Question about Weather King 10AJA6001AH Air Conditioner
Weather King AC
When I go to turn my AC on on the thermostat, it will blink cool, I will hear the ac unit kick on but no air will come out. I was wondering what is going on and if there is something that I could check.
  • Weather King Master
  • 5,568 Answers
The motor of your air mover in the inside unit has failed.
It is responsible for circulating the air through the exchanger and your home.
This may be located in an attic space depending on the construction of your house.
Running the cooling with this not working could cause your outside unit to operate continuously or fail.
A more remote possibility is that the thermostat has failed and is only causing the outside unit to run.
Posted on Aug 19, 2008
I can't get my AC to turn on. I'm house sittting, so I don't know the ropes of this AC system. The AC pad only has up and down buttons, but when I adjust them they just blink for a while and then go back...
Hi, on the thermostat there should be a door of flap that opens, pulls down to reveal more buttons such as Cool, heat, auto, off, on. Find these and they will either be switches or a touch pad. Turn it to cool and auto. You should be able to use the arrows to lower or raise the temperature at that time. It may say hold temp on it also. Set the temperature where you want it, lets say 75 and push hold temp. It should work for you now. Please let me know how it turns out or if you need more help.
Sincerely,
Shastalaker7
A/C, Heating, & Refrigeration Contractor
Aug 09, 2010 | Weather King 10AJA3601AH Air Conditioner
Weather King 13AJA36A01 AC freezing up at night
check the inside coil is dirtyor may be low on freon
May 14, 2009 | Weather King 12AJA4801AH Air Conditioner
What type of freon my ac uses
R-22, if it were R-410A then it would have a pink sticker on it near the service ports. You would know for sure.
Mar 24, 2009 | Weather King 12AJA4801AH Air Conditioner
Problem with my AC unit
Hi Phillip,
Check your thermostat wires to see if you have any of them which are bare and touching. If any are touching separate them and tape em up and try unit again. You have a direst short in your cooling portion of the unit.
Feb 12, 2009 | Ruud UAMB Air Conditioner
Weather king ac not working at all
see if there is a switch at the furnace that may be off.check the doors as well for tightness.If that doesnt do it,you may need a pro.
Aug 05, 2008 | Weather King Heating & Cooling
Fan
you need to have whole ac serviced do everthing at once so it works right
Jun 02, 2008 | Weather King 10AJA4801AH Air Conditioner
Weather King 12AJB60a01 - Noisy Clang at Startup like hitting metal lockers
Sounds like the compresser is going out on the unit the noise is internal the winding would not have anything to do with that noise maybe valves going out
May 23, 2008 | Weather King 10AJA2501AH Air Conditioner
Weather King 10AJA6001AH Air Conditioner Logo
121 people viewed this question
Top Weather King Heating & Cooling Experts
Donni Steen
Tim Whalen
John Tripp
John Tripp
Are you a Weather King Heating and Cooling Expert? Answer questions, earn points and help others
