOU CAN BYPASS THAT BOARD AND SAVE MONEY JUST BY USING THE AV INPUT...TUNICA
Sep 25, 2008 | RCA P52926 52" Rear Projection Television
61" RCA Projection TV, no picture, "unusable signal" message
Read the suggestion of unplugging the TV for at least 4 hours to re-set to factory specs and that took care of it!
Apr 03, 2008 | RCA HD61LPW165 61" Projection HDTV
RCA Scenium HDLP61W151
I had the same behavior, but not as a result of power outage. The TV is driven by windows CE software and it goes haywire every now and then. Usually pulling the plug for a few seconds takes care of any problems, but not this time (as you noticed). I had unplugged my ethernet connection on the TV a few weeks ago and thought I'd hook it up again to see if there was a new software release (not likely). I went to the menu and chose "Connections" and then chose "Ethernet Setup" and then chose "Reset All". After I closed the menu the TV rebooted itself (as it said it would). After my TV rebooted I had my analog channels back. There shouldn't be any connection between these two events, but it worked for me. Hopefully it will work for you as well. Good Luck!
Feb 17, 2008 | RCA Scenium HDLP61W151 61 in. HD-Ready...
Lost Station
table top box from rca,to get the channels
Nov 05, 2007 | RCA F38310 38" TV
Unusable Signal
Hi. What you need to do is plug in a cable or Antena in its place, and reprogram the channels. if you did that, then try to use a VCR or DVD player and install it using the RCA cables. Install the cable to the DVD or the VCR. If nothing works, My TV has a crack in the LCD. I'll either sell it to you, or buy yours. Let me know. Thanks.... email me to hajum30@yahoo.com
Thank You...
Sep 29, 2007 | RCA L46WD22 Television
RCA L42WD22 42 in. LCD Television Logo
1,409 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
