Question about Whirlpool Washing Machines
Whirlpool AWO/D 6507 (I think - at work currently) Fault details: Failed part was through a wash now has - Low mechanic buzzing sound when cycle started. Drum will turn by hand, but not by motor. Is not draining, not sure if it will if I leave it on though (only found problem last night and havent had a chance). I'm going to drain it and have a quick look inside tonight to confirm its not the belt etc - but any advise / assistance would be greatly appreciated! Many Thanks, LEwis
Fixed it!
drained (via filter) last night, took out the missus's hairclip which was jamming the pumps (which was stopping it from spinning and causing the buzzing noise) and all good!
saved a few pennies!!
Posted on Aug 20, 2008
Water not filing machine
Take the back of the washer off and find the pump and disconnect the hoses. Check the pump intake area. I had a sock stuck in my pump. Don't ask how a sock got there but that was the problems. Also check the screens in your hoses that supply the water to the washer.
Mar 27, 2013 | Whirlpool Washing Machines
Whirlpool awo 9663 wont start cycle
This can be due to failure of motor components or the control panel as there is no communication for the drive . Check the motor to panel wiring, check the panel for failed component
Jul 05, 2012 | Whirlpool Washing Machines
Whirlpool washing machine AWO/D 5556 washing machine service light showing ?
The warning light comes on because the machine "thinks" that something is wrong. Since it stops on and off something is wrong.
Why not phone the Whirlpool service in your area and tell him aboout this and ask what you can do??
give it a try
Kolbrun
Feb 22, 2012 | Whirlpool Washing Machines
AWO 3551 have a FP fault . help
thanks for your advice. I have an AWO 3551 Whirlpool front-loading washing machine. It works but I think it's highly likely that the filter needs a clean and is long overdue. I've opened the front plate and unscrewed the plastic cover but the filter doesn't come out at the same time. It seems pretty stuck and there is nothing to get a purchase on (unless I get pliers and turn counter clockwise - but slightly concerned that might break it...?) Any suggestions of how to make it 'come out to play'?!
Feb 21, 2012 | Whirlpool Washing Machines
Where can I find a user manual for Whirlpool AWO/D 6507 Washing Machine?
go on line click free washing machine manuals type in one of your options type in your make model you may find the one you are looking for free if not you will have to buy it
Nov 17, 2011 | Washing Machines
I have a whirlpool awo 3751 washing machine when i close the door set the program press the start button the machine appears to start and the time reduces but there is no water going to the machine i think...
You most probably have a faulty water inlet valve...Not an uncommon problem..They can sound ok, but when you check the detergent drawer there will only be a trickle..Replace the inlet valve...Good luck...Nomess
May 20, 2010 | Washing Machines
It fills with water, washes, then makes a buzzing sound.
This is a failed timer mechanism. replacing this failed mech will fix your issue.
Jun 19, 2009 | Whirlpool Washing Machines
Fault F07
F07 Motor control unit error The Central Control Unit has detected a short in the motor control unit. If a failure occurs during high-speed spin the door will be unlocked after 3 minutes.
Potential Causes
• Check wire harness connections between the Drive Motor and the Motor Control Unit (MCU), and between the MCU and the Central Control Unit (CCU)
• Check the MCU
• Check the Drive Motor
• Check the Wire Harness
Replace failed component.
May 20, 2009 | Whirlpool LHW0050PQ Front Load Washer
Fault codes f 13 Whirlpool Washing Machine AWO/D 5716
f13 is a Dispenser circuit error
If the dispenser motor is not able to be driven to it’s proper position.
Potential Causes
• Check mechanical linkage from dispenser motor to the top of the dispenser.
• Check Wire Harness connections to the dispenser motor and Central Control Unit (CCU)
• Check Dispenser Motor
Jan 29, 2009 | Washing Machines
Washing Machines Logo
202 people viewed this question
Dan Webster
Dan Webster
Mike Cairns
Mike Cairns
prem mathew
