Question about Panasonic DMR-EH57 HDD Recorder Player
HELP-where is the One Touch Recorder button
I cannot find a quick way to tape for say an hour like a OTR button, all I can find is the record button, no good to stop if I am not here or go through the long process of setting up.
I am frustrated with this model, I hate the fact that it won't record with a disc in it......I know, I know it will stop overwriting BUT very annnnoyyying.
Hope you can help with one of my frustrations of this OTR.
Many thanks for any help Kind regards J I have the same probelm. When i try one-touch recording it just starts to record. There is no table or action for setting a period to record.
According to the manual I should be able to set the recording time length in steps.
  • johnlynne Aug 24, 2008
    I have read the advice but does not add anything to a solution. The advise is a quote from the manual, I have the manual and this does not work. IE There is nowhere to specify the length of the recording. The machine just starts to record when I re
    press the record button. Noting else happens with repeated presses, and stops when I press the stop button. Is this a machine fault.
  • 157 Answers
Yes it is a machine fault.
You will need to upgrade the firmware
Send it to the authorised service centre and they will upgrade the firmware for you for free
Cheers
Posted on Aug 24, 2008
  • 4,234 Answers
I don't know this exact model, but other Panasonic models have similar functions. Usually the OTR option allows you to start recording easily and is not designed to have any other options associated with it. To set timed recordings, there is a sequence of steps required. The OTR is for recording when you are present. I will confirm this with Panasonic and update this.
Dan
Posted on Aug 19, 2008
  • ABRsvcs Aug 19, 2008
    I could not find your specific model (EH57), but did find the model EH75 which had the following sequence for performing the task you wish. It aas taken from the user's manual. I hope this helps,
    Dan
    During recording
    Press [
    ¥, REC] to select the recording time.
    ≥You can also press [¥, REC] on the main unit.
    ≥You can specify up to 4 hours later.
    ≥The unit display changes as shown below.
    Counter (Cancel) # OFF 0:30 # OFF 1:00 # OFF 1:30
    ^------- OFF 4:00 ! OFF 3:00 ! OFF 2:00 !----------}
    ≥This does not work during scheduled recordings (l 32) or while
    using Flexible Recording (l 30).
    ≥If you change the channel or recording mode while recording is
    paused, the time specified to stop recording is canceled. (Except
    [VHS])
    To cancel
    Press [¥, REC] several times until the counter appears.
    ≥The time to stop recording is canceled; however, recording
    continues.
    To stop recording partway
    Press [∫, STOP].
This morning while trying to copy from vhs to dvd I kept getting an on screen message OTR Pause....record. What is OTR as the tape did not copy this is model DRC832ON
OTR is one-touch recording on most of my VCR/DVD burners where you set the length of time to record from the tv. In my manual it is the Express Record feature. Press the REC button several times to advance the record time by 30 minutes. In your case it might refer to On Timed Record.
Use the COPY button on the front of the unit when the tape you want to record is in the VCR and a blank DVD is in the DVD tray. If you have the A/B Edits set, only the A/B editted sections will copy. (Copy protected tapes and DVDs can't be copied.) (Or the timed transfer described below)
Copying DVDs to VCR tapes can be done in a timed record mode. You can either use Menu > Disc > Copy Disc then press OK or Menu > Timers > Set Transfer and press OK. Then press Info to name the timed event followed by Done and OK, if desired. Press OK to highlight Copy From/To and make sure to select the correct source and destination and press OK. Next set the day and time that you want the transfer to take place (a couple of steps, press OK between them and when done). Then adjust the quality if needed and press OK. Finally highlight Keep Timer and press OK again. Make sure the correct tape and DVD are in place for the timed event.
Depending on what you set the unit for, I'd look for signs of power failures (which mess up most timed record functions). Then I'd double-check the time you set it to transfer and the A/B edits function. (A/B edits lets you grab small clips from an Indexed tape. Either index the tape by playing it and pressing the Insert A/B edit button (on the VCR/DVD, possibly on the remote) or delete A/B edits.)
I hope this helps.
Jul 23, 2010 | RCA DRC8300N DVD Recorder/VCR
I pushed the otr button by mistake and now I can not stop it from recording or turn off the vcr.
OTR stands for one touch record, each press of the button will increase the recording time. However if you keep pressing the button it should go back to "0" and stop!
Feb 22, 2010 | Emerson EWV603 VHS VCR
VCR ejecting my cassettes
Try removing the top cover & have a look to see what happens when you put the tape in & press play/rewind etc. Is the take up spool (right hand spool) turning properly or is there slack tape not being taken into the cassette? Are the heads spinning ? I think your problem is more likely to do with the tape not travelling smoothly around the tape path. Possibly the clutch gears need cleaned or the soft brakes may not be dis-engaging properly.
Jul 19, 2009 | Televison & Video
EVERYTHING YOU NEED IS IN MY LETTER BELOW.
1. On your remote, find the record mode button; it is near the bottom on the left side. This button sets
the recording speed for the DVR. Faster recording speeds provide higher quality recordings.
2. Look at the display on the front of the machine: it should say XP ( records 1 hour on the disc,)
SP ( 2 hours, ) LP ( 4 hours, ) or EP ( 6 hours. ) You can also set it to record 8 hours on a disc,
but the quality of the recording will be poor.
3 Press the record mode button until the screen displays the recording speed that you want.
4 Note: if the powers fails or the Machine is unplugged, the machine will automatically reset itself to
SP mode.
Apr 29, 2009 | Panasonic DMR-ES40V DVD-Video Recorder
Timer recording, more than 1 show
I have no solution how to fix it. My idea is . Use the One-touch timer Recording (OTR) on page 27.
If your manual is the same as mine. My VCR recorder is broken.
Aug 29, 2008 | Televison & Video
The One Touch Recording only works from pressing the RECORD button on the main unit NOT on the remote control.
Hope this helps.
Jun 26, 2008 | Panasonic DMR-EH57 HDD Recorder Player
Dubbing from vcr to vcr
Connect with RCA cable to RCA jacks\plugs::
output [player] audio to INPUT [recorder]
OUTPUT [player] Video to INPUT [recorder]
Place blank tape in RECORDER, Tape that you want to record from into PLAYER.Press Record [recorder machine], wait one second, press PAUSE.( thats to give record tape "breathing" space.) Set up your player tape to start playing. When you know what you want to record, press PAUSE again to begining recording. Press PAUSE after the recorded section to install 2nd tape, etc. etc.
NOTE:: some VCRs use PAUSE 2nd time to release and continue recording, while some machines you must press RECORD button again to release PAUSE. you must expirement before begining your project.
May 24, 2008 | Zenith VCS442 VHS VCR
Quits after an hour
when you start the recording have a quick check to make sure it is taping on the eight hour setting and not HQ
Sep 08, 2007 | Panasonic DMR-ES10 DVD Recorder
DV-PC recorder
DV-PC Recorder is a Windows XP only application that enables you to record images and sound on the tape in the camcorder and on the computer's hard disk by connecting a camcorder equipped with the DV CONTROL function to a computer using an IEEE1394 (DV) cable. DV-PC Recorder has the following features. 1. You can record movies simultaneously on your computer's hard disk and on the tape by pressing the start/stop button on the camcorder. 2. It enables long, continuous recordings, which you cannot achieve with the tape alone. (Approximately four and a half hour's worth of recording will fit on a 60GB hard disk.) 3. You can start editing the movies on the computer right after recording, as the images and sound are saved on the computer's hard disk. (Optional editing software is required to edit movies) 4. You can record movies on the tape in the camcorder and on the computer's hard disk by controlling the DV-PC Recorder from your computer.
Sep 04, 2005 | Canon XL2 Mini DV Digital Camcorder
Panasonic DMR-EH57 HDD Recorder Player Logo
55 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
