I cant get my reode to change chanels
Are you using the controls on the CR248 or on the remote? If you are using the remote, try the controls on the radio. Press the Function button (top left on the radio) to get into the tuner moder. Then use the Band button (second button from the left in the second row of buttons) to select AM/FM. Then use the Tuning Up (fast forward) or Tuning Down (fast reverse) to run through the frequencies. These buttons are to the right of the Record button in the line with the Power button (on the right). Note: you need to connect the FM radio antenna and position it to receive stations. The AM antenna is internal and the position of the radio will change whether you can get the signal. To program stations, press Program and then use the Preset Up/Preset Down to select a memory area in which to store the frequency. Then press Program to save. Then you can use the Next/Previous buttons to go through the preset channels. The manual is here:http://crosleyradiostereosystem.danielca... . I hope this helps. Cindy Wells
Insert a blank CD-R or CD-RW into the unit. Press the Function button on the remote (key above Vol+ on the bottom right of the remote) or the turntable itself (top left of the control panel) until the unit is in Phono mode. Then insert the pre-recorded cassette and press Play to advance the tape to where you wish to start recording. With the cassette playing, press the CD Record button (recording will flash on the display). The CD Record button is to the left of the fast reverse button on the unit; it is labeled Record on the remote and is below the Stop button. When one side of the cassette finishes playing, press Stop. Wait for the display to return to Phono. Then eject and turn over the cassette to play side 2 (if you want to record both sides of the tape). Press Play again to advance the tape and then press Record. When this side finishes, press Stop and then Finalize. Finalize is at the bottom left of the remote buttons and to the left of the stand by indicator on the turntable.
The manual is available at Crosley: http://www.crosleyradio.com/Product.aspx?pid=1790 . The direct link to the manual is http://www.crosleyradio.com/Manuals/CR248_Manual.pdf . Recording a cassette to CD is on page 11 (page 12 of the pdf).
I hope this helps.
