Question about Frigidaire PLEF398AC Electric Kitchen Range
Oven won't turn on and left rear burner dosen't work
Used oven to bake cookies, went to use it to cook dinner 30 minutes later and oven won't heat up and left rear burner dosen't turn on. You can set the temperature and it clicks like it is turning the oven on, but no heat. The left rear just dosen't come on either.
  • 4 more comments
  • darlene3 Aug 22, 2008
    I did assume it was the element for the not baking issue, however the left rear burner went out at the exact same time that the oven stopped working. Are these two things controlled by the same element???????
    see above addition to the question
    still wondering why the left rear burner does not work and went out the same time the oven did?????????????????????????????????????????????????????????????????????????????????????????????
  • darlene3 Aug 26, 2008
    the manual says it is a ES100 control with ceramic cooktop, what you are describing does not match what it looks like when the back or panel is removed. the front gives a p/n 316417025
    it is a ceramic cooktop, there are only elements showing in the oven
    MODEL NUMBER FEF336ECE
    SERIAL NUMBER VF64171524
  • 1,879 Answers
>check for fuse / wires broken, disconnected or damaged. use proper tools for probing - don't assume that when the controls make a sound everything should be working (the knobs won't heat up the oven)
control ---//---(wire)---//--- logic board ---//---(wire) ---//--- heating element
Posted on Aug 26, 2008
    Genius:
  • 1,447 Answers
Hi-
Check the back for fuses, if it has try replacing it. check wirings if pinched or curled or loose as well
Hope this helps
  • 2,071 Answers
  • LORETO LACARON
    LORETO LACARON Sep 01, 2008
    Did the solutions from all of us experts solved your problem if
    not then let us know the current updates so all the fixya experts can
    assist you further.
    Genius:
  • 1,269 Answers
Burners need to be cleaned using sand paper or steel brush.
Maybe there are too much carbon present on the contacts. Get your owners manual and check there how to clean the burners.
Courtesy of repairclinic.com
If one of your burner heating elements works only intermittently, it's probably because of worn or bad contacts in the receptacle that the element plugs into. On most electric ranges, you can remove the element by lifting it up several inches and firmly pulling it away from its attachment (receptacle). Read your owner's manual to learn the correct technique for your range.
If, after removing the element, you see that the ends of the element that were plugged in are pitted, corroded, burned, scarred, or rusted, replace both the element and the receptacle.
Posted on Aug 22, 2008
    Master:
  • 848 Answers
Try this there are two resetable thermostats in this particular oven, the first is located on the rear of the unit behind the panel ( if standing behind unit its in the upper left hand side of unit. 2 wires leading to the thermostat and a small "button" to press to reset it. if it doesnt work after resetting that one then the second one located under the control panel behind the second burner knob from the right.. to acess this panel you will need to remove the burner knobs::: then loosen and remove the plastic hold down under the knobs, the contriol panel will lift off then and then remove the four screws holding the clock assy in position, when thats lifted out of the way( no need to disconnect)you see hte same resettable thermostat moundted on the unit right behind that second switch, simply reach in and reset it
  • 435 Answers
When the food you're baking is done on top but not on the bottom--or when baking just takes far too long to finish--the bake element may be burned out.
You may get fooled into thinking it's working, because the oven is hot inside. But many electric ovens use the broil element, too, during the preheat and bake cycles. So the food may be getting heated only by the broil element, which causes poor baking results.
If the bake element is burned out, replacing it should solve the problem. Otherwise, you need to further troubleshoot the oven's electrical system to locate the defective wire or component.
When the temperature is consistent but too high or too low, it could be one of several different things. First check to see if the thermostat sensing bulb has come loose from its holder. It could be lying on the floor of the oven or resting on the heating element. This would cause the oven to not heat correctly.
If the thermostat bulb is not dislodged, it's likely that the thermostat or sensor is either mis-calibrated or defective.
Electronic ovens with a digital display use a sensor to monitor oven temperature. To solve temperature problems for these models, you may need to replace the sensor. On some digital-display models, you can calibrate the temperature using the key pad. See your operator's manual for details.
Ovens without a digital display often use a mechanical system for controlling temperature. On many of these units, you can remove the thermostat knob and adjust the knob itself to more accurately represent the actual setting of the thermostat.
If, when you remove the knob, there's a screw on the back of it with a small calibration plate, you can loosen the screw, adjust the plate, then tighten the screw again. If the knob isn't adjustable, and the oven temperature is off by more than 30 to 40 degrees, you need to replace the thermostat to solve the problem.
    Genius:
  • 1,011 Answers
Dear, Pros: the wheels on the bottom make it easy to pull out to clean and unplug
Cons: if you leave something to simmer temp will go up without turning the dial
This stove as has been problems from time of purchase.
The right front burner will just stay on even after the knob is turned off I have to pull it out and unplug the range very disappointed with frigidaire no response to my problem. If I leave the range on low to simmer when I come back it is at a full boil without touching the knob
  • 3 more comments
  • SALMAN NASEER Aug 22, 2008
    dear, Pros: the wheels on the bottom make it easy to pull out to clean and unplug
    if it doesnt work then check it by changing the setting to low heating or high..
    check if either it slightly heating up in either settings
    there are some possible interlocking with them.
    has u confirmed this situation many times
  • SALMAN NASEER Aug 23, 2008
    did you get the solution to cure it.
    regards,
    Genius:
  • 1,011 Answers
Dear sir/madam,
click this link for repairing your oven by yourself......
http://www.repairclinic.com/0088_13_1.asp
thanks
good luck
    Genius:
  • 3,422 Answers
HI,
It won't bake Usually, when an oven won't bake, it's because the bake element is burned out. The bake element is the black, pencil- thick tube at the bottom of the oven. When the oven heats, the element glows red. This element has an expected life-span of several years. It may last for only one; it may last for many more. When the element burns out, you need to replace it.
It bakes poorly Here are two instances of when food "bakes poorly:"
  • When the food you're baking is done on top but not on the bottom--or when baking just takes far too long to finish--the bake element may be burned out.
  • You may get fooled into thinking it's working, because the oven is hot inside. But many electric ovens use the broil element, too, during the preheat and bake cycles. So the food may be getting heated only by the broil element, which causes poor baking results.
  • When the temperature is consistent but too high or too low, it could be one of several different things. First check to see if the thermostat sensing bulb has come loose from its holder. It could be lying on the floor of the oven or resting on the heating element. This would cause the oven to not heat correctly.
  • If the thermostat bulb is not dislodged, it's likely that the thermostat or sensor is either mis-calibrated or defective.
6ya staff
SOURCE:
Maytag Range won't heat up oven or cook top
you have melted internal wiring, probably some mice ate it. call an electrician and DO NOT USE IT!! turn off at the wall/fusebox
Nov 20, 2013 | Maytag MER8770WS 30" Freestanding Electric...
Oven takes forever to preheat
The way the oven works is like so:
1) User sets the desired temperature
2) Power is sent to the ignitor
3) The ignitor is then energized, drawing 3.2 amps of current
4) When the 3.2 amps is drawn, the gas safety valve is allowed to open and gas flows into the burner assembly in the oven.
5) This gas is then ignited, causing the oven to heat.
6) As the oven heats up, the oven sensor, which is the metal rod located at the top on the rear oven wall, converts the heat into an electrical signal, relaying this information to the main control which in turns displaying the temperature.
(In models with a dial thermostat, there won't be a sensor, though a metal wire with a bulbous end will be present, which is actually connected to the thermostat.)
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Jun 21, 2012 | GE Kitchen Ranges
Was cooking dinner, and in the middle of dinner, I walked away and heard a popping sound. I checked the oven and it stopped working. My husband turned the breaker off and back on and the stove top works...
It sounds like the bake or broil element went bad and they will make a popping sound. Usually it is visible on the element that it is bad. You may have to measure the element. It should measure 8-30 ohms if good. If there is no visual sign and you are unable to measure elements keep oven off until a repairman comes. Please rate me after reading this.
Dec 13, 2009 | Kitchen Ranges
Whirlpool oven door won't open.
You can try unplugging the over for a while and seeing if that helps. But if that doesn't help you will have to let the oven complete the cleaning cycle in order to regain use.
Jun 23, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Amana gas range bake burner does not heat
Pull the bottom of the oven off. You will see 2 to 4 screws that hold the panel on. The ignitor is under there. Look at the ignitor carefully for breaks. I say carefully as the ignitor is very easy to break.
Feb 03, 2008 | Ovens
Burners Blew
if you will send me your model number off your serial plate on your range will be on front open oven door or lower drawer some where and when you bought it i need to check the service bulletins before i reply but dont rate me till were done
Jan 02, 2008 | KitchenAid KESC300 Electric Kitchen Range
Oven burners won't shut off
Bat, your model number is right on accurate. Here's the scoop... the F3-E2 means the temp sensor inside the oven cavity needs replacing, but I doubt that your problem is the sensor. The problem is your "microcomputer". I call it an ERC for short. There are 3 separate circuits on your ERC; low voltage for your keypad, medium voltage for the mechanical relays and high voltage for you elements. When you program a cook time/temperature, the ERC translates this into medium voltage and activates the proper relay on the ERC (i.e... "bake", "bake w/ convection", etc...) to send high voltage to the proper component. All of that to say this, the relay on the board that activates the bake element is "welded" shut. When powered off, the relay won't open up! This will result in run-away temps. I've seen this before on Whirlpools. The ERC will have to be replaced, the part number is #8302994 and lists for ~$180.00 at your local appliance parts store. If you need assistance with the replacement procedure, post back. If you decide to get in there without posting back, DISCONNECT POWER AT THE BREAKER PRIOR TO ANY SERVICE.
Aug 14, 2007 | Whirlpool RBS245PDS Electric Single Oven
Frigidaire PLEF398AC Electric Kitchen Range Logo
469 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Ismael Rodriguez...
Paul Carew
Marvin
Marvin
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
