Question about Sharp AR-407 Copier
Error code h5-01
My copier says call for service h5-01 i know there is a way to clear that with a series of numbers in the programing menu or the key operator menu can you help
    Problem Solver:
  • 3 Answers
H5-01 Refers to an exit sensor problem, open the left side door and check the exit flag and or sensor. But yeah to reset H codes go into simulations by pressing (Program, Interrupt, Clear, Interrupt) Once in there hit 14, Start. Then it will ask you if you want to execute or something in that manner. Hope that helps
Posted on Aug 19, 2008
Sharp AR275 copier error message received is "call for service u2-40" please what can i do to solve the problem?
in order press
* Entering the simulation mode
1) #/P key (program) ON → Asterisk (*) key ON → CLEAR key ON →
Asterisk (*) key ON → Ready for input of a main code of simulation
Simply # * C * and the machine will enter simulation mode.
Then enter the number 16, which is U2 code correction, follow what the screen says, Normally just press start and the machine will reset.
U2 codes are software glitches. A U2 40 is a CRUM fault which is a drum or toner chip problem.
Sim 16 almost always clears them.
May 19, 2011 | Sharp AR-275 Copier
RICOH 2045E COPIER WHAT DOES ERROR CODE SD546 MEAN?
Hello!
Follow the next steps carefully and the error code SC546 will disappear.
Press the following keys by this order:
1. press the (yellow key) [Clear]
2. press then the numbers on the numbers key by order (1)-(0)-(7)
3. press the red key (cancel) [C] and hold it pressed for about 5 seconds.
4. on the screen will appear another menu different from the one
you are
familiarized it will write up in the left corner [service menu],
(if the service menu do not appear repeat the procedure again).
After this menu will appear turn off the machine from the red switch which is located somewhere in the middle of the machine and just by the left corner (the turn off switch-plug) wait for 10 seconds and turn back on the machine by the same switch-plug.
After this the error code SC546 should be disappear.
Please Answer does this was helpful for i to know does the problem has disappear or i should post some other information.
Regards
Jan 12, 2010 | Ricoh Aficio 450 Copier
Unable to enter program mode for Sharp AR-C260M Copier / Printer
Solved the problem by switch on press #P Then * then C then *  then 14  This will then ask if to execute the action to clear the service code H5-01.
Will need to ensure that the fuser unit is not causing a blockage on the feed out path as this code is caused by 5 errors / misfeeds in the Fuser unit.
Nov 13, 2009 | Sharp AR-C260M All-In-One Printer
How can I get the error codes of my Sharp AR-507 and how to clear
Press the "P" key, the "Interupt" key, the "C" key then the "Interupt" key.
Once you enter the Simulation Mode, then "2,2, start (Print Key) will show the jam, service counters, and 2,4 start (Print Key)"will allow you to clear the counters.
To clear certain codes, once you enter the Simulation Mode, then enter "13 or 14 or 15 or 15 then start". Depending on the code will depend on which "number" you need to execute. (It doesn't hurt to do all the numbers."
Aug 08, 2009 | Sharp AR-507 Copier
I need to retrive the key operator code for a Aficio 1060/1075. How do I do this?
You cannot restore the key operator code for the Aficio 1060/1075. You can delete the code and then write new one .
Follow the instructions and will be easy.
1. enter the service mode.
2. To enter the service mode press one after other the follow keys on the control panel of the copier.
press the yellow key [ Cancel Modes] than press the number one after other [1]-[0]-[7] on the number keypad of the copier and than press and hold the red key [ Clear \ Stop] until on the touch screen do not appear the service menu after the service menu will appear press on the touch screen [Copy Sp] up in the right corner has a touch key [sp direct] press that key and press the follow numbers on the number keypad which are 7810 and then press "#' on the number keypad.
on the screen will appear "execute" press the touch button and than by pressing
"exit" several times you will exit from the service mode.
NOTE: "PLEASE DO NOT TOUCH NOTHING ELSE IN THIS MODE IF YOU ARE NOT A SERVICE TECHNICIAN BECAUSE BY PRESSING SOMETHING YOU MAKE SOME ERROR OR OTHER PROBLEM"
After clearing the key operator code you may enter new one.
If you need something else please ask
PLEASE RATE ME
Jul 15, 2009 | Office Equipment & Supplies
My ricoh 1022 after puting power on it shows error code sc542
What code? Try entering service mode then turn off copier and turn it back on. (push these buttons in sequence Clear modes (yellow) 1 0 7 then hold the red stop button for 5 or so seconds you are now in test mode
Jun 10, 2009 | Ricoh Aficio 2022 All-In-One Laser Printer
We have a Sharp AR-335 and it is giving an error
on the keyboard near the number pad. "c" is the clear button and I think program is "p" on that machine. Interupt is also up around the key/number pad. Its been a while, but Once you get into the maint/service mode, type in "14" and press the green start key. That will clear up any confusion the machine is havine unless its a fuser or laser code or something on those lines.
May 22, 2009 | Office Equipment & Supplies
How to clear error code SC571 on Ricoh 1232c copier
See thread I left you this morning on this. I hope it helps.
Press the yellow button. Press the 107 keys. Press and hold the red clear button for a few seconds until the service mode screen appears on the LCD display.
Oct 30, 2008 | Office Equipment & Supplies
Ricoh 1232c copier error code sc 517
The error is about the fusing unit for to reset the code you must enter into the service menu and reset the SC code 517
For to enter the service menu you should do the follow steps :
1.Enter the service menu by pressing the follow keys in order: yellow key[clear modes] then press "107" number one after other and then press and hold the red key [clear/stop]
2.Hold it down until service mode do not appear if not appear after 10 seconds try again.
After you will be in service mode press the follow numbers :5810 and then will apear on the screen "SC reset" set the value from "0" to "1".
Then turn off and after 5 seconds turn it on the machine.
Please replay if this do not help and write the SC code good because i cannot find the code SC517
Oct 29, 2008 | Office Equipment & Supplies
Canon 3320 Error message
you also have to high lite service mode and clear that or the error will return
May 15, 2008 | Canon ImageRunner 3320N Copier
Sharp AR-407 Copier Logo
1,605 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
