Question about Kenmore Washing Machines
My HT3 washer door will not lock. The washer will close and click but the door does not lock closed. It will work if you hold the door closed.
  • 5,911 Answers
It sounds like your door latch assembly is worn out, or the door gasket is not seated properly. Inspect the rubber gasket around the wash tub opening and make sure it is seated around the door opening properly. If the gasket checks okay, the latch should engage and hold the door shut. If it doesn't, I would recommend replacing it. The following link explains how:
http://www.fixya.com/support/r587965-door_latch_replacement_fdl_error
A replacement latch can be ordered on line at searspartsdirect.com or repairclinic.com. Compare the two sites for the best price. I hope this helps you. Please let me know if you require further assistance.
Posted on Aug 19, 2008
Maytag Brovo 300 seies washer display says dl and will not wash
The error code "dl" is for door lock. From what I've read, it may mean you need to replace the latch assembly.
Sep 07, 2014 | Maytag Bravos MTW6600T Top Load Washer
Kenmore front load washer door won't latch lock light on
On some Kenmore front load models, if the black gasket around the door opening is unseated (for example, because you drag some heavy wet laundry over it) the door will not engage the lock and stay closed. This is a feature to prevent the washer from leaking when the gasket is not sealed. To fix it, simply reseat the gasket and the door will close and lock.
Jun 21, 2012 | Kenmore 44102 Front Load Washer
Bosch 500 series front load washer less than 6 months old. Getting code E27 when turning it on... suggestions before I call service?
E27 means there is a problem with the door lock.
Unplug the machine for 30 minutes and try again. If the error code returns you will need to replace the door lock assembly. Open and close the door two or three times to reset the sensor. Sometimes the door has been closed too hard and the sensor reading fails.
Replace the door lock assembly on the washer. Refer to your washer manual for the correct part numbers.
Check to see if your Bosch washer is still covered under warranty. If so, you could receive free replacement parts and service for the faulty door locks.
Hope this helps (remember to rate and comment this answerr).
Jul 16, 2011 | Bosch Evolution 500 Series B20CS51SNW 20.2...
My washer latxh will not lock or close. I xan hold it c;psed bit all I near is a clicking. Please help me???
There is likely to be a problem with either the lid/door solenoid/lock or the 'lid/door closed' sensor requiring a service engineer's attention I suggest ;-0(
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
Jul 08, 2011 | Whirlpool Duet GHW9150P Front Load Washer
F dL symbol on Whirlpool duet HT
It is saying there is a problem with your door Lock. when you close the door does it hold like it use too? try to open and close the door if it doesn't really close properly then you will just need a door latch. If the machine gives you an f11 code then its the main computer board that can also give your the door lock error. I would check the door first though.
Jan 09, 2009 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
Front Loading washer Kenmore Ht3
Here are the steps to unlocking the door manually if clothes are still in the machine.
1.Unplug machine
2.remove bottom panel
3.Reach up along the inside of the front panel and locate the botttom of the door latch assembly
4.Located on the bottom of the door latch assembly is a tear dropped shaped tab
5. Gently pull down on the tab about a 1/4 inch or until a click is heard.
6. You may now open the door.
This code means the door lock mechanism has failed or the central control unit has failed. Replace the door lock mech. first. This should fix the problem. (before replacing anything make sure there is no obstruction around the switch or in the switch.) After the machine has been unplugged it may fix itself. if not replace door lock mech.
Nov 15, 2008 | Kenmore 46462 Front Load Washer
Washer won't start/lights on
ok try first to make sure the detergent drawer is closed tight if its not will stop washer is the door locked some times you have to close them firmly make sure the lock light is on hit pause cancel twice then try washer
Dec 30, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
81 people viewed this question
Sal De GO PATS
fordexpert
Ed Mac
