Question about HP LaserJet 2420 Printer
HP LaserJet 2420 PCL 6
"illegalmaediasource" printed on every second page
  • mattlindsay Aug 21, 2008
    On Microsoft Word
    Prodigy:
    An expert who has answered 500 questions.
    Sergeant:
  • 564 Answers
In what program?
Posted on Aug 19, 2008
I have a printer HP Laserjet 2420dn pcl 6 on network which prints empty page on every second page can you give me solution to this problem
Why don't you delete the printer and go out to www.hp.com/#support and download the latest drivers.
Try the PCL5, less problems. and reinstall the printer.
Feb 03, 2011 | HP LaserJet 2420 Printer
My hp color laserjet cp2025 has the pcl xl error subsystem: Kernel error: Illelgaloperatorsequence operator beginpage position: 14 What can I do to fix this?
A Hewlett-Packard LaserJet printing language, PCL 6 is optimized for printing from graphical user interfaces (GUIs) like Microsoft Windows.
The Enhanced PCL XL, or PCL 6, driver that is included with the HP LaserJet printers provides enhanced WYSIWYG and enhanced performance with application support over the Standard (PCL5e) driver. PCL XL is a new page description language by HP, that is part of PCL 6 and is closer to GDI, which many applications use. Less translation takes place by the driver, which means increased WYSIWYG capabilities, and better performance with applications that support escapes implemented by the Enhanced driver.
While printing using the PCL 6 driver it is possible to encounter a PCL XL error. This error will print out at the LaserJet device, and will look like something similar to the following:
PCL XL error
Subsystem: KERNEL
Error: IllegalOperatorSequence
Operator: EndSession
Position: 15
These type of errors can be PCL interpreter errors, firmware related, tied to communication, driver, driver dependency, and application specific. Additional troubleshooting will be required to further isolate to root cause.
Troubleshooting:
I. Verify printer functionality
To verify printer functionality, perform the following:
1.Power the printer Off.
2.Disconnect the parallel, USB, or network cable.
3.Power the printer On.
4.Once the printer display reports Ready, verify device functionality by printing a Configuration Page from the device.
Note: should the internal printer test not print as expected, and/or a PCL XL error occur, you have then isolated the issue to the printer device, and any network connectivity or driver / application troubleshooting can be ruled out.
II. Verify communication w/ the device
To verify communication with the device, perform the following:
2.Reconnect any communication device cable previously removed
4.Once the printer display reports Ready, perform the following:
a.From the client machine or print server that had previously encountered the PCL XL error open the Printers and Faxes folder.
b.Right click the PCL 6 driver in question and select Properties.
c.From the General Tab select Print Test Page
d.Verify the driver test page successfully printed
Should the test page successfully print, continue with the next troubleshooting section entitled Isolate user, application and/or file.
Should the PCL XL error manifest itself as a result of the driver test page, perform the following:
1.At the print server, or client machine, open the Printers and Faxes folder
2.Click on Add Printer
3.Go through the Window’s driver install process installing the appropriate PCL 6 driver for the device in question, with the following characteristics: printing directly to the device (IP_Address, USB, Parallel, etc), creating a new print queue, selecting to Replace Existing Driver.
4.If the issue persists see section entitled: Microsoft Unidrv driver dependencies.
Note: If using an HP LaserJet PCL 6 device specific driver (discrete), try installing the latest HP Universal Print Driver PCL 6. Available at the hp.com website under support & drivers. Select product cb534a and also select your operating system, download a universal print driver Post Script would be the best selection.
You can also adjust a few settings under printing preferences:
under the advanced tab:
Raster compression:
Set it to max
III. Isolate user, application and/or file
If in fact the printers internal test pages and driver test page have printed successfully, further fault isolation must be performed to correlate the PCL XL error with a specific user, application, and or file. This information is most often easily gathered by speaking with the customer, investigating which user is printing when the PCL XL error manifests itself. Once the user is identified, the application the client was printing from can be isolated, and quite possibly the application file itself.
If an application file consistently causes a PCL XL error when sent to the device, it could be a problem only with the file.
IV. Microsoft Unidrv driver dependencies
The issue was identified to be related to Microsoft unicore files: unidrv.dll, unires.dll, and unidrvui.dll, that were not compatible with the available PCL 6 drivers at that time. Microsoft has developed a hotfix to address the symptomatic PCL XL errors – the Microsoft Hotfix can be reviewed here:
Microsoft Windows 2003 and XP: http://support.microsoft.com/kb/948046/en-us
Microsoft Windows 2008 and Vista: http://support.microsoft.com/kb/948349/en-us
Microsoft Windows 2000: NA
HP LaserJet – PCL XL Error
If anything else let me know,
Al
eliteprintersolutions@gmail.com
May 27, 2010 | HP Laserjet Cp2025n Printer
PCL XL error in hp laserjet 3055
information about the cause:
PCL XL error pages that print from an HP LaserJet 1200, 1300, 2200, 2300, 3200 or 3300 series product when a PCL 6 printer driver is in use typically indicate a communication issue. Sometimes this issue is caused by an incompatibility between the Enhanced XL language and the software application.
You can find the solution for this error here:
(It's a long instruction page, I advise to copy the sections that refere to your OS to a separate document, so you don't miss any step)
URL to HP service page:
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&taskId=110&prodSeriesId=1161389&prodTypeId=18972&prodSeriesId=1161389&objectID=bpl10637
Aug 29, 2009 | HP LaserJet 3055 All-In-One Printer
PCL XL error
Please uninstall the current PCL driver and upgrade the same with UPD PCL5 (dont install PCL6) from http://www.hp.com/go/upd
Regards,
Nikhil
Dec 16, 2008 | HP LaserJet 1320n Printer
HP 2420 keep printer wrong characters
This could be due to corrupt file or print job irrespective to file. This can also be an issue with the network sending packets or print spooler.
However, i would suggest to upgrade the driver to UPD (universal printing driver) PCL6
http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?locale=en_US&pnameOID=412129&taskId=135&prodTypeId=18972&prodSeriesId=416419&lang=en&cc=us
Please let me know the next update.
- Nikhil
Nov 17, 2008 | HP LaserJet 2420 Printer
Hp color LaserJet 4650
I had a similar problem with the PCL driver. I fixed it by installing the "HP Universal Printing PS" driver instead.
Sep 10, 2008 | HP LaserJet 4600 Printer
HP LaserJet 2420 Printing trouble
I think that Odyssey user is right it maybe that the print driver is not compatible with the program you are using goto hp.com or hp.co.uk and download the PCL 5e driver
Hope this helps you
Thanks J
Jan 03, 2008 | HP LaserJet 2420 Printer
Printing only 1/2 the page
print a demo page(which is in the menu)if it comes out ok,it's either the drivers or possibly the formatter board.if demo is not of,it could be the cartridge.i could help you better if i know which half(right to left or top to bottom)
Sep 19, 2007 | HP LaserJet 2420 Printer
HP LaserJet 2420 Printer Logo
Ben Johnson
