Washing Machines Logo
Posted on Jun 10, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hi, I have a Kenmore 70 Series Washer. Model number 110.20722990 Serial Number: CK 2634528. It has been running like a dream until today :( Started a load in the washer, filled fine, agitated fine, drained fine, when it went to the spin cycle, it started making this awful metal on metal grinding noise, and while looking at it, i noticed that the agitator is not spinning. I would like to fix this myself if at all possible, so if you could please give me some suggestions to try, or walk me through how to figure out exactly what it is, i would greatly appreciate it. Thank you in advance for your time
Anonymous
Level 3:
  • Master 600 Answers
  • Posted on Jun 11, 2011
Anonymous
Master
Level 3:
Answers
600
Questions
0
Helped
159006
Points
2012
Hello, Thank You for using FixYa. I will be helping you today.Sounds like the motor coupler broke.Part number 285753 here is a how to video http://www.youtube.com/watch?v=WLPGs2UMUJc
Thank You and please rate my answer if it was helpful..
Looking for age of Kenmore gas dryer Model 110.77741600
The are various idea here.
I have model and serial #s for my washer/dryer. What year ...
iFixit https://www.ifixit.com > Answers > View > I+have+m...
Apr 3, 2017 - I have a Kenmore washer and dryer. I have the model #s and serial numbers. I need to know what year ( how old are my appliances?) of the models.
4 answers · Top answer: Erin Morrissey , How to find out the manufacture date of a Kenmore washer or dryer by the ...
How old is my dryer? - Kenmore 110 Series ...
Mar 11, 2022
How old is my kenmore washer/dryer combo? - iFixit
Aug 4, 2018
help me find out how old this washer is - iFixit
Sep 29, 2021
What is this dryer model number? - Kenmore Elite ...
Jul 18, 2016
More results from www.ifixit.com Missing: 110.77741600 ‎' Show results with: 110.77741600
Can you tell me the age of a dryer from the model or serial
JustAnswer https://www.justanswer.com > Appliance Repair
May 19, 2023 - Can you tell me the age of a dryer from the model or serial # Kenmore 600. Model is 110 78652700 serial is - Answered by a verified ...
1 answer · Top answer: Good afternoon. My name is ***** ***** I'll be assisting you with your appliance today. Please ...
I have a Kenmore 70 series Washing machine top load model 110 serial number 82870120 . where is the lint trap located and how to take out to clean? clothes have a lot of lint after being washed.
It is likely that a tissue or paper product was included with the wash load. The series 70 does not have a lint trap. At the hose connection to the house drain lint has been known to build up restricting the emptying. This buildup would not introduce lint into the washer.
If the water temperature is very very cold and you use powder detergent it will not dissolve completely into the water and will leave a white residue on the fabrics.
Try running a short load in the washer allowing for ample water to rinse out the machine before the next wash load.
1helpful
Model # 110 20702 991 Serial # CK 5008937 Type 111 Can hear motor running and makes a slight noise also drains but won't engage in washer spin
Hello, Thank You for using FixYa. I will be helping you today.Sounds like a failed motor coupler part number 285753. It connects the motor to the trans. You can lean the unit back to change this part. Remove the pump remove the motor and you will see it.
Kenmore washer
most likely you have a sock or, some cloth obstructing the pump.
you will have to bail out the water then: remove the Sears 700 series 4screws holding the washer's control panel and, remove the washer side clips under the panel to remove the washer's sides then remove the 8 pump screws to remove the pump face and, remove the obstruction. the
exploded drawings can be found at: http://beta.searspartsdirect.com/partsdirect/index.action
1helpful
Need age of my washer machine
Kenmore elite model number 22054100 serial number CL210158. How old is this washer?
Washer pump capability?
This may or may not help.
If you can find the actual model number 110.########
Go to the following site:
http://www.managemyhome.com/
and click on the Manuals tab.
Sears has manuals for most of their products and some of the Washer manuals (installation) have sections on drain hose extensions and lengths.
31helpful
2answers
What is the date of manufacturing based on the serial number of my Kenmore 70 series washer?
Tyler,
It came off of the Clyde, OH production line the 26'th week of 2001.
Amazing, ain't it? Seriously... the info is embedded in the serial number. Here's the link to the code sheet.
Please remember to rate this solution as "FixYa", OK?
SG
Signal
Kenmore 70 series. Model/Stock 66702692 Serial MG2402832
Cycle Signal works but then won't shut off until I open up the dryer door - it just keeps buzzing for hours. Also the dryer will turn on if I close the door ( and arrow is within a number and not on off) without pressing the start button. So if door is closed - the dryer will run or buzz (depending on arrow). How do I fix this?
Thank you
84helpful
8answers
Kenmore Washing Machine 70 series
You most likely have a broken coupler between the motor and gearcase.
You can buy the part for about $10 or have someone come out and replace it for about $150-200.
If you will post the complete model number from the the washer so I can see which style cabinet you have, I will try to walk you through the repair. It isn't very complicated if you are handy with home repairs.
With the age of the machine it probably just needs a coupler, but it could also have a problem in the transmission or basket drive that has caused the failure.
Top Washing Machines Experts
john h
