Question about Singer 7462 Mechanical Sewing Machine
I have an Aldi Delta NM902-05 sewing machine which was stitching OK yesterday. Todya if it skipping a few stiches on the top sticth. My mum is the sewing whizz and she reckons it's the tension, however, it does not matter what number we change the tension to we are still getting some missed stitches. What do you suggest? Would cleaning it help? Thanks. Regards, Sarah.
  • Learnin2sew Feb 19, 2009
    How do you do this???
    Problem Solver:
  • 10 Answers
Sarah if the top tension is to tight it might slip stitches but as always when there is a problem with stitching you should change the needle and make sure it is in right.
Taking the needle plate of and cleaning with a fine brush around the bobbin and feeders will help and should be done regular.
Posted on Aug 19, 2008
  • cnrockit Nov 02, 2010
    Hi - we bought an Aldi machine too - Delta FY780. I bought it but it wasn't used for about 8 months. When I used it it did exactly the same as the original question here, and no amount of adjusting would stop it missing stitches, about 1 in 12. It was new with demonstration sample attached which was perfect of course. It totally clean and I'm assuming its a brand new needle - sharp and no rust. Have others had the same problem with Aldi Delta sewing machines and if so what did you do to fix the problem please?
  • jacqueinemar Jul 06, 2011
    mine did the same now my pedal pack up i have just used it for first time in 3 years since i brought it from Adi now out of warranty so get get a replacement does anynoe know were i can get a new pedal
My machine is skipping stiches it seems its not picking up from the bobbin
Install a brand new needle and confirm it is inserted with the flat side facing the proper direction.. A bent, damaged needle will sometimes cause skipped stitches or even needle strikes inside the machine. A new needle is the least expensive cure for a lot of sewing machine problems. The needle should be changed about every 8 hours of sewing or at least when starting a new project.
Remove the top thread. ALWAYS RAISE the presser foot and rethread from the beginning. Verify the thread path is correct.
Sometimes, skipped stitches will occur if the needle, thread, and fabric are incompatible. Be sure to use the correct needle for your project. Use a good quality thread--AVOID old or bargain bin thread!
If the machine continues to skip stitches, then it may be out of time. Search for sewing machine timing or take it for service.
Basic Maintenance Tension Skipped Stitches
What to Do If Your Sewing Machine Is Skipping Stitches
Don Ignore Your Sewing Machine Skipping Stitches Simple Solutions
May 24, 2017 | Sewing Machines
How to change stich to long stich for gathering? is the manual for your machine; look at p. 27. You want stitch 00, and then increase the stitch length with the up/down buttons on the control panel.
p. 24 of the pdf covers adjusting the top tension of the machine; you'll have an easier time of gathering if you reduce the top tension about 1-2 number setting.
May 29, 2014 | Singer 5400 Sew Mate 60-Stitch Sewing...
Thread tension will not adjust.
Check your setting, you have your stitches set too far apart. Wherever on your machine you see the zigzag stich you will see other stich settings, look at it until you see the right amount of stiches you want.
Mar 06, 2017 | Brother CE8080PRW Limited Edition Project...
When I am sewing it will sew about 3 stiches and then jam.. It does it if I change weight of material or it will s kip stiches.
Skipped stitches is usually indication that needle is blunt or burred.
Or if you are using a sharp needle on knit fabrics it may also skip a little.
Not sure what you mean by "change weight of material" - do you mean you are sewing applique and going from one fabric weight onto another? or different sewing projects?
It is a good idea to change your needle for each new project (4-6 hours sewing time max) and choose the right type of needle and size for your project.
However, the jamming part sounds more like thread tension issues, especially if the jamming is happening underneath from the bobbin. If stitching is loose underneath, then top tension is the problem and visa versa.
Recheck your threading path, top and bottom tensions and that you have good quality thread. Change the needle, rewind a fresh bobbin, thread up and try again.
There is really good info on or I refer to my Singer Sewing Machine textbook at lot too. Good luck.
Mar 30, 2011 | White Sewing Sewing Machines
Stitches are on the reverse of the fabric
hi! there,
set dial tension to #3 and stitch tension to #12 try on straight
sewing,check bobbins winder if thread was wind on clockwise rotation before sewing.if ok try to sew and observed the change.
have a nice day regards,dont forget to rate me
Apr 09, 2009 | Singer 7444 Mechanical Sewing Machine
Brother XL2230 Elastic Overlock function not working properly
First of all check your needle size and utility, for the tension machine it must be the same on top and bottom example pull the top thread and the lower thread they must be the same.
When sticthing the elastic you must devide the amount of elastic versus the fabric : dise the amount before stiching
Hope this will help
Good day
Feb 16, 2009 | Brother XL-2230 Mechanical Sewing Machine
Letters have skipped stiches in them
check a few things and report back if this doesn't solve the problem.   Needle:  Use a new needle appropriate for the weight of the fabric, most likely a size 11.
Stabilizer:  do you have support under the fabric such as Pellon or Stitch and Tear?  If the fabric is looped or piled, a thin layer of plastic such as a dry cleaning bag on top might help.
Thread:  Depending on your machine (check with the manufacturer) a stitch lubricant might help.  Is the thread flowing freely from the spool?  does it "catch" as it switches directions while unwinding from the spool?  If you are using a decorative thread such as sulky, you might want to reduce the thread tension.
Machine:  If you've had a needle hit there may be a burr on the machine, or the machine might be due for timing.
Jan 12, 2009 | Singer CE-200 Quantum Futura Computerized...
Skipped stitches and getting worse
It might be that you have the wrong needle/ thread combination for the fabric that you are using. sharps for wovens, ball point for knits. the heavier the fabric and the thicker the thread the larger needle you need to use.
Dec 29, 2007 | Janome 4623 Mechanical Sewing Machine
Singer 7462 Mechanical Sewing Machine Logo
911 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
