Question about Panasonic Cameras
Panasonic dvcam cassette door fails to open - Panasonic Cameras
  • 149 Answers
May be jammed. pres open button and try to pry it at the same time.
Posted on Aug 19, 2008
How do you insert a video 8 cassette into the vhs cassette adaptor.
There's no way! They are two vastly different systems.
Video8 tape is nearly 1/4 inch wide whereas VHS tape is 1/2 inch wide - and thats just the begining!
Electronically, everything about them is different which is why Video8 came out from Sony in 1985 to improve on VHS systems and camcorder quality.
The higher quality version Hi8 followed in 1990 which made it's way into the professional market too.
I used the both formats for TV news and other programmes 1989-2000 when I went over to DVCAM, a professional compact cassette system also from Sony so I know the 8mm systems inside out.
Nov 20, 2010 | Panasonic PV-P1 VHS-C CASSETTE ADAPTOR
Panasonic m7 vhs video camera while in play mode camera stopped and made whiring noise then shuts right down will not eject how do you get tape door open manually
Hi, open eject door,try to see very small lever at the left side cassette at lower end and try to pull it at your side with very thin and at least 4 inch long screw driver.Cassette compartment will open. But its not so easy to find.It need patience.
Aug 10, 2010 | Video Cameras
Sony 570 dvcam error message 91-143 can you help
Microcomputer and its periphery device error
1: CASSETTE IN
4: Capstan motor/capstan FG
2: Detected speed error
It looks like a bad capstan motor.
Dec 15, 2009 | Sony Dvcam DSR-390P DV Digital Camcorder
Aj-d200 video camera, cassette door stuck partially open. best diagnosis and/or remedy?
Partially open sounds like a mechanical problem with the cassette housing/door assembly. The door usually stays fully open or will not open at all, caused by component failure on the mechanical driver board. Check to make sure nothing is stuck in the mechanism, like a label or a broken piece from a cassette. If the door will move, but will not latch closed, the problem is most likely on th emechanical driver board.
Mar 25, 2009 | Panasonic AJ-D200 Camcorder
8mm Cassette mechanism fails to eject or sometimes fails to close
This camcorder is at least six years old now, and replacements are available quite cheaply vie on-line auction sites, probably at far less than the cost of repair.
Apr 05, 2017 | Sharp Viewcam VL-AH60U Hi-8 Analog...
Fix Dew Detect for Panasonic 700X
Dew has condensed in the camera. Eject the cassette but leave the cassette door open.remove the battery . Borrow a hair drier . set it to optimum temperature(not vey hot but but hot enough to cause discomfort when blown on fingers). direct the hot air through the cassette compartment door for about five minutes. reattach the battery and reinsert the tape.
Good Luck,
Luwangula
May 15, 2008 | Panasonic PV-GS300 Mini DV Digital...
No power
Use a credit card (or similar stiff-like plastic material) and gently work it in the slot between the camera body (you will have to remove the battery pack) near the cassette door.
By gently working the corner of the card around near the upper area, and with some pressure, it should pop open.
Good luck,
~app
Jan 30, 2007 | Panasonic PV-L750 Camcorder
Cameras Logo
19 people viewed this question
Top Panasonic Cameras Experts
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
