Question about Microsoft Wireless Notebook Optical Mouse VSBX300001
Not working the lights are all on the power is in good but still it doesn't work though it says the hardware are working properly but i think the receiver doesn't received any signal from the wireless mouse
  • Anonymous Aug 19, 2008
    mouse not responding lights are on
    Genius:
  • 1,011 Answers
Dear,
The small notch in usb device socket under the mouse could be malfunctioning. If you press this notch you will find the mouse red light blink. If you further try pressing this notch at some point the mouse red light comes on constantly. Thats it, hold it there and try to connect first by pressing the usb device connect switch and then the mouse connect switch. The moment the connection is made the usb device stops blinking and the red light on the mouse starts blinking. Wow, it works now. Some one might just open the mouse and fix this microswtich for a permanent solution.
regards,
dont forget to rate it
Posted on Oct 28, 2008
2005 GMC Savana. Rail lights don't work properly.
Check any ground wire you can find. They may have gotten corroded and no longer grounding properly.
also I would check both fuse boxes and make sure there aren't any blown fuses.
May 10, 2013 | Cars & Trucks
Why isn't the green light on? and shy doesn't the cam work though it has before?
1st You download Webcam Driver.
After this install the Webcam driver in the system.
Installation of Webcam Driver
Go to the control panel
Click on the System Icon
Click on the Hardware Tab
Click on the Device Manager s
Select the Unknown Device or printer device where yellow Question Marks sign on it.
Right click on it and uninstall it.
After this go to the top of the device manager and click on scan for hardware changes.
Driver installation Wizard start.
Brows Your Driver from the Hard Disk and click on next.
Driver will be install.
Mar 30, 2012 | Microsoft LifeCam VX-1000 WIN-Blk Webcam
Radio, dome light and door open warning bell doesn't work
try changing fuses any way somtimes there dirty or coroted and dont make good contact even though they test good and look good still could be the problem
Mar 02, 2012 | 1997 Dodge Neon
Hp 2133 screen is blank when you turn on the power button and only the power button light works
I had the same thing with an MSI notebook. This is most likely a hardware issue and can only be fixed permanently by replacing the motherboard.
For me one trick worked though... when turning it on, instead of pressing once, press the power button rapidly multiple times. I've been using my notebook like this for half a year now, its quite tricky, doesn't always work, but cheaper than a new mobo.
Aug 08, 2011 | HP 2133 Notebook PC
My murray 20 inch push cuts off after about 15 minutes...I let it set about 5 minutes then it will start back and go through the same thing again...
Try my Tip out on this subject. Even though the Tip is not written on a mower, the same concept will apply:
www.fixya.com/support/r6081786-trimmer_weed_eater_only_runs_10_15
If you try this Tip, and it doesn't work, then you have a bad Ignition Coil (Module). If they start to go bad, when they get hot, they stop working. Then when they cool down, they will work again. But I think you will find that the gas cap is not venting properly.
Good Luck!
Jim
Aug 08, 2011 | Garden
Car wont start, doesn't even turn over. battery is good though, boost does not work. think it might be the starter?
Its a good bet. Be sure the battery connections are good too.. Flip on the headlights and then try to start it.. have someone watch the lights.. If they go dark. You have a bad battery or bad connection. If the lights stay bright then you need to look at starter connections/starter/starter solenoid.
May 05, 2011 | 1993 Nissan NX
Please where can I find intel vga drivers for acer power F2 using windows 7.
As of this moment, there are no drivers for that hardware available for Win7.
http://support.amd.com/us/gpudownload/Pages/index.aspx
This is where you would find it, if it were available. I'm sure there is a way to get it working though. The only thing I can think of is try running the setup for that specific hardware (Xabre200 32MB, ATI Radeon 9200), and if it doesn't work, try running it in xp mode. To run it in xp mode, right click the setup.exe file, go to properties, then go to the compatibility tab, and select XP SP3 from the drop down menu.
Hope this helps!
Aug 20, 2010 | AcerPower F2 PC Desktop
Hi MY Dell OptiPlex GX620 have a hardware
try the bios settings is your monitor in a grafics card slot
also see if plug and play is enabled only use a keybard and mouse with a ps2 conection not usb
Nov 24, 2009 | Dell OptiPlex GX620n PC Desktop
2 of 4 USB Ports Not Functioning
Most likely a motherboard problem, though you can try and re-do windows, best bet on getting it all to work is Turn off CPU, Unplug Power cable, And all usb devices, let it sit for about 20mins. Plug it all back in. Turn on the CPU! Though this might really get on your nerves having to do this multiple times, id get a new motherboard.
Dec 26, 2008 | Gateway 4540GZ Notebook
Display works - but only for a plit second...
Lower your resolution on your computer. Usually when that happens the resolution is set higher than what the monitor can support. Lower the resolution and try again.
Jul 25, 2007 | Dell E173FP 17" LCD Monitor
Microsoft Wireless Notebook Optical Mouse VSBX300001 Logo
227 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
