I have successfully completed my first disc - transferred 4 hours of 8mm camcorder tapes to DVD+R format. Finalized the disc and am able to replay it on my PC, regular DVD player and portable DVD player, all with no problem.
Now I would like to make a copy of the disc for my in-laws and another for backup, but neither of the programs I normally use on my PC, Nero and DVD Shrink, recognize the format of the DVD and are unable to copy it.
Any alternatives to going through the whole procedure all over again from start to finish? (4 hours + editing/finalizing time.)
There are three ways of transferring the videos from the Camcorder to the Computer. One is by using the Picture Motion Browser Software, other by using the A/V, USB cable after finalizing the disc in the Camcorder and finally using the DVD-ROM Drive in the Computer after finalizing the disc. If you're trying to transfer using the 2nd and 3rd option, the the disc in the Camcorder should be finalized.
Also make sure that the disc is formatted in DVD-Video mode instead of DVD-VR mode. VR mode recorded discs can only be played back using a VR Compatible Software/Player or in the same Camcorder. DVD-Video mode recording will help you in playing the discs in all the Players and DVD Viewing Software.
I always recommend transferring the videos to the Computer using the supplied PMB Software.
Please check transferring steps and information from the link given below:
http://www.kb.sony.com/selfservice/microsites/search.do?cmd=displayKC&externalId=C409768
Thanks.
KenSolutions
Not sure how getting a laptop is going to help, unless you mean to use it to play my first disc back into the DVR as the source for a new recording. I can do this now, using my DVD player, but it's still going to take 4 hours plus editing and finalizing time for each disc. I'm looking for more of a mass production-type of solution.
I tried Nero, but it doesn't recognize the disc at all, so I can't even make a disc image. I will, however, try to see it Explorer or any other file manager can read the disc, asGazllFixIt suggests. Then I may at least be able to copy the files, which will be a start.
So what files-types do you have on your DVD master if you explore the disc on your computer?
