I have a 26" Sanyo
I have a 26" Sanyo TV. Its about 9 years old. As I was watching, the screen shrunk to a 1/4 line across the middle of the screen. What might this be and is it worth fixing?
  • 4,234 Answers
The vertical IC either has bad connections on it or hit has failed completely. These are common ICs and are available for about $12-$20. If you can solder, you should be able to repair this yourself. Open up the back and look for a small flat IC with about 11 pins attached to a heat sink. It will be marked LA7837 or something similar. Try resoldering the pins first. If that fails to resolve the problem, replace the IC. If you have any question about whether or not you have the correct part, post the marking here and I'll confirm the part.
Keep us posted.
Dan
Posted on Aug 19, 2008
Why does picture have lines of different colors?
Common easy LCD TV fix: bad picture screen rainbow colors
? 4:04
https://www.youtube.com/watch?v=KWIWeESmXC0
Aug 10, 2014 - Uploaded by Tampatec
Common easy lcd tv service repair fix, TV's distorted rainbowpicture screen fixed by ... Common easy LCD TV fix: bad picture screen rainbow colors ... Need to report the video? ... Sanyo LCD with Distorted Half Picture Lines Waves Distortion Distorted ...Duration: 11:36. by Do It With Dave 316,733 views.
LCD Display Symptoms and causes. - YouTube
? 2:01
https://www.youtube.com/watch?v=DedJvyNm_s4
Mar 1, 2011 - Uploaded by Grants Pass TV Repair
With LCD TVs you can have the same display problems fordifferent ... Fix for Samsung lcd TV colour display problem - Duration: 1:26. by alwaysafix 462,823 views. 1:26. Sanyo LCD with Distorted Half Picture Lines Waves Distortion ... HOW TO FIX LED TV VERTICAL LINES ON SCREEN 55" MODEL LG ...
How To Fix A Broken Flat Screen LCD LED TV With Lines or ...
Dec 11, 2015 | Sharp Televison & Video
Tv screen is black except for 1 horizontal line of color
The line is there because the vertical deflection unit - the one that spreads that line across the entire screen to form the image - has failed. Replacing it is a job for a professional, or at least an experienced amateur, and the parts will be quite difficult to find for such an old tv .
May 28, 2010 | Panasonic CT-36DV60 36" TV
Spiral line descending across screen
hoz. out of sny. look for cap 200/100v
Jul 18, 2009 | Sanyo DS27910 27" TV
I turn on the TV and there is only a line going across the middle of the TV. The sounds work the same but there is no picture. It seems as if the picture had shrunk to a very thin line that just goes...
this is commonly known as a frame colapse and could have two possable causes (1) no 28volts comming from the l.o.p.t.x or in english the line output transformer ,to the frame output i/c ,usualy caused by an inline fuse blowing this looks like a very small transistor but with only two legs or (2)the frame output i/c has packed up
Jun 12, 2009 | Emerson EWF2703 27" TV
My ilo tv picture is 1 1/2 inches. How can I fix this??
its a vertical problem could be bad cap or possible vertical i.c. okay take to tv shop is their still a warrany on this set sounds pretty new shad
May 14, 2009 | iLO IWT3206 TV
Tv picture is shrunk to the middle of the screen and turns off
if you mean line across middle no vertical deflection prob circuit prob. need tech.
Dec 13, 2008 | Zenith C27A24T 27" TV
Shrinking screen.
hi there, you do have a vertical section problem and at the power supply section problem. do some test, check for some cold solder at the power supply section, test some electrolytic capacitor at the vertical section. ty
Jan 01, 2008 | Televison & Video
Problem with tv
Its known as 'screen collapse' and yes it can be fixed but it may not be economical you should get some quotes from your local tv repairers.
Nov 14, 2007 | Televison & Video
Tv not working
this symptom, sometimes called the tube light effect, it is characterised by a bright thin horizontal line across the middle of the screen. this symptom is caused by a breakdown in the vertical deflection circuit. hence maybe the trouble maybe in the vertical oscillator, amplifier or output circuits. but if all i have said is not clear to you, better bring it to a qualified tv technician. good luck!
Mar 08, 2007 | Sanyo DS31590 31" TV
Televison & Video Logo
Top Televison & Video Experts
