Adjusting the Ringer, Earpiece and Speaker Volume
Adjusting the Ringer Volume
You can choose from four ringer volume settings (off, low, medium, and high) separately on each handset or the base.
With the phone in standby, press or on the handset or VOLUME or VOLUME on the base. The handset or base sounds the ringer at that level.
Use on the handset or VOLUME on the base to make the ringer volume louder. Use on the handset or VOLUME on the base to make it softer or turn it completely off.
When you hear the ringer volume level you want to use, stop pressing keys.
The handset or base will use the new ringer volume starting with the next incoming call.
Note: If you set the ringer volume to Off, the handset or base won't ring. Other handsets or base will ring according
to their individual settings.
Muting the Ringer (One call only)
While the phone is ringing, press /Mute or END on the handset or on the base to mute the ringer
Hi
You can turn off the ringer completely so it no longer makes an audible sound when the phone receives an incoming call. The phone's ringer options can be accessed in the handset's menu.
Press the "Menu" button on the phone.
Press the up or down arrows until the phone's display says "Ringer Volume."
Press the "Select" button on the phone.
Press the up or down arrows until the phone's display says "OFF."
Press the "Select" button to save your settings.
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
The only button on the base is the find button. Please, anymore suggestions?
