Cyberhome CH-LDV 700B Portable DVD Player Logo
Posted on Jun 10, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The cable that connect the screen to the board is broken. Where do I get a replacement parts.
Kenneth Lee Sr.
Level 3:
  • Master 597 Answers
  • Posted on Jun 10, 2011
Kenneth Lee Sr.
Master
Level 3:
Answers
597
Questions
10
Helped
82918
Points
1207
Try Sears parts dept.
Connection cable screw broken in side tv
the main board will need replacement as the cable input is an integral part of the main board. You can get the main board from www.tvcircuitboards.com
Replaced screen but no right color
Hi ,Im interested to have more information of your problem.Whats your first problem, (2) Is there any action you did to try to solve the problem, (3) if yes what is now the results.
But from my experience ,there are two main causes for missing/unstable colour.(1) The screen itself might get broken , and the only way to solve this is ,by replacing the LCD screen.
(2)Another cause is a broken cable ,or poor connection .the solution is to replace the LVDS cable (or data cable from main-board to srceen).
Hope this solves your problem.
10helpful
2answers
My dvc NV-GS25 lcd screen is not working
Common problem with this model, flat cable that connects lcd assembly to the main board is broken, replacement part comes as hinge assembly witch includes cable and the hinge.
Broken screen
Hey how are you!!!
You replaced the broken LCD screen in your laptop with a new screen. Does this sound like your problem? Let’s find out what could be wrong and how you can fix it.
First of all, I assume that your new LCD screen is compatible with the old one. Different screens require different video cables. Make sure you new screen is compatible with your laptop.
OK, let’s say you accidentally damaged the LCD screen in your laptop. A part of the screen still works fine but you cannot use it like that so you decided to replace the screen yourself.
Her is some instructions to follow.
Before you start to panic, check all cable connections again. Check connection between the video cable, LCD screen and inverter board. Reconnect cables just in case.
screen-not-working-3.jpg Take a closer look at the connection between the video cable and LCD screen. It’s possible you accidentally pulled the video cable from the connector during the screen installation.
screen-not-working-4.jpg The video cable has to be seated properly, all the way down.
screen-not-working-5.jpg Also, on some older LCD screens there are very thin pins inside the connector. Take a look inside the connector, make sure there are no damaged (bent) pins.
You can straighten bent pins with a very small screwdriver but this procedure requires a lot of patience and concentration.
Fortunately, most newer LCDs have a different type of connector, without fragile pins inside.
screen-not-working-6.jpg OK, you have reseated all connectors and cannot see anything wrong but the new screen still is not working. What’s next?
Remove the new screen and connect the old one. If the old one works properly (except the damaged area) but the new one is dead, apparently the new screen is defective and has to be replaced.
Hopefully it has warranty.
Here’s another scenario. The new screen kinda works. You can see a very faint image but there is no backlight.
If that’s the case, disconnect the new screen from the inverter board and plug in the old screen instead, as it shown on the picture below. If the backlight inside the old screen lights up, apparently the new screen has defective backlight lamp and has to be replaced.
Good luck
ICmanServer
2answers
TV input on the back of the unit broke cant connect coaxial cable
Try entering the model number on website below, they do worldwide delivery, and have one of the biggest database of replacements.
Appliance parts, electronics parts & more from PartStore.com
6answers
Broken horizontal stripes except for 6" band
The most common reason is a faulty lower buffer board. Also faults to Sustain boards and cables can cause the same problem on a plasma.
2answers
Ariel socket in tv has broken
The best thing is to replace the signal board, that costs $24.
Check here for the part : Polaroid Replacement TV Parts
You find the part on Ebay here.
Part number is 200-013-JK371-1AH FLM-323B
Broken cable connection inside board
No need to buy a PC board. Have professional tech solder leads back and tighten connector
Cable monitor removal
Hi there, removing the cable monitor has a diferent models and brand. some cable just screwing it by your hand both end. and some are connected built in to the screen, if you have this kind of model, you may need some tools and replacement cable for this. simple remove the screw of the monitor at each corner at the back of the screen and see if there is other screw at the back or bottom. then you can pull up the cover the screen and pick up the cable which is connected usally at the small board behind the picture tube which is the CRT Board. then replace the cable with the new one. TY
Top Cyberhome Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ExpressFiX
ExpressFiX
Are you a Cyberhome Televison and Video Expert? Answer questions, earn points and help others
