Flat widescreen LCD monitor Model 190SW8FS/00. On each page there are two faint lines running across screen from right to left. Also, a blue notice appears when beginning to use monitor with the number 144OX900@60HZ. How do I get rid of it.
  • Flecks Aug 19, 2008
    I hope so - haven't carried out instructions yet.
  • 19,396 Answers
Try first moving the cable, often you get similar phoenomena from cable problems.
Posted on Aug 19, 2008
  • Ginko
    Ginko Aug 19, 2008
    About the 144OX900@60HZ message, this often happens because the monitor does not support display resolution from computer.
    To fix this you need to go to display properties, from control panel and open display resolution properties, then adjust display settings to a supported resolution.
    Check
    Change Screen Resolution in Windows
    Regarding the two lines, see if they also disappear changing resolution or moving cable/ connector, then it can be an internal fault, like a burnt component inside. In this case you ma need a technician, if this is the case check guaranty terms and call service number printed in owner manual.
Diagonal lines at 45 degree angle from left top to right bottom of screen
db:: 4.31::Diagonal lines on tm2 screen? fz - Hivmr
www.hivmr.com/db/fzap9jk8dp87mcjk3cc9jsp7fzxk7pz1
There are faint 45 degree diagonal lines covering my brand new tm2 LCD ... with some static looking diagonal lines going from bottom left to top right. .... DB:3.01:Dv6113 Us - Computer Freezes Showing Diagonal Lines On Screen aj ... Also there arediagonal lines that run across the screen at about a 30 degree angle.
3M Privacy Filter for Laptop diagonal-14.1" viewing screen ...
www.amazon.com/3M...diagonal-14.../B00006B8A9
Amazon.com, Inc.
Rating: 3.8 - ‎1,617 reviews
Amazon.com: 3M Privacy Filter for Laptop diagonal-14.1" viewing screen ... Premium 14.0 Inch Privacy Screen for Widescreen Laptop or Computer Monitor .... 3M™ Privacy Filters create a 30-degree cone of vision so on-screen data is .... You'll also notice a large "3M PF14.1W" printed in the top right hand corner of the filter.
FZ190: Faint Diagonal lines on screen? ' NotebookReview
forum.notebookreview.com > ... > VAIO / Sony
Jan 27, 2016 | Computers & Internet
Screen in my Philips 190SW8FS/00 monitor, suddenly becomes black...
Grab a flashlight. When your screen goes black, shine the light on it. If you can see a faint image (press the Windows key and see if you the start menu pops up) then your inverter is going out. They are not expensive but depending on how time consuming it is to replace it, it might be easier and cheaper to just get a new monitor.
Oct 18, 2013 | Computers & Internet
Samsung screen is not calibrated properly. There is a line on the right side of the screen that I can't get rid of.
Unfortunately the line didn't show up in the video.
1) New LCD screen?
Should have an Installation CD Disk that comes with it. Use it if so.
Has the Drivers on it.
Driver: Small piece of software that allows the Operating System to communicate with a device.
Don't know which version of the Windows O/S you have.
The device in this case is the LCD monitor.
2) What is the NATIVE screen resolution for the LCD monitor.
Look up the specs on the monitor using it's Model Number on back.
For example I installed an HP 2009M 20-inch widescreen monitor, along with the 26-inch RCA ENV HDTV I use for a monitor.
I had to use the drivers from the disk, but could still not set the native resolution in Display Properties.
There is an alternate resolution to the native one that can be used.
The drivers from the disk made it so.
The 20 inch widescreen is 1600 x 900 (Pixels)
The 26 inch HDTV is set at 1360 x 768 (Pixels)
Right-click on an empty area of your desktop screen.
Left-click on Properties at the bottom of the list.
In the Display Properties window click on the Settings tab.
What is the Screen resolution setting? What is it supposed to be?
The Slider on the line is clicked on with the left mouse button, left mouse button held down; then the Slider is slid to the left to decrease screen resolution, or to the right to increase with the mouse.
Color quality should be set to High (32-bit)
1) Installing software (Drivers) from the Installation disk, (Or from the monitor manufacturers support website);
And,
2) Setting the screen resolution;
doesn't help, replace the monitor cable with a known to be good one.
Still no? Your LCD monitor is going out.
Regards,
joecoolvette
Dec 07, 2012 | Computers & Internet
Line across lcd screen
Try the following steps:
  1. On the monitor, press Menu, and select Factory Reset.
  2. If the monitor has more than one type of connection available such as VGA, DVI, or HDMI, try a different type of connection.
  3. Connect the monitor to another computer. If the line appears when the monitor is connected to the second computer, the monitor might be damaged or defective.Otherwise, the video card and driver is causing the problem from the computer. let me know if this resolved ur issue.. regards, guru
May 03, 2010 | HP 22" Widescreen Flat Panel TFT LCD HD...
Envision 19" Widescreen Flat-Panel LCD Monitor It just started I have lines that flicker across the screen.How do I stop that it is driving me crazy.
Is there any speaker sets near the monitor or electromagnetic devices near the monitor?
Generally the flicker is caused by some external devices.
Mar 14, 2010 | Envision 19" Widescreen Flat Panel LCD...
My monitor has a variety of colors going down the left side of the screen and across the top of the screen
increase colour quality 24 or 32 bit from display properties, if there are no options than u have to install display driver.
Aug 02, 2009 | Gateway 19" Widescreen Flat Panel TFT LCD...
EMachines E19T5W Flat Panel Monitor - keeps blinking red, green, blue white lines
On the monitor below the screen has these fine pink and green lines blinking across the screen all the time on my laptop. Can you tell me how to fix it or solve this problem?
Aug 12, 2008 | E-Machines 19" Widescreen Flat Panel TFT...
White horizontal, zig-zagging lines
Sounds like the flyback transformer is bad. couple of 100 dollars if it is that
Dec 03, 2007 | Televison & Video
Picture is not centered on monitor leaving a 2 1/2" black border on Philips LCD
I have a Philips 30 inch LCD and solved the problem by using the circular arrow button on the TV remote. Pointing it at the TV and clicking "right" (3 o'clock on the button), the picture moved right. Same thing on for "left". Worked for me.
Nov 13, 2007 | Philips 37PF7320A 37 in. HD-Ready LCD...
LCD monitor problem
what is the solution for this? my husband just turned his pc on when we got home and there are line blue lines running up n down in the black
Oct 11, 2007 | Computers & Internet
Computers & Internet Logo
79 people viewed this question
David Payne
David Payne
