How are external DVD RW recorders fitted to the pc
    Scholar:
  • 113 Answers
External DVD RW recorders come with three different interfaces:
1) Oldest type was using the parallel (printer) port
the other two interfaces are USB & Firewire
Posted on Aug 19, 2008
SOURCE:
What should the CD's recording speed be when buying a blank CD-R/CD-RW for an Acer Aspire 5750-6677?
Rewritable CD-RW / DVD-RW media typically have lower recording speed (4X - 12X is common) compare to CR-R / DVD-R (20X - 50X is common).
The quality of the CD/DVD media is the most important factor: buying a well known brand blank media is always advisable.
The higher the recording speed for a specific brand the higher the price: that said, a CD/DVD with a high recording speed rating can always be used at a lower (and usually more reliable) speed.
If you are not burning CD/DVD everyday, then a cheaper 'slower' media, especially at an attractive price point, is OK.
ps. Be aware that writable CD/DVD media are not always readable/compatible in other devices (e.g. external DVD or CD players) ... even well known brand media can fail compared to lesser brands.
Sep 23, 2011 | Acer (4432A-002) CD-RW Burner
What is the difference between a DVD+RW and a DVD-RW.
DVD-RW
It is the re-recordable version of the DVD-R. To use this type of media you will need to buy a DVD-RW recorder. The DVD-RW recorders usually record DVD-R, CD-R and CD-RW media, too. Similarly to what happens to DVD-R, DVD-RW disks can be played in newer commercial DVD players without any problems. Older commercial devices cannot recognize the media, refusing to play the disk. To play a DVD-RW disk, commercial players need the disk to be finished. After finishing the disk, you can only record new data in it by reformatting it, which makes you lose all the recorded data.
DVD+RW
It is the re-recordable version of the DVD+R and everything that was said about the DVD+R is valid for the DVD+RW. Only the newest DVD players play movies recorded in disks using this format. There are recorders on the market that can record both DVD-RW disks and DVD+RW ones. These recorders are called DVD?±RW. Similarly to the DVD-RW, the disk needs to be finished to be played in commercial DVD players, and to record new data in the disk after having finished it requires reformatting it, which makes all the data in it to be erased. DVD+RW recorders are usually capable of reading DVD-RW disks (but not of recording them) and vice-versa.
There you are.
Aug 22, 2011 | Acer Computers & Internet
Recorder works great but cannot play DVDs recorded from television on my computer. These recordings were made of several films over six hours on DVD-RW discs. I have Windows 7 and have tried all types...
Recordings made on DVD-RW discs cannot be played in other players, including many PC DVD-ROM drives; incompatible format. If you had recorded your TV/video material onto a DVD-R in the recorder, for example, then finalised the disc, it would work in your PC and any DVD player.
But since you used a re-writable video/data DVD, it won't work outside of the recorder - that's why you can't play it (or if it was written on your PC, your recorder won't read it - incompatible disc).
If you don't wish to finalise the RW disc (I don't recommend it - plus I wouldn't blame you for not wanting to do that), you could copy it from one recorder to another, unless your PC has a capture card - which allows the outputs of your DVD recorder to connect to the PC inputs. Using relevant DVD software (for example, ULead DVD factory), you may be able to 're-author' the contents of your recording, and create a DVD-R copy which WILL work in all players that way - use DVD-R (or DVD+R if your PC and other players allow that format) for 'permanent' video recording - use re-writable discs for backups, test recordings, temporary stuff, and PC data files. There are many inexpensive software programs available. Have a look sometime at your leisure. See what they are like.
Even if you could copy the DVD contents in a Windows program, regardless of the software used, there is no guarantee that the copy you make will work outside of the player and/or original recorder, because it would require a lot of time and effort to achieve, and unless you know what you're doing with the program, you could waste a lot of time (and blank discs) in the process - it only adds to the frustration.
I am glad to hear your recorder has no major faults at present - that's great. No expensive workshop repair cost headaches; just frustration with discs (especially if they become drink coasters).
DVD-RW is ideal for test video recordings and PC data, but is limited when it comes to compatible playback/usage outside of the device it was written/recorded on.
DVD+RW discs on the other hand, when titled/ top menu created, can be played on a PC or player without finalising. You can even direct copy a DVD+RW straight to a DVD-R - it works in most cases.
The upshot of this is you haven't lost anything, and with the exception of perhaps a few dollars for a pack of either DVD+RW, DVD+R, or DVD-R discs (any brand), it didn't cost a fortune. You can also retain any DVD-RW discs you have previously used.
The simplest and cheapest options are often the best ones.
Mar 24, 2011 | Panasonic DMR-ES10 DVD Recorder
Trying to write to blank disk first time (Memorex CD-RW). Get message: Record failed: wrong format for re-write Spectroniq SDR-205 DVD Recorder
Some DVD recorders cannot write CD-RW - only DVD-RW (+ and -) as well as DVD-R (+ and -) (this depends on the brand/model). This unit probably does not support CD recording. Try using DVD-RW instead for this machine - see if it records that (do not finalise even if unit prompts you to with an on-screen message prior to ejecting disc).
There are DVD players and recorders which can play CD-RW (mp3, jpegs etc.) but I don't know of any which record this format (a PC CD/DVD-ROM drive can do this though).
Mar 09, 2011 | Televison & Video
My dvd rom have some difficulty to read some DVD.. But not all i can read the matrix 1 but not the matrix 3... Any suggestion
A DVD rom driver can read DVD disks only. DVD Recorded, DVD ReWritable disks cannot be read on the DVD rom driver. Acquire an external DVD RW driver to make possible any recorded digital formats readability.
Dec 21, 2010 | HP Pavilion a1630n PC Desktop
Iam not getting power to my dvd rw
Please describe your DVD-RW if it is internal or external? External means that it is enclosed in a separate 5.25" HDD/DVD-RW enclosure.
If it is internal, check for a worn-out power cable on the ATX PSU. If it is external, check for the proper voltage output of your enclosure power supply by a voltmeter/tester. Ask assistance from an electronic technician or anyone who is knowledgeable enough to use the said tester.
May 24, 2009 | Coby DVD-R1300 DVD Recorder
Replace the dvd-rw drive in a sanyo drw500 with new betterproduct
IF u are only talking abt the Drive only then yes u can get a better one now.
From what u had stated I prsume tht it is in an external bay which has USB or firewire compatibilty , Right?
If this is the case, then U can get a better drive for this, any tyoe will do as long as it is a DVD RW drive.
The one u have currently is a very old one which has very limited capability like recording to DVD-ROM cd's, it can only write DVD+ROM types....
Now u can find Drives which supports + / - type dvd discs and ROM's and also RAM Drives.
Just do a google search or I can state what I uses. I Use
1 - Sony DVD RW DRU-845S
2. TDK DVDRW 1616N
These are the best in it's region when they were released, I believe there are better ones now.
Cheers
Rifaa
Nov 19, 2008 | Sanyo DRW-500 DVD Recorder
How can i watch dvds ?
You need to buy an external DVD RW, you will be able to watch and record DVD and CDs on your Eee.
Here is a lelection, they start from $40
Cheap ones are usually big, probably bigger than your Eee, here are a couple of nice pocket model
Addonics Pocket DVD+/-R/RW - DVDâ±RW drive
External Dual Layer DVDâ±RW Drive
LG LightScribe External DVD+/-RW Dual Layer Slim
Targus PACMB010U DVD/CD-RW Drive
Let me know if this had been helpful.
Many thanks
Aug 28, 2008 | ASUS Eee 4G Notebook
Copying video to dvd
1st, does it come with a driver...if it doesn't, just make sure it is installed properly in your PC, then you just need to install a dvd writing software in your PC e.g. NERO Pro (v7 or later)...then, all will fit in...
Jul 23, 2008 | Samsung DVD-R130 DVD Recorder
How do I get a Verbatim DVD RW disk to record a file that i have downloaded
1. You need a drive that will record on a DVD RW.
2. You need software that will let you record to a DVD RW (such as nero, roxio, there are others)
If you have the above the two, it depends on the software you use on how to record to the DVD RW.
Jul 01, 2008 | Computers & Internet
Open Questions:
Computers & Internet Logo
23 people viewed this question
Ekse
Alun Cox
