How do I install a channel to receive satellite programmes? My model is LE19R8
  • 138 Answers
If you have a satellite and it is connected with coaxial cable put the set to channell 3 or 4. If the satellite is connected with RCA cableput the set on that source the cable are connected to. No need to program the set. Use the cable remote to change the channels just use the tv remote to turn the set on and off and for volume.
Posted on Aug 19, 2008
I have a THS220 box and have difficulty recording programmes
Hello Joan,
To record a satellite you will need two scart leads.
Plug one end of the first scart lead into the "DVD/VCR SCART" socket on the back of the satellite receiver, then plug the other end into the "INPUT" scart on the back of the VCR. Take one end of the second scart lead and plug it into the "OUTPUT" socket on the back of the VCR and plug the other end into "SCART IN" socket on the back of the TV.
To record, select the satellite channel you want to record, then, on the VCR, select scart input, (at this point, you can record a satellite program). To watch a satellite channel or recorded satellite channel, select the scart input on the TV.
If you need anymore information, then let me know.
Kind regards,
Ron.
May 04, 2014 | Thomson Audio Players & Recorders
Recording from Sky
you need to connect the satellite box directly to the VCR and record
Sep 09, 2008 | Televison & Video
I have a wf24t5 that i want to connect to a dish sat hd. how and what do i need to do to connect?
After confirming by viewing the operation manual for this unit, this TV is only capable of inputting a baseband video and standard audio. Unless the Satellite Receiver you have has those type of output jacks then this TV will not be able to reproduce picture or sound from the Receiver. It may be possible to connect through the antenna connection but again the Satellite would need a connector that would output on Channel 3 or 4. Most recent satellite receivers do not offer these ouputs. You indicate that the Receiver you have is High Def. The TV you have is not high def and would drastically down grade the quality of your picture and audio being delivered by the satellite receiver
Television system: NTSC-M
TV Standard
Closed Caption
System: §15.119/FCC
Channel coverage
VHF: 2 - 13
UHF: 14 - 69
CATV: 2 - 13, A - W,
W+1 - W+84,
A-5 - A-1, 5A
Tuning System: 181 channel
frequency synthesized
tuning system
Channel access: Direct access keyboard,
programmable
scan and up/down
Terminals
Antenna input: VHF/UHF/CATV
75 ohm unbalanced
(F-type)
Video input: RCA connector x 1
(1 x Front)
Audio input: RCA connector x 1
(1 x Front)
1 speaker
ELECTRICAL SPECIFICATIONS
Sound output: 1W, 8 ohm x 1
OTHER SPECIFICATIONS
Remote control: Digital encoded
infrared light system
Operating
temperature: 5°C to 40°C
(41°F - 104°F)
Power requirements: AC120V, 60Hz
Power consumption
(Maximum): 98W
Picture tube: 23"
Dimensions: H : 20-3/8" (518mm)
W: 22-13/16" (580mm)
D : 18-7/16" (469mm)
Weight: 55.1lbs. (25kg)
•Designs and specifications are subject to
change without notice and without our
legal obligation.
•If there is a discrepancy between languages,
Feb 18, 2011 | Symphonic Televison & Video
What has happened to BBC 4 On free to Air? its gone Blank
Try the CBeebies channel: you won't get a programme guide, but the BBC4 transmission takes over the channel at 19.00 hours U.K. time.
Oct 30, 2010 | Digi Konig tal Free-To-Air Satellite...
My receiver displays "updating channels" and nothing else works
problem lies with sirius, contact sirius and follow instructions to update exactly step by step...
Sep 20, 2009 | Sirius Satellite Radio Receiver
Retuning digital TV
You need to use the (what looks like a large sattellite) button to retune your tv.
Some Samsung tv's let you access the button but other models have a "D MENU" button on the remote. Press this button, then scroll down to the icon that looks like a large sattellite. Then scroll across and click on "Auto Store" this will then go through all the available channels
Mar 26, 2009 | Samsung LE32R41BD 32 in. HD-Ready LCD...
Have Direct TV using a Sony Digital Satellite receiver model #SAT B2-2 /Sony Satellite dish purchased in 7/97. I get local channels thru Direct TV. Recently, local channels will show on the Direct TV guide...
Your dish is out of alignment. The local channel satellite doesn't have as strong of a signal, so a slight misalignment will cause problems.
It could also be an F-connector needs to be replaced at the dish or multiswitch (if you have one). Sometimes moisture builds up inside the connector and corrodes the copper stinger inside.
If you go into your satellite signal strength menu and find the local channel satellite, you're sure to see either a weak signal or an intermittent one.
One more thing, if a tree has grown in the line of sight between the dish and the satellite, this will cause signal problems too. In this case, you either have to trim the tree or move the dish.
Hope this helps!
P.S.
The customer service reps at DirecTV usually idiots reading from a script with no real field experience.
Mar 25, 2009 | Televison & Video
Reply from Matt633
If you are receiving OTA channels, you will need to have the converter box but if you have a cable TV converter or satellite receiver then you do not need the converter as the channels will come to the cable bix or satellite receiver and from there to your TV.
Dec 13, 2008 | Televison & Video
SAMSUNG LCD TV LE19R8.
my samsung ps-42s5h seems to have a problem with the screen, there is no picture and seems to make a pulseing noise. any ideas?.
Oct 01, 2008 | Samsung Televison & Video
Televison & Video Logo
80 people viewed this question
Top Televison & Video Experts
