Question about Neff 24 in. S5456 Built-in Dishwasher
Neff Dishwasher Model: 195301525 built-in I require a schematic for this model so I can order some parts for the unit: Top panel which is broken Catch Door Handle
    Problem Solver:
  • 7 Answers
Telephone BSH 08705 543210 ask for spares department who are very good helping you with spares as long as you have all relevant serial and product numbers it can sometimes be difficult to get through because they are always busy, be persistent
Posted on Oct 09, 2008
My Bosch Dishwasher door sticks shut at the end of the cycle. I can open and close it with ease during the cycle, but once it finishes I have to pull really hard to open it.
see all this steps and fix it. God bless you
Door or Lid Latch Assembly
If the door won't latch, the latch assembly might be defective. Inspect the latch assembly to see if it is cracked or worn out. The latch assembly is normally replaced all as one part.
Enter your model number to see parts for your dishwasher.
Help me find my model number
Door Hinge
If the door won't latch, one or more of the door hinges might be bent or broken. If the door hinges are not working properly the door won't close squarely and then the door won't latch.
Door Catch
If the door won't latch, the door catch might be out of alignment or broken. If it appears to be OK, reposition it as needed. If appears broken it should be replaced.
Door Lock
If the door won't latch, the door lock assembly might be defective. These are normally made of plastic and cannot be repaired. If the door won't latch and the door lock is broken, replace it.
Door Latch
If the door won't latch, the door latch assembly might be defective. These are normally made of plastic and cannot be repaired. If the door won't latch and the door latch is broken, replace it.
Door Strike
If the door won't latch, the door strike might be defective. These are normally made of plastic or metal and cannot be repaired. If the door won't latch and the door strike is broken, replace it.
Apr 05, 2013 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Shelf fitting slot broken off
Use the link http://www.neff-eshop.com/eshop/neff/gb/prodlg.htm?x=0&y=0&Maktx=Neff+U1721&eshoptype=Aenter the FULL enr from the rating plate, don't just pick the nearest one if the enr is U1721N0GB/75 that's the model you need to check as parts from one model to another can vary. This will open a diagramatic breakdown of the oven and you can search for the relevant part (and buy if online direct from Neff). Couple of things to remember, make sure you have the right oven (ie top or bottom) and whether it is the front or rear holder as one is like a keyhole and the other is a keyhole on its side.As this is a build under unit, it does make changing the part a little easier (depending on which one is broken, hoping for your sake that it's not the back top oven one..Argggh!!) You will need to get the oven out and I find it easier if it's on it's side with the faulty holder at the top. The side panel needs to come off (or at least be loose if it's a front holder) as the holders are held in place by a retaining clip behind the cavity wall, or if it is a screw in type, the screws comes in from behind the cavity wall. I suggest you order and get the parts first and this will give you an idea what you're dealing with. Let me know how you go and post any comments or problems you have whilst doing the repair (anything I've forgot to add) as this will help anyone else looking for a solution to a similar problem.Ps. If you are sensitive to fibreglass, wear a pair of gloves.
Nov 23, 2011 | Neff U1721 Double circotherm Electric Oven
WHO MAKES THIS MACHINE AND WHERE DO YOU GET PARTS AND WIRING DIAGRAM
At this stage I can only tell you this dishwasher was made by a company called Applusa and it is atleast 10 years old.
It was an Italian made dishwasher imported into US by a trading company called "Stainless" who would also use their logo on some of these imports.
I am trying to find if anyone acquired the service business for this model of appliances. Will have to get back to you in a couple of days if that is OK>
Aug 24, 2010 | Stainless 24 in. SDW3162 Built-in...
Our Neff S5454x1/21 dishwasher has occasionally stopped/stuck
Looks like the heater unit has packed up.
I cannot seem to find the actual model you have anywhere on the internet. But I am assuming you connect the dishwasher to cold water inlet and it is meant to have a heater.
Are you in UK or Europe. Bosch also makes parts for the NEFF dishwasher but I am not able to find spare parts for your exact model.
Please post a comment.
Jun 05, 2010 | Neff 24 in. S5453X1 Built-in Dishwasher
The door would not shut. We checked all around and nothing was blocking the door from shutting. We determined the latch on the door was not releasing. I forced the door shut. The touchpad...
Lowes is right regarding the parts needed.
First check the strike part is ok - that's on the body of the machine not the door.
Unplug the machine.
Remove the front door panel by removing the visible screws on the door.
Check the door catch for broken parts, and order those required before using again,
It is a fairly easy fix once you've identified the part required.
May 02, 2010 | Whirlpool DU1055XTS Built-in Dishwasher
I replace torn outlet hose on my Neff S4438 built
make sure you still have power going to your unit. sometimes they are plugged into a regular wall plug under the sink or you can also chrck the circuit breaker @ the panel most of the on the out side of the house
Oct 25, 2009 | Neff 24 in. S4443 Built-in Dishwasher
Neff dishwasher door catch not corking, door does not close ?
look carefully at the catch and the latch as almost all can be adjusted with just a screw driver.
May 31, 2009 | Neff 24 in. S4456 Built-in Dishwasher
Neff Built in Dishwasher
take top off then side panel and hinge is exposed. to expose the part of hinge on door, take outer panel off door - just held in by screws down each side
Jun 26, 2008 | Neff 24 in. S5456 Built-in Dishwasher
Neff built in dishwasher model no: S4453N0GB/07 When you switch the dishwasher on all the relevent lights swich on, indicating the dishwasher is ready to use. but when you switch the start button it clicks...
We fixed the problem at home. The Start button had a loose connection.unscrewed the panel and pushed all the wires in and were able to restart the dishwasher.
Feb 29, 2008 | Neff 24 in. S4456 Built-in Dishwasher
Neff 24 in. S5456 Built-in Dishwasher Logo
165 people viewed this question
Top Neff Dishwashers Experts
shaun taylor
Michael Galve
Michael Galve
Are you a Neff Dishwasher Expert? Answer questions, earn points and help others
