Question about Lexmark X1150 All-In-One InkJet Printer
Has enough ink but won't print legibly or dark enough
Nnnnnvery hazy and light nnnnnnnnnnnnnnnnnnnn
  • Anonymous Aug 20, 2008
    the printer is producing a two color elegible printed page. Faded,distorted.,unreadable. Dont no which way to go to correct.
    Prodigy:
    An expert who has answered 500 questions.
    Sergeant:
  • 564 Answers
Try a clean and alignment procedure.
Posted on Aug 19, 2008
I replaced the black ink and the error light is on and the out of black ink light is still on. Won't print
Try it.......
Remove the print head and soak it for three 5-minute cycles in hot (~170 F) distilled water about 3/4 inch deep with continuous mild agitation. The first soak quickly turn the water black, the second end with the water a dark grey color. The hot distilled water dissolved the dried ink in the small ink passages from the cartridges to the ink ejection part of the print head.
Carefully dry the print head as per instructions, clean the electrical contacts on the printer, and placed the print head and the ink cartridges in the printer.Turn off the printer, then unplugged it for one minute.Then turn it on...and print an alignment sheet...
If you need any technical help on printer then you can reach at http://www.vtechsquad.com/
Nov 20, 2012 | Dell 1320c Laser Printer
My printer is printing dark black at first then the bottom of the page is light black. I have tried shaking the ink cartridge and I don't believe it is old enough to be out already. I just replaced it a...
The amount of time is not a factor, it depends on how much printing you have done. If you have printed a lot of photos the ink get used very very quickly.
The way to improve the print quality is to use the maintenance option to clean the print heads, but it sounds like low ink.
Jan 19, 2011 | HP Photosmart C3100
The striker appears not to strike the Daisy wheel letters firm enough to produce a dark and clear letter. Many times the result is a letter not fully printed and it appears to be lighter along the left...
Please check the ink ribbon. There are two types of ribbons. The plastic one can be used once and if you try it the second time then there is no guarantee that all letters will appear fine and legible. (as may be happening in your case). The other is the cloth ribbon. This can be reused and it keeps fading as you keep repeating it. But in this case all letters are faded and nor selective.
Nov 22, 2010 | Lexmark Wheelwriter 1000 Typewriter
Print quality: dark faded, but continuous
Open top cover and remove toner, shake toner cartridge and try a test print. IF image good then problem is low toner level in cartridge.
Apr 01, 2010 | HP LaserJet 4 plus Printer
Printer not printing dark enough
go to the print settings select the dark scale
u can get print darker than the previous
May 27, 2009 | Samsung CLX 3160fn All-In-One Printer
Printer will not print clearly
im sure you have heard this put are you sure you have the right driver, Or your printer cartridge could be dispersing too much ink at one time try replacing them.....
Driver Download
Apr 26, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Not dark enough
If you use a refilled cartridge all print quality problems should go back to the supplier of the ink.
Lexmark does not now and never has authorized refilled cartridges on their products for this exact reason.
Lexmark cannot guarantee the quality of the ink.
Apr 17, 2009 | Lexmark X5150 All-In-One InkJet Printer
Light in color and won't copy dark. It come out light purple
you may try
1) color ink cartridge--- no enough ink or the cartridge ink channel dryer and constipated, refill ink and put down the cartridge bottom surface to water a little for 1 hr, then set back. or change a new cartridge if not fixed go next
2) print head--- the ink channel dryer and constipated, take out print head clean it's ink channel using cleaner or steep in water (do not touch circuit pin area with water) 20 minutes or longer. then set back and test (you can do more times), still not fixed, your print head have to change.
Feb 06, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
Samsung digital cam vp-d351
First try to take photo in a sunlight, if the photo is still hazy then clean the lense and make sure you dont put your finter anywhere in front of the camera.
If the photo is still hazy then it could in internal camera fault.
If the photo is fine in the sun but its blurry in the dark then take photo with flash if thats ok then you just need more lighting.
Also make sure the ISO Rating is auto or 100 many people set ISO to 800 and then forget about it. It causes hazy photos in the dark
Nov 02, 2007 | Fuji FinePix F401 Digital Camera
Lexmark X1150 All-In-One InkJet Printer Logo
74 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
