Question about Sony Audio Players & Recorders
I have an older sony explod car amp model xm2200gtx. My problem is the power protector red light comes on, it goes green then turns red after a couple of seconds. I have it hooked up direct to a 12.67 volt dc power. any help???
    Genius:
  • Sony Master
  • 1,550 Answers
Maybe the audio amplifier IC´s are in bad conditions that´s why going in to protection way.
Posted on Aug 19, 2008
SOURCE:
I haave a sony xplod 600w 3and4 channel amp. all wires are correctly installed and it works for like half a second then the protector light comes on (goes green to red) and stays red. ive checked the...
Well as far as getting a different amp depends on what kind of subs or speakers you are trying to push. Also it depends on how much you are asking the amp to do. If you are asking a 600w amp to try and do 1000w job its just not gonna work and it will shut down.
Jan 04, 2011 | Car Audio & Video
Amp repair
Check all your connections to make sure wiring is correct, if the light stays red you have an internal fault in the amp.
Jan 27, 2010 | Sony XM-SD46X Car Audio Amplifier
Wrong model showed up on my question - need new reply about part
ORDERED SONY PROJECTION REPLACEMENT LAMP - SHOULD ARRIVE IN ONE MORE DAY - KEEPING FINGERS XXX'D THAT THIS WILL RESOLVE THE PROBLEM - BUT THE TECH WAS EXCELLENT RESOURCE! I'M CONFIDENT IT WILL FIX THE PROBLEM AND THRILLED WE CAN DO IT OURSELVES AND SAVE $200! THANKS !
May 18, 2009 | Sony KV-36FV26 TV
SONY KDF-E55A20 5 red blinking lights on power button
Symptom shows Lamp is weak in result and causing restart of TV again and again. Your TV requires new lamp as per following part number...
A1085447A* LAMP BLOCK ASSY XL-2200U
It is available in Sony Accessories Store for $200 and replacement procedure is written in instruction manual of TV.
Always buy Sony original lamp for TV and avoid aftermarket / cheap lamp for TV safety.
Power protector light on sony xplode 1000 watt amp
a green light is the power indicator, a red light is when the protector is in affect
May 30, 2008 | Sony Xplod XM-554ZR Car Audio Amplifier
Protector light keeps coming on
the reason why this is happining is that your pushing to much power than that amp can handle you need to get a bigger amp so it can withstand the power that you want to push to it also the red light comes on so you dont blow the amp.
Jan 08, 2008 | Sony XM-1252GTR Car Audio Amplifier
My Power Protector Light wont turn Green
switch off the amp then take off all the wires off including the speaker wire and then reconnect the wires on like before the problem is that the amp is on protection and if that dont work then get it repaired another thing is make sure ur amp fuses havent blown.
Nov 04, 2006 | Sony Xplod XM-554ZR Car Audio Amplifier
97 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Ekse
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
