Question about Emporio Armani Chronograph Ar0657 () Watch for Men
I have an Emporo Armani Chronograph. It stopped working about 1 year ago. everyone I have taken it to has told me that there is no battery and that I cannot fix the watch. The watch looks like brand new, unfortunately I cannot use it because it does not work. Cann you help me? Aj3
  • Emporio Armani Master
  • 8,539 Answers
Since you had it looked at by professionals, the next obvious thing is to try to sell it on eBay or other method, advising that it is non-working but is otherwise looking like brand new.
Posted on Mar 08, 2018
How do I reset emporio armani ar5950 chronograph to zero after replacing the battery.?
pull crown out to second position ,then press bottom button till it goes to zero then push crown back in job done,,if you want to do both dials press and hold bottom button so they rotate faster to zero then press one press at a time...
Nov 21, 2014 | Emporio Armani Mens AR5950 Brown...
How to set up the chronograph needle
acabo de adquirir un reloj armani AR0431 segui las instrucciones ajuste fecha y hora, pero no trabaja..que pasa a caso no bienen de fabrica con la bateria instalada? o cual podria ser el problema?
Sep 11, 2012 | Giorgio Armani Emporio Armani AR0584 AA...
Dear Sir/ Madam, My wrists watch stopped working/moving abruptly some day ago. I have had this wrist watch since 3 years and have never had any problems. I was wondering what the problem? I know it...
yes, this watch uses battery, you had to replace it with a new one. you had to bring it to watch service center because they have what you need for your watch. i hope I solved your problem.
Jul 23, 2011 | Festina Chronograph 16162/1 watch
The second hand will not re-set to zero. It has stopped. The watch works perfectly during the day apart from the second hand not moving, but , the watch stops at 11.15 at night. When I get up in the...
This is a symptom of what is usually several possible issues:
1) The most common is that the battery must be changed. Insist on Energizer batteries only (as they do not leak) and visit your local Certified Master Horologist for assistance in changing the battery and resetting the watch.
2) The movement must be serviced every 3-5 years by a qualified professional. Dust and debris can cause the symptom of stopping and starting the movement. If you have owned it for less time than this, remember that the watch may have been manufactured and in the retail location longer than this period of time before it was purchased.
3) The movement is defective or damaged. If the watch is under warranty, and it was purchased through an authorized dealer, Armani will take care of this issue for you at no charge.
To properly assess this issue, I recommend taking the first step, as a CMH also has the proper tools to test the movement and battery to determine the best next course of action.
watchandpen
Feb 25, 2011 | Giorgio Armani Emporio Armani watches...
CHRONOGRAPH AND CENTER STOP SECOND DONT WORK PROPERLY
This may be due to a poor battery connection, a low battery, a dry movement, or debris in the movement. I strongly recommend taking it to a local Certified Master Horologist for assessment and repair. Estimates are usually free.
Jan 12, 2011 | Giorgio Armani Emporio Armani AR0584 AA...
WIND UP MY ARMANI AR0203
Try puting it off and wind it then.
Dec 31, 2009 | Giorgio Armani Emporio Armani AR0203...
Emporio Armani AR0534, How do you reset the Chronograph function of this watch?
If it is not working you may need to "AC" the watch. This generally needs to be done when the battery is replaced. This will reset the circuit board and allow the watch to work correctly. There maybe instructions on the inside of the back lid to do this but i always recommend having a watch maker/technician doing it because of the delicate nature of the circuit board.
If the sweep arm is not resetting to the 0 position then you can set by....
pull the crown out to the first or second set position then press and hold down the start button until the sweep arm is in the position you want.
Sep 11, 2009 | Giorgio Armani Emporio Armani Classic...
Emporio Armani Chronograph Ar0657 () Watch for Men Logo
251 people viewed this question
Top Emporio Armani Watches Experts
Andrew Taylor
Andrew Taylor
Tom Chichester
Are you an Emporio Armani Watch Expert? Answer questions, earn points and help others
