Question about HP LaserJet 1000 Printer
HP Laserjet 1000 series problem
I get Front door open No Toner Cartridge error message and printer stops without printing and ytello light on.
  • 1 more comment
  • Anonymous Dec 19, 2008
    I have a printer HP laser jet 1000 and I got problem "Door open light is always on", could anyone explain to me to solve this problem? Thanks alot.
  • Anonymous Jan 09, 2009
    Front door is open. but the cover is close and yet have toner
  • blue_moon_05 Jan 18, 2009
    same problem, i think you should try new cartridge..
  • 32 Answers
First close the front door then try printing.
if problem persists contact to fixya again
Posted on Jul 31, 2009
How can fix this error. i seen this "the hp laser jet 1018 has the front cover door open or the toner cartridge is missing"
Hello !!
For tha particular error you are facing, here is the reason. These printers have a switch that triggers an interrupt when the toner door is closed. Usually there is an arm on the door that pushes the switch. It is quite sensitive and delicate. Then sometimes there is a tab on the printer's toner and if that breaks off then that error will be generated.
But in your case as you have not removed or inserted the toner, I think option 1 is applicable to you.
Now, if this printer is in warranty you should send it to HP for Free repair/replacement.
and chek BLOW links too for paper jam and cleaning
Paper jam Message Displays for HP LaserJet 1018 1018s 1020 and 1020 Plus... Cleaning the Printer
Dec 23, 2014 | HP LaserJet 1018 Laser Printer -...
LOCATION OF PRINTER SENSOR
Jams
Clearing jams
CAUTION Do not use sharp objects, such as tweezers or needle nose pliers, to remove jams.
Damage caused by sharp objects will not be covered by the warranty.
CAUTION Always pull jammed media in the direction it would travel through the paper path.
Do not pull jammed media against the direction of travel through the paper path to avoid damage
to the printer.
To prevent damage to the printer when clearing jams, including jams in the output bin, always open the
print-cartridge door and remove the print cartridge. Keep the door open and the cartridge out until the
jam has been cleared. Opening the print-cartridge door and removing the print cartridge relieves tension
on the printer rollers, which prevents damage to the printer and makes the removal of jammed pages
easier.
Occasionally, media becomes jammed during a print job. You are notified of a media jam by an error
from the software and the printer control panel lights. See Control-panel lights (HP LaserJet 1010 series
printers) on page 102 or Control-panel lights (HP LaserJet 1020 printer) on page 106.
The following are some of the causes of media jams:
The input trays are loaded improperly or are too full. See Loading media on page 25.
NOTE When you add new media, always remove all of the media from the input tray and
straighten the stack of new media. This helps prevent multiple sheets of media from feeding
through the printer at one time, reducing media jams.
The media does not meet HP specifications. See Media specifications on page 21.
Typical media jam locations
Print cartridge area: See Removing a jammed page on page 43.
Input tray area: If the page is still sticking out of the input tray, gently try to remove it from the input
tray without tearing the page. If you feel resistance, see Removing a jammed page on page 43.
Output path: If the page is sticking out of the output bin, see Removing a jammed page
NOTE There might be loose toner in the printer after a media jam. This toner clears up after
a few sheets are printed.
Use the procedures in this section to remove a jam.
CAUTION Media jams might result in loose toner on the page. If you get any toner on your
clothes, wash them in cold water. Hot water will permanently set the toner into the fabric.
Partshere Troubleshooting
CAUTION To prevent damage to the printer when clearing jams, including jams in the output
bin, always open the print cartridge door and remove the print cartridge.
To prevent damage to the print cartridge, minimize its exposure to direct light. Cover the print
cartridge with a sheet of paper.
NOTE The following illustrations show the HP LaserJet 1020 printer. The same procedure is
used to remove a jam in the HP LaserJet 1010 series printers.
Open the print cartridge door, and remove the print cartridge.
Grasp the middle edge of the side of the media that is most visible, and carefully pull it free from
the printer.
jams. Damage caused by sharp objects will not be covered by the warranty.
Do not forcefully pull jammed media against the direction of travel through the paper path to
avoid damage to the printer.
When you have removed the jammed media, replace the print cartridge, and close the print cartridge
door.
After clearing a media jam, you might need to turn the printer off then on again.
NOTE When you add new media, remove all of the media from the input tray and straighten
Sep 25, 2011 | HP LaserJet 1020 Printer
How do I load ink and toner in hp laserjet 1100
By load the toner, if you mean inserting the toner cartridge.Then i will give you instructions.In laser toner printer, there is toner cartridge, and not ink jet cartridge.In laser toner cartridges, there is a black color toner power and it does have any liquid ink, which ink jet cartridges have.To remove the laser toner cartridge from hp laser jet 1100 printer, its simple.The front door open and old toner cartridge comes out.Just pull the front door towards you.While inserting cartridge.If you have problem, then take note that, sticker side of the cartridge is towards you.On the cartridge there is a rectangle flap, which you hold in your hand.This is meant for holding the cartridge, while removing and inserting cartridge.The stick side will be in your side.There is a green color drum, the drum side will be on opposite site.-------------- Still any problem.Keep updated.But i think that will help.Thanks.Helpmech.
Mar 25, 2011 | HP LaserJet 1100 Printer
HP LaserJet 1020 won't print. Error: HP LaserJet 1020 has the front cover door open or the toner cartridge is missing. The door is closed and the toner crtridge is installed properly. I tried to upgrade...
Did this just suddenly happen or was it after you replaced the toner cartridge or opened the door?
I have found that if the toner cartridge is not completly positioned into the printer, it can give this error.
Feb 23, 2011 | HP LaserJet 1020 Printer
Hp laserjet 1000 series - installed new cartridge now a line prints every 3 inches on every copy
You have a bad toner cartridge.
Did you have the line with the original cartridge?
A line every 3" is the diameter of the toner drum.
Dec 13, 2010 | HP LaserJet 1000 Printer
Hp LaserJet 1000 series printer error message on front door cover and toner cartridge missing
hi..
ijust solved this issue
WHOA ...
my printer is HP 1020,, and i was printing a huge number of sheets, which USED TO GET STUCK IN AGAGIN AN AGIAN... coz, i was using a low quality damned paper..
now,, it began to gave error ,tht either the front cover door not closed , or its toner cartridge missing.
Well,, simple solution for me was (which is basic i think)
>> Remove the metallic plate on the back of the printer
>>there you 'll find , on the right side, near the socket for poer cable, a "lever" like thing, thats the lever for the "barrier" between the SENSOR... move it and u'll get an idea..
>> if its jammed ,, then free it..
(mine was stuck into dont know wht, and i freed it, and all is fine)
>> if spring adjusment is wrong, correst it(you may get idea by moving it again n again, whether it comes bbacl to its orgignal position or not...
> remore the tonor cartidge and insert it back while looking on the lever movements.... and you ll get whats the matter with it..
PLEASE note it,,, that i think,, the sensors are NEVER damaged !!! mind it.....my knowlegde says , sensors are hardly damaged ..
-----Adios.... Tauseem Omer...Ravian Kemcolian.
Nov 11, 2008 | HP LaserJet 1010 Printer
Printer suddenly stopped printing
verify if you are printing with the correct paper size..... long is 8.5 by 13 and not 8.5 by 14.....
or
1. delete the installed driver
2. turn off the printer and let your computer detect the printer.... let it finish
3. restart your computer
Nov 09, 2008 | HP LaserJet 1020 Printer
HP Laserjet 2015 dn
It means that the printer is in READY State.
Control panel
The printer control panel is comprised of six lights and two buttons. The lights produce patterns that
identify the printer status.
1 Jam light: Indicates that there is a jam in the printer.
2 Toner light: When the print cartridge is low, the Toner light illuminates. When the print cartridge is out of the printer,
the Toner light blinks.
3 Paper out light: Indicates that the printer is out of paper.
4 Attention light: Indicates that the print-cartridge door is open or other errors exist.
5 Ready light: Indicates that the printer is ready to print.
6 Go button and light: Initiates action or indicates status.
7 Cancel button: To cancel the print job that is currently printing, press the Cancel button.
Sep 08, 2008 | HP LaserJet P2015dn Printer
Open Questions:
See all HP LaserJet 1000 Printer Questions
HP LaserJet 1000 Printer Logo
113 people viewed this question
Seeker5211
Seeker5211
