Question about Mitsubishi WD-52525 52" Rear Projection HDTV
Mitsubishi WD-62825 Green Blinking light and TV won't turn on
  • 2 more comments
  • Anonymous Dec 25, 2008
    same exact problem....getting annoyed
  • fatfender Dec 26, 2008
    Blinking green light, no picture, no response from the TV
  • NORVELL_M66 Jan 23, 2009
    TV WAS WORKING FINE UNTILL I PRESSED THE SYSTEM RESET BUTTON THEN THE TIMER LIGHT WONT STOP BLINKING
  • Nancy Jan 28, 2009
    Have the same problem, but somehow it does go away and the TV seems to work. My problem now is the picture will go to snow (seems to have snow that is red/blue and possibly black), then picture goes black and goes back and forth between snow and black screen. When I turn off the TV and turn it back on it seems to bring the picture back. A month ago I called service and they changed the chassis. I did not think we would have this same problem again. Anyone have an idea of what the problem is. The TV has 1 month more in its warranty. I have a quadriplegic son that watches the tv about 10 hours a day so the TV is very important to him. Can anyone help?
I have the same problem with the green light blinking and the T.V will not come on. I have reset it and unplugged it and everything and still nothing. Can anyone help me
Posted on Sep 29, 2008
  • 179 Answers
You could try changing the twelve 1000uf/16vdc caps. four on each of the power supply, FMT, and DM boards. this may take care of it.
most likely though the chassis needs to be rebuilt. check out www.tv-texhs.com
Posted on Dec 26, 2008
Mitsubishi LT 52144 blinking blue light i have pressed buttons for this probem before and it came on i can not renember which ones
Posted on Sep 04, 2012
4 Suggested Answers
premtech
  • 934 Answers
SOURCE: mitsubishi wd-62825 dlp
The WD62825 has a Digital Module located on the left side of the chassis looking at it from the rear of the set. It's housed in a metal box that can slide out of its holder after removing the trim screws.
The module has its own power supply board and there are a group of 16v/1000uf caps on that board which commonly fail causing the constant flashing standby light. Further back on the module is a small board about the size of a matchbook called the E2P module. Its SMT (Surface Mount Technology) caps also commonly fail which can cause the same symptoms. Techs can tell whether the E2P has failed by simply removing it, hooking the DM back up and trying to power the set. If it powers on the picture won't be much good - but at least you can tell what's keeping it down...
Back to the caps on the pwr board. If they've failed they usually will buldge visibly on top. And ESR is almost not necessary. In any event that's the nuts and bolts on this model.
Is it a job for a layman? Yes and no - you might strongly consider a tech if you don't feel comfortable removing all the connections that the DM has with the signal board. There are about six - multi-pin - wired connections to unplug and then sliding the DM out of the unit and carefully removing the screws and latching to take the DM top cover off...
Hope this helps.
Bill
Posted on Nov 10, 2007
  • 184 Answers
If the green front panel LED blinks continuously and the TV never comes on, its an issue with the "DM" board. When these TVs are first plugged in, the green LED should blink for 30 sec. to a minute or so. This is the TV booting up, reading its software. Mitsubishi has been having problems with this circuit for several years. In may cases the only permanent solution is to have the chassis rebuilt by Mitsubishi at considerable cost and inconvience. The chassis may have to be sent back to Mits for this rebuild. Call Mits and ask for help.
michtech
Posted on Feb 14, 2009
walesarumi
  • 6993 Answers
SOURCE: Blinking green light will not
this problem is either a power problem or bad projection lamp problem;
How long have you been using this TV and have you ever changed the lamp?
This problem also has a symptom of a bad or dying projection lamp and sometimes the ballast board. The ballast board helps to ignite the projection lamp.
So, you might need to replace the projection lamp and if possible, ballast board.
Again, the constant blinking light also be caused by failed capacitors on the DM power board. Check the below link, you will find the service or repair manual for your TV.
Also, to order for a repair kit to fix DM board problems, visit; http://www.tvrepairworld.com/mitsubishi_repair_kits
Check the above two discussed as one certainly has to be the cause of the problem.
Good luck..
Posted on Mar 11, 2011
Wd-62825 takes a few seconds to turn on
the lamp may be showing its age or number of hours of use---typical on this set from cold turn on is up to 15 seconds.
Oct 29, 2012 | Mitsubishi WD-62825 62" Rear Projection...
No response from the TV when turned on. Slight hum but no green light flashing....
power supply or mainboard deffective..go to your nearest mitsubishi srvice center
Sep 07, 2010 | Mitsubishi WD-62825 62" Rear Projection...
Blinking green light on Mitsubishi will not turn off
The capacitors on the DM board need replacement, thats a common problem it will work fine but if power is loss even for a minute the capacitor drain, then they cant recharge since they need replacement so the set will just keep blinking the timer light. Installing the V26 DM repair kit from www.tvrepairworld.com will usually repair that. The kit contains the Replacement caps and the CD with detailed instructions.
Dec 25, 2009 | Mitsubishi WD-62825 62" Rear Projection...
Mitsubishi wd-62825 dlp
michtech
Feb 13, 2009 | Mitsubishi WD-62725 62" Rear Projection...
Mitsubishi Diamond blinking green light of death
try going to tvrepairworld.com located in NC. Inquire about their dm26 kit with cd!
Nov 14, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Green timer light
check the number of blinks each blink means something
Apr 19, 2008 | Mitsubishi WD-62825 62" Rear Projection...
Hope this helps.
Bill
Oct 29, 2007 | Mitsubishi WD-62825 62" Rear Projection...
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
558 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
