Question about Brother MFC-410CN All-In-One InkJet Printer
Brother mfc-410cn colour cartridge problem
Printer says my magenta is empty, have put in 2 new cartridges and message is still the same, 'replace magenta' could you help me with this one
  • bonnifazio Jan 05, 2009
    I have the same problem with magenta.
  • 5,660 Answers
There may be three problems here.
1.Not doubting your skills for one minute, nor wishing to offend you in any way, but did you remove the protection strip off of the Magenta ink cartridge? Sometimes we forget to do that.
2.Once a new ink catridge is installed, it's best to go to the Brother diagnostic tools section, and run a test. Sometimes an error code is kept, (Ink cartridge is empty), and the diagnostic tool checks this out. It then clears the error code, and 'recognizes' the new ink cartridge.
3.Ink may have dried, for the tiny little holes for the magenta ink cartridge, where it attaches to the body of the printer. Just this one ink cartridge. Suggest you don a pair of rubber dishwashing gloves. MFC-410cn -> Unplugged <- from the surge protector, use a clean, lint free, warm water, damp cloth, and wipe the holes for the ink cartridge, where it lines up with the printer body. This will be where you see that copper metal strip. (Or perhaps it's brass)
To clarify, you are cleaning the printer body. The area where the ink cartridge goes, and the metal strip. The ink passes from the ink cartridge, and goes through holes in the body of the printer. The metal strip is where these holes are located. Allow this area to dry. You may want to use a hair dryer set on low heat to speed the drying process up. Constantly move the hair dryer back and forth. Keep it about a finger length away.
Once you are satisfied this are is dry, reinsert the magenta ink cartridge. Plug the printer back into power. Advise waiting one minute, then turn the printer on.
Use the Brother diagnostic tool.
Should you not be able to find the Brother diagnostic tool, I suggest you go to Start>Hover your mouse cursor on All Programs>Go over to Brother>MFC-410cn>and to the Help section. The Help section, will tell you how to open the diagnostic tool.
Posted on Apr 15, 2009
MFC-J430W will not recognize any new magenta cartridge!
When installing the cartridges, it is important that you insert them from left to right with the black cartridge first and the magenta cartridge last. The reason for this is because the magenta cartridge has a clip on top of it that goes into the cartridge door sensor. The clip needs to push the sensor in so the printer is able to function with the cartridge door open. If you insert the magenta cartridge first, the printer will think the cartridge door is closed and you will get a error message for the other missing cartridges.
May 29, 2013 | Brother Office Equipment & Supplies
Machine says that magenta is empty, cartridge level reads empty. But when I put a new magenta cartridge in it reads no cartridge open cover and reinstall magenta cartridge. The cartridge is full and is a...
maybe it have the ink level chip which can be resetted by removing the cartridge and oning and offing the printer for 5 times within 10 minutes coz it saves data of a cartridge upto 5 use before only.. and 6th time insert it.
Sep 28, 2009 | Brother MFC-5460CN All-In-One InkJet...
Changed yellow ink to new cartridge. Printer won't recognize.
I contacted the Brother site, the support function there. Pursuant to what I found there, I unplugged the printer for ten seconds and replugged. The message display then told me that cyan was empty, and that magenta was near empty.
I installed a new cartridge in place of the empty cyan, and that fixed it.
Jun 04, 2009 | Brother MFC 420CN All-In-One InkJet...
Wont print with all new ink cartridges
If the error message is only "magenta/cyan low", it doesn't cause any error. The low message stays after replacing ink cartridges if they're replaced too early (before they're indicated as actually empty), it doesn't cause the printer to not work.
However, some other problem might be faulty, or there might be another error message. Try emptying printer queue and print from Ink Management -> Menu/set (twice) to check wether the problem is with communication from pc or if the printer actually is unable to print.
May 29, 2009 | Brother MFC 210C All-In-One InkJet Printer
Toner Cartridge empty
does the display come up as "toner empty x"? what is the last character after the toner empty ?
where x is:
c=cyan= 6,600 pages
m=magenta=6,600 pages
y=yellow=6,600 pages
k=black=10,000 pages
Jan 06, 2009 | Brother MFC-9420CN All-In-One Laser...
Brother MFC-210c-Just replaced ink cartridge & it is already empty
I gave up on this printer and bought a new one from a different manufacturer.
Oct 01, 2008 | Brother MFC 210C All-In-One InkJet Printer
MFC 660CN
message says"removescanner cover,then reinstall cartridge," just renewed cartridge.
Jun 05, 2008 | Brother MFC 420CN All-In-One InkJet...
Brother MFC 5460CN No cartridge error
The tape method worked for me on my 1960C. I put duct tape over the window in the front. If there's a place you can see ink, cover it up.
Nov 14, 2007 | Brother MFC-5460CN All-In-One InkJet...
Model mfc-240c
did you replace with brother carts, are you sure machine is refering to mag and yellew being mt, not the other ones, power off, remove all carts, power on , reinsert carts one at a time answer machine when prompted. these cartridges are deemed empty even when they look like they have a little ink left. Try putting in 4 new brother inks
Nov 09, 2007 | Brother Multi-Function Center MFC-240C...
Empty magent
Magenta is the colour of one of the 4 inks used in your printer. You need a new magenta ink cartridge because it's empty.
Sep 21, 2007 | Brother MFC 210C All-In-One InkJet Printer
Brother MFC-410CN All-In-One InkJet Printer Logo
306 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
