Question about HP Pavilion dv6000z Notebook
Wont Recognize DVD drive
I have a brand new laptop and my problem is when you insert a cd/dvd nothing happens. Iv'e tried to update the driver and it says its already updated. When I click Computer under the start menu It doesnt even Show I have any other drives than my C drive. When I go to the Device Manager and right click the DVD drive, Go to Properties and Message in the box says Windows cannot load the device driver for this hardware. The driver may be currpt of missing. (code39). It says check for solutions and I click that but nothing happens! ??? I have exactly the same problem only I get a Code 19 error. I've taken all the steps recommended by Vista help directory.
  • 149 Answers
If its brand new go and get it checked by warranty.
Posted on Aug 19, 2008
I put a DVD R in the computer but it wont let me put anything on it. It is saying that there is no disk inserted
there might problem of your dvd drive not working,, or else can be happen some times that your dvd R is not able to read with your dvd drive..
also..
try cleaning the lens of your dvd drive...
Oct 04, 2009 | Lenovo 3000 V100 Notebook
My cd/dvd driver is not working on my hp notebook
Go to HP's support website, find your laptop, and get the missing driver, or find out what brand your cd/dvd drive is and go to the manufacturers website to get the driver. I hope this helps!
Jul 24, 2009 | HP Pavilion dv9000z Notebook
CD/DVD drive doesn't work
try removing the drive from the laptop, then go into the device menu and delete the drive. Restart. Shutdown again and insert the drive, restart - it should show a "new device" recognized. If it doesn't, the drive may just have failed. I've had it happen to a dell drive - it just doesn't see the drive at all.
Jun 05, 2009 | Dell Inspiron™ E1505 PC Notebook
Cd drive not recognizing cd's
nope it happens to me, if your laptop still under warrantee call toshiba and they will replace it to you. the problem is the lens not reading the cd, try to clean it by dvd cleaner if its not working replace it.
Mar 19, 2009 | Toshiba Satellite M115-S3094 Notebook
GMA 4082n device driver not working properly code 39
First go into Setup (usually F1,F2 or del) at start-up. See if your drives show up there. With Windows running, right click My Computer, left click Properties, left click Hardware, left click Device Manager, left click DVD/CD-ROM drives. Also check IDE ATA/ATAPI controllers. Do the drives show up there? If they do right click on drive and left click Update Driver. If they are not there go back to System Properties and left click on Add Hardware Wizard. This will search for devices. It may ask you to insert Windows CD which of course you can not do because the drives don't work. Try a different drive. When you cleaned out your computer did you delete or uninstall Office? That may be what caused this problem. None of this may work but it is a starting point.
Jan 06, 2009 | Dell Dimension 4600 PC Desktop
DVD player in Toshiba laptop won't work
First check that it is indeed a CD/DVD drive.
Also, you didn't say whether it was a video or data DVD. Assuming it's a video DVD, you'll need an mpeg2 decoder. (Something like WinDVD, PowerDVD, or Nero Showtime, or one of the many open source alternatives)
If neither video or data DVD's will work, you may need to update your driver for the drive, on the Toshiba website.
Nov 15, 2008 | Toshiba Satellite A135-S4527 Notebook
Hi, the error code that you have is a known issue from Microsoft that needs a registry tweaks. Error code means "Windows cannot load the device driver fro this hardware. The driver may be corrupted or missing (code39)".
To resolve this problem, remove the affected filter drivers. To do this, follow these steps:1. Click Start, type regedit in the Start Search box, and then click regedit in the Programs list.
If you are prompted for an administrator password or confirmation, type your password, or click Continue.
2. Locate, and then click the following registry subkey:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
Caution There can be many instances of the registry subkey that is mentioned in step 2. You must make sure that you are in the appropriate registry subkey before modifying the UpperFilters and the LowerFilters values. To verify that you are in the appropriate registry subkey, make sure that the Default data value is DVD/CD-ROM and the Class data value is CDROM.
3. In the right pane, right-click UpperFilters, and then click Delete.
4. Click Yes to confirm the removal of the UpperFilters registry entry.
5. In the right pane, right-click LowerFilters, and then click Delete.
6. Click Yes to confirm the removal of the LowerFilters registry entry.
7. Exit Registry Editor, and then restart the computer.
Apr 23, 2008 | HP Pavilion dv6000z Notebook
Annoying Problem with MD-16XDVD9A4
This is a now issue with XP when you install a DVD/CD-it doesn't always happen but when it does there is nothing that can be done about it-I went as high as tier 3 support at MS and tried regediting, mapping, even a complete reinstall-nothing helped-untill I bought a cheep CD RW and installed it as anotuerh dirve. Then I had a DVD RW, and a CD RW. Problem solved
Nov 05, 2007 | Mad Dog Multimedia (MD16XDVD9) DVD±RW...
Laptop trouble
see it is problem with your dvd drive try with dvd lens cleaner if still it is not working then show it to service personnel. bye
Sep 23, 2007 | Computers & Internet
HP Pavilion dv6000z Notebook Logo
53 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
