Question about NetGear MR814 Wireless Router
Network key trying to find above help
    Problem Solver:
  • 18 Answers
Locate the re-set button on the router, if memory serves, its on the back and may need a pin to fully depress it. This wipes out any passwords stored on the router and web interface
Posted on Aug 19, 2008
Acer how to setup
Hello. This may help. Your Wireless Network name and SSID are one in the same. Lot's of people will customize there wireless network name (SSID) like "smithfamily". However, if it wasn.t customized the default SSID should be used. This can be found on the sticker on your modem. Now then, as you know, when you try to connect to your network you are prompted to provide a network Key or PASSPHRASE. The same applies here as above, if it was customized then the Key or PASSPHRASE will be different then the default Key or Passphrase found on your router.--So when it say's you have a "badphrase", your Key or PASSPHRASE is incorrect.. Good Luck
Feb 10, 2014 | Computers & Internet
Wireless not working on Dell D610, installed drivers, enabled in bios able to use FN F2 key show icon but no lites above keyboard
it might be diasbled. try windows key + "x", if this doesn't work when you turn it on there, try going to network connections and enable the wireless. Go to control panel, select network and sharing, change adapter settings, you'd have something like wireless network connection, right click and click enable if its disabled.
Mar 16, 2011 | Dell Latitude D610 Notebook
How can i activate wifi in my ACER 7720Z????
there is usualy a switch on the side it may be by a amber light antenna
Mar 01, 2011 | Acer Aspire 7720-4428 Notebook PC
How do I reset my network key/wep key? I recently
I believe you have formatted only your PC but your WEP/WPA settings remain the same or you can set it so.
First step is to check if you have wireless network up and running.
Click on the link below to download and install the Network Detector.
Download Link
If this tool does not detect your network ( not your neighbours ) then most likely you need to re-setup the entire network ( router ) settings. This is done once you call the ISP ( Internet Service Provider )
If the above tool detects your network, you can open the router configuration page and reset the WEP Key
Regards,
Ron
* Please rate this solution with Thumbs up and Testimony to help us improve providing support
Dec 20, 2010 | Linksys Wireless-G WRT54G Router
Trying to get wireless
there are some options that might help u: 1. check to see whether wireless adapter is on; 2. if wireless adapter is on, check on drivers whether wireless driver is installed (check in device manager in control panel); 3. check your network connection, check the connection is "disabled". If yes, right-click to enable it. 4. if the above is not your issues, then try this: right-click the wireless network connection to check the available wireless networks, select one of the network, type WEP key and connect it straight away.
Nov 20, 2010 | Computers & Internet
Can't Turn On WiFi
Hi Theresa
Try this.
Acer (General) - FN+F5
Aspire 1000/1640Z/1690/2012 - Launch Keys above the keyboard
Aspire 16xx (General) the satellite-like launch button above the keyboard
Aspire 2000 Series (less Aspire 2012, See Above) - Button on the Front of the Laptop
Aspire 3005 on the lower right-hand side of your laptop
Aspire 3500 -
Aspire
5612 sliding button on the side of the laptop
Aspire 9302 the blue button on the left-hand side of the laptop
Aspire 94xx (General) the key found below the Lock key
Aspire One, in the lower right corner of the palm rest is a small strip with a picture of an antenna on it. An LED to the right of the strip lights to indicate the wireless is turned on.
Aspire One Series ZG5 -
Extensa
2000/2500 Series - Far Right launch button above the keyboard
Ferrari 3000/3020/3400/4000 - Button on Front of Laptop
Travelmate C Series - Far Left hot key and then choose WLAN from menu that appears
If this will still not turn the switch on, try to go to the network connection / network and sharing center. right click on wirless network connection and click diagnose,
then it will prompt you to turn on the switch. Just click on "turn switch on" then windows will ne the one who will on the wireless switch.
Sep 17, 2010 | Acer Computers & Internet
Wep key will not store...
Hi, This is a prominent issue with SP1 on XP.Either upgrade it to SP2 or above or use NETGEAR Utility to connect to the network instead of windows one.
To download SP2 visit microsoft website and for NETGEAR UTILIY follow the steps below:
1. Double click on WN111 icon from the right hand extreme bottom corner of the screen, near the system clock, in the system tray.
2. Click on networks tab.
3. Click on the SCAN button - This will show a listing of all available networks.
4. Select the network you wish to connect to and click on the "CONNECT" button.
5. This will automatically take you back to the settings tab.
6. If you are using WEP security then Enter the WEP KEY under the option 'Enter Key manually' under the settings Tab.
7. Apply Settings .
8. This should get you connected to your selected network.
9. Click on the 'About' tab and check the IP address.
10. If you are getting an IP address in the format of 192.168.x.x, try to go online.
11. If you are not getting an IP or the IP is in the format of 169.254.x.x, restart the computer and then try to go online.
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. If you cannot rate this post with the highest rating, then please comment to this post and I will try to help you further.
Regards
Anand
Jul 21, 2009 | NetGear WN111 (DHWN111100NAS) Pre-802.11n...
Problem connecting wirelessly using netgear router MR814v2
Hi, you should consider changing your security to WPA-PSK or WPA2-PSK encryption instead of WEP as WEP can be cracked in a matter of minutes, even 128bit keys can be cracked easily. Plus there's no confusion over the four WEP keys generated.
With WPA you choose the key so it can be a word instead of random key, making it easier to remember. Just make sure its not a simple word that can be guessed, and use random numbers or characters so something like 64ranDomWordz92. Its case sensitive too so chucking in capitals makes it even harder to guess. Don't forget to write it down in case you forget it, make sure you write it correctly.
Now you know which key your using, go to manage wireless networks on your laptop and delete any profile you have for your network. Now when you try to connect, it will ask for your WPA / WPA2 passkey, just type it in and hit enter, you should now be connected.
Let me know if you need help with any of the above.
Jan 21, 2009 | NetGear DG834G Router
Help..
Follow these steps to check for problems on the machine you cannot access.
1) Open the registry editor on the machine you cannot connect to by clicking on Start, Run
2) Type REGEDIT and press Enter
3) Click on the plus signs (+) next to the following entries
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Services
Lanmanserver
Parameters
4) In the right-hand portion of the Registry Editor look for a key called IRPStackSize
5) If the key exists, double-click on it and increase the decimal value to 15 and click OK. Close the Registry Editor, reboot the computer and try to connect to the network share. If you are still unable to connect follow the above steps again and increase the decimal number for IRPStackSize by 5 and try again. Continue to do this until the stack size is large enough to permit access. Personally, I had to increase the number to 25 before I could connect. The decimal range for the parameter is between 11 and 50.
6) If the IRPStackSize key DOES NOT exist in the right-hand column of the registry editor, then click on right-click in the blank area in the right-hand column and choose New
7) Then Click on D-Word under the Key column
8) In the Name of the new key, type the name IRPStackSize and press Enter. Type the name with the correct capitalization as shown above.
9) Now double-click on the IRPStackSize key and type 15 in the value data box and place a dot next to Decimal then click Ok.
10) Close the registry editor and reboot the computer. Try to access the network share again. If the same error appears follow the steps above to increase the value and reboot again. Continue this procedure until the problem is resolved. The decimal range for the parameter is between 11 and 50.
Oct 18, 2008 | Computers & Internet
Psp internet connection
common is there anything you can do to fix it
Jul 28, 2008 | Sony PlayStation Portable (PSP) Console
NetGear MR814 Wireless Router Logo
74 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
