Question about HP Office Equipment & Supplies
Hp PSC 2210 i HAVE JUST INSERTED A NEW BLACK CARTRIDGE. iT ALIGHNED ITSELF CORRECTLY.hOWEVER IT CONTINUALY SHOWSPRESS ENTER TO ALIGN AND WILL NOT PRINT OR COPY
  • Anonymous May 11, 2010
    you may have to uninstall the program and then reinstall it for that printer and then do the updates too make sure you have the right program ,,,,,,,,,,, or ther are a few corrupt files, and or registry errors that need to be corrected ...... try going to www.pcpitstop.com and run there free program to find out exactly where your problems are ...... just and idea for ya ...
    Prodigy:
    An expert who has answered 500 questions.
    Sergeant:
  • 564 Answers
You may need to do a clean print head first.
Posted on Aug 19, 2008
SOURCE:
HP 2210 all in one chg black cart, get message
Do a powerflee of the printer..
take out the black cart. Unplugged all cables
including powercable. press and hold the powerbutton for 30 sec then put back the cable and the black cart.
May 07, 2010 | HP PSC 1210 All-In-One InkJet Printer
Dial says to remove cartridges and check. Have replaced cartridge
After cleaning cartridges and replacing refilled black ink, I removed blck ink and replaced with HP 58 photo ink. this aborted the "check cartridges freeze". I still cannot align cartridges after removing #58 and replacing with new HP 57. the operation starts but will not complete.
Any suggestions on how to align cartridges?
dunbarj730
May 02, 2009 | HP PSC 2210 All-In-One InkJet Printer
"Press enter to align cartridges"
Try removing the ink cartridges and cleaning the electrical both on the ink and iside the unit with some rubbing alcohol and qtip then reseat them back into the unit and see if that works
Feb 21, 2009 | HP PSC 2210 All-In-One InkJet Printer
New ink cartridge
http://h10025.www1.hp.com/ewfrf/wc/document?docname=
c00042820&cc=ca&lc=en&dlc=en&product=79499
Apr 21, 2008 | HP PSC 2210 All-In-One InkJet Printer
Put in a new cartridge
i don't have driver
i want to load driver printer hp psc2210
Printer Issues
my hp psc 2210 after putting in new cartridge keeps saying press enter to align cartridge. it keeps repeating the same reading.
Apr 08, 2008 | HP PSC 2210 All-In-One InkJet Printer
Alighning test
Problem The following error message appears on the LCD panel on top of the printer after you insert a cartridge: Press enter to align cartridges . You press Enter , but the error message does not go away. The printer will not print. Solution To bypass the cartridge alignment, do the following:
  1. Press and hold the Setup button.
  2. Press the Options button. The printer should be ready to print.
If the print quality is unacceptable after bypassing alignment, follow the steps below until the error is corrected. Step 1 - Check the paper Make sure the printer is loaded with clean, unused, white paper. If the paper is not feeding properly, check the paper path. For information about how to do that, see the instructions under "If the paper does not feed correctly" at the end of this document. Step 2 - Remove and inspect the cartridges
NOTE: The "problem" cartridge is the cartridge indicated by the error message.
  1. Turn on the unit, then open the print carriage access door. The print carriage moves to the center of the unit.
  2. Press down lightly on the top of the ink cartridge latch and pull the lower section of the latch out to release the cartridge. Figure 1: Removing the cartridge c00143341.gif
Mar 03, 2008 | HP PSC 2210 All-In-One InkJet Printer
Hp psc 2210 all in one printer
pls.. align the carriage , or re insert the two cartrige's
Apr 22, 2007 | HP PSC 2210 All-In-One InkJet Printer
Open Questions:
44 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
