On an HP 3050, a vertical line appears on the left side of the scanned document when using the software proviced with the machine. How can this line be eliminated?
  • fixya1945 Aug 19, 2008
    It worked! As the HP 3050 is not a flatbed the "glass" is a clear plastic strip about 1/2" long and 8 1/2" wide. It can be accessed by tilting up the control panel. Using a flashlight to find the speck and eyeglasses cleaning cloth to clean it I was able to remove a buildup of dirt a bit smaller than the head of a pin.
    Thanks to fixya and to aosman for the tip.
  • 134 Answers
Try cleaning the glass strip to the left of the larger piece of glass. A tiny spec of dirt will cause a long vertical line when scanned through the feeder.
Posted on Aug 19, 2008
How to get rid of vertical lines in scanned documents in bizhub 200?
Open the top cover of the machine and clean the small glass on the left hand side. Good luck.
Dec 27, 2012 | Konica Minolta bizhub 200 Printer
Black verical line appear when documents are scanned from the feeder. How do I get rid of the vertical lines?
Clean the glass on the extreme left side of the printer. Lift up the feed tray and clean the vertical glass. You probably have some debris on it, such as white out or some other stuff.
Mar 05, 2011 | HP Officejet 5610 All-In-One InkJet...
When I scan there is a vertical line on the left side of the page on all the docs. 8.5 x 11 HP Laserjet 3050
You have white out or something on the glass. The top of the machine will open up about 30 degrees. Look at the glass and you should see something on it. clean it.
Jan 06, 2010 | HP LaserJet 3050 All-In-One Printer
Vertical line appears on the faxed page sent to
This sounds like a dirty scanning glass in the adf feeder. clean the glass with a soft cloth. if this doesn't solve the problem, there might be dirty optics under the scanning glass.
Aug 03, 2009 | HP LaserJet 3050 All-In-One Printer
Line down the scanned document on a HP LAser Jet 3050
If you are scanning using the Auto Document Feeder be sure to clean the glass where the documents get scanned. A small speck will cause a line down the page. On HP there is often a narrow strip of glass on the left side of the platen glass.
Apr 10, 2009 | Brother IntelliFAX 4100 Laser Fax
HP 3050 - vertical black lines
You say that the scanner glass is clean, but it takes next to nothing to cause these lines. Couldn't hurt to chack again (if you havent cleaned it 6 times already).....anyway, I found this document that is not specifically for your machine, but the menu commands should be the same:
Recalibrate the product scanner:
  1. Press ENTER/MENU on the control panel of the product.
  2. Press the < arrow key once to display Service and press the ENTER/MENU button.
  3. Use the < and > keys to select Scan Correction and press the ENTER/MENU button.
  4. Insert a blank, bright white piece of letter (8.5 x 11 inches or 216 x 279 mm) or A4 (8.3 x 11.7 inches or 210 x 297 mm) paper into the document feeder tray.
Good Luck, and please rate the response :)
Mar 20, 2009 | HP LaserJet 3050 All-In-One Printer
Solid Line on left Margin after Copy/Scan
When I Copy or Scan with my HP LaserJet 3050, a solid black line appears on the left margin of the page. . Can you suggest any solution to the problem. .
Oct 29, 2008 | HP LaserJet 3050 All-In-One Printer
I purchased a HP LaserJet 3050
The instruction to use scanner in HP Laserjet 3050
Click Start, click All Programs or Programs, and then click HP. Click HP LaserJet
3050/3052/3055/3090 all-in-one, and then click Scan.
Click Setup.
Select Change the destinations that show up on the all-in-one control panel when I press
the Scan To button, and click Next.
Select Allow me to scan by pressing the Scan To button on the all-in-one....
Move the destinations from the PC window to the All-in-one window.
Click Update. See the online User Guide for complete information
Source : Manual for HP Laserjet 3050
Thanks for using Fixya
SAM ANDERSON
Sep 11, 2008 | HP LaserJet 3050 All-In-One Printer
Vertical lines in scanned documents
Scan glass has muck on it, needs to be perfectly clear, it is just in where you feed originals.
Nov 21, 2007 | HP LaserJet 3050 All-In-One Printer
jasbo
jasbo
