Question about Xerox Phaser 6180N Laser Printer
Xerox 6180 lost CD...
Hi, I have a Xerox 6180. I lost the CD. I need to install the network connection (the menu where you have the option to choose to install either a local or network printer). Xerox's website only has the driver installtion and doesn't have the option of choosing a local or network printer. How can I obtain the complete setup file on the CD??
    Prodigy:
    An expert who has answered 500 questions.
    Sergeant:
  • 564 Answers
The local or network option happens when you install it, install as a local first, then select it as a network option, assuming you have xp.
Posted on Aug 19, 2008
How do you print two sided on xerox 6180 phaser
I expect you have to put the paper in the other side up. however if you do you could spoil the first side as it will melt the wax again when it's fusing the second side!
Good Luck.
Jul 31, 2014 | Xerox Phaser 6180N Laser Printer
I am unable to install hp laserjet M2727 nf MFP in the network. i don't know how to install it on the network? please suggest me the steps .
Hi
This is very easy setup to install the network printer. first to set the your desire network IP address in your printer.follow the mention option enter the Ip address.
  1. Press the Menu button.
  2. Press the Down Arrow to find Configure Device .
  3. Choose Configure Device .
  4. Press the check mark button.
  5. Choose I/O .
  6. Press the check mark button.
  7. Press the EIO (1 or 2) Jetdirect Menu .
  8. Press the check mark button.
  9. Choose TCP/IP .
  10. Press the check mark button.
  11. Choose Configuration Method .
  12. Press the check mark button.
  13. Choose Manual .
  14. Press the check mark button.
  15. Select Manual Settings .
  16. Choose IP address .
  17. Press the check mark button.
  18. Enter IP address with keypad.
  19. Press the check mark button.
  20. Choose Subnet Mask .
  21. Press the check mark button.
  22. Enter Subnet Mask with keypad.
After assign the IP addres in printer. connect to your printer with router or switch. and insert you HP Installation CD in Rom,
Go to the Control Panel and select Printer and Faxes click the "Add Printer"the new Add printer wizard open click next and remove the check mark in " Automatic detect and install the Plug and Play printer" click next, then you get "Select the printer port screen" Click create New port and choose Standard TCP/IP and click next.
You will get another New windows " Standard TCP/IP Add Printer Port" click next and put the Printer IP Address click next and next, Finish.
Now the windows will appear " Add Printer Wizard" click the Have Disk " and choose the .Inf file for your Installation CD, and Click Finish.
Your printer will install and the test will come.
If my solution solve you problem then give me four thumb
Cheer
Jul 12, 2011 | HP Laserjet M2727nf Multifunction Printer
Hello: I removed all installed printers from the uninstall list in control panel the other evening. Then I deleted two icons from the devices and printers window but they sometimes reappear. This time, I...
Hi Edward
The automatic reappear printer problem its come when you are connect to two and three computer in same network, when the network on the automatic search the printer in network if you install that printer in any other PC so automatic the printer is add in your printer list.
For installing the printer not nee to delete the all printer, put the installation CD in Rom and click the setup.exe
Cheer
Jul 11, 2011 | Xerox Phaser 6180N Laser Printer
Lost CD & Manuals For instructions To connect Printer To LAP TOP Need Info. How To Install Same Thanks
Click on the link below to download the software for installation.
Choose the operating system and download the DRIVERS. ( usually 32 bit is common PC Operating system for XP, VISTA or Win 7 )
Download Drivers
User Manual
First step is to run the wireless setup wizard from printer front panel
Press the Setup button on printer front panel - Press OK
Use the arrow keys and locate Network Connections - Press OK
Locate the Wireless Setup Wizard - Press OK
It will search for the network Name ( SSID )
Enter the network key if your network is password protected.
Press OK
It should give you message as printer connected to network.
Run the software driver file that you have downloaded and choose the Wireless option to continue with installation.
* Please rate this solution with Thumbs up and comment to help us improve providing support
Dec 07, 2010 | HP J4680 Office Jet All-In-One Printer
Xerox 6180 MFP N error 016-782 Windows 7 x64
did you get a solution to this problem. i have the exact same situation.
Feb 16, 2010 | Xerox Phaser 6180N Laser Printer
Xerox phaser 6180 mfp error code 133-290
Before attempting to resolve the error 133. -290, print a copy of the configuration report on the copier / fax. Use the navigation on the front panel to access the configuration menu to get the impression. Review printing to make sure it understands the network settings. This is a protection against configuration settings being lost when you troubleshoot.
Clearing Memory reset the memory of the Xerox Phaser 6180MFP, Dell 3110cn or Dell Machine 3115cn to erase the stored contents and eliminate corrupted data. Disconnect the analog line and power cord from the printer. Wait at least 10 minutes. Then reconnect the analog line and the power cord. As the machine starts, press the "All Clear" "Stop" buttons to prevent automatic printing of the status page. Check the error display panel 133 to 290 times the machine is fully initialized.
Corrupt Adjustmen
Jun 20, 2009 | Xerox 6180MFP/N Printer
Installed the Logitech 10.5.1 software, lost networks, access
ok.. so the other way for that is to repair it using your Operating System disc. It repairs the missing or corrupted files. You don't have to worry because it will not remove your files from your harddisk. You will just choose Repair in the option menu when you boot from your Operating System disc.
Jan 10, 2009 | Logitech QuickCam Deluxe for Notebooks
Installation cd for officejet 4215
Hello
if you lost your hp cd you should download the "HP Full Feature software/driver: No Network Support" and then install it. choose your printer here and OS then the HP Full Feature software/driver: No Network Support the size of the file is 364.59M. that´s the best alternative to go, if you just want simple software and drivers choose the HP Basic Feature software/driver
good luck
Sep 15, 2008 | HP Deskjet 3845 InkJet Printer
Instalation
You can download the drivers from HERE
Just click on the driver, choose the ad-option, on the new window, click on no-thanks on the right hand side. Enter the 3-digit code provided, then choose verify.
Download and enjoy!
Apr 11, 2008 | Encore ENUWI-G2 802.11G WIRELESS USB 2.0...
Xerox Phaser 6180N Laser Printer Logo
295 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
