I have a kenwood KA-94 home stereo intergrated power amp in which the output ICS on one side short out.Last time the ICS were replaced, it ran for an hour but shorted again! Any thoughts on the problem??
Unit may have any one of several problems: defective or shorted speaker(s), -- ICs work within certain circuit paremeters; B+&B- voltages from power supply also provide voltage to secondary drivers and biasing circuits. Any shorts and/or transistor leakage may cause failure under load. The entire circuit should have been tested before use
Posted on Aug 19, 2008
What is the wattage output of the kenwood ka 728 integrated amp?
Specifications Power output: 130 watts per channel into 8? (stereo)
Frequency response: 20Hz to 20kHz
Total harmonic distortion: 0.007%
Input sensitivity: 0.2mV (MC), 2.5mV (MM), 150mV (line)
Signal to noise ratio: 69dB (MC), 87dB (MM), 107dB (line)
Output: 150mV (line)
Dimensions: 340 x 109 x 369mm
Weight: 9.2kg
Year: 1984
Kenwood KA 828 Manual Stereo Integrated Amplifier HiFi Engine
Nov 15, 2016 | Kenwood Audio Players & Recorders
Kenwood ka 996 integrated amp. The standby light will dont turn off. I also need to see if someone will tell how everything should be hooked up.
the standby light should be on if the unit is not 'ON' if you want the 894 to turn on when you power up the 996, then you will have to plug the ac for the 894 into the 'switched' ac outlet on the back of the 996
what specific problems do you have with this system
Mar 07, 2013 | Audio Players & Recorders
Dead Kenwood Home stereo Amp. KA-2002
Some says it is only dead when it is buried.
Open it up and check, ( Be sure it is unplugged)
Only if you feel you can DIY or have a tech do it for you.
Oct 06, 2012 | Kenwood Vintage Model Ka-6006 Stereo...
Don't know how to hook up kenwood ka-994
Check the bellow link for the user manual of kenwood KA-994. In page number 4 of the user manual You can see how to make the connections to the receiver
Manual
Ajin
Mar 09, 2012 | Audio Players & Recorders
Describe your kenwood manual "ka
Hi, Yes it is safe to leave this connection unhooked. The system control is what the stereo uses to remote control a cassette deck,cd,turntable etc... using the amplifier separately should be o.k. I hope this helps, good luck and thanks for choosing FixYa-Prodzilla
Apr 20, 2011 | Audio Players & Recorders
Amps ? stereo intergrated amps ?
Since the mixer has a line level output, yes you can use a home stereo for the "AMP". Use the AUX IN, TAPE IN or CD IN on the stereo and connect the speakers as you normally would.
Dan
Feb 26, 2010 | Behringer DJx700 5-Channel Pro DJ Mixer...
I HAVE A OLDER KENWOOD STACK HOME STEREO SYSTEM WITH OUT MANUALS OR REMOTES AND NEED TO KNOW HOW TO HOOK ALL THE COMPONENTS TOGETHER. KC-206 STEREO CONTROL AMP KT-76 TUNER KX-96W CASSETTE DECK KM-106...
start with the tuner, hook up the equalizer to the tuner, then on the rear of the equilizer hook up all the peripherals except the amps which will go to the tuner outputs and all will feed thru the tuner to the amps and out to the speakers
Oct 23, 2009 | Audio Players & Recorders
Ka 94 amp no sound from lft spkr jacks
Sounds like the wiring connection is either loose or fried. You can take the back panel off and check to see if their loose, if they are you just need to resodder them on, otherwise, they need to be replaced.
Aug 26, 2009 | Kenwood Audio Players & Recorders
Kenwood KA-880D Amp keeps blowing the 6v 250w fuse
please check the VDR in primary supply side.its directly connect to bouth N&Live wire connections of supply.
nuwan.
Jan 11, 2009 | Kenwood CT 401 Hi-Fi Stereo Dual Cassette...
Open Questions:
972 people viewed this question
 Grubhead
Grubhead
