Question about Dryers
Hoover Tumble Dryer TC650
The dryer works fine but does not heat up. Any idea's?
  • 49 Answers
Yes
Posted on Aug 19, 2008
How do I change the heating element on a hoover vhc 691 b tumble dryer?
Many of the heating elements can be seen and changed by laying the dryer on its back...the element is usually visible from the bottom. I found the part on the link I am incuding for you. Hoover VHC 691B80 Dryer Element 2100W
Dec 15, 2014 | Hoover Dryers
My hoover tumble dryer Hnc175 wont heat up,is still working as normal, just no heat, i have cleaned out the filters and still not working
Heating elements can fail. These are relatively easy and economical to replace. The heating element is not necessarily the culprit if your tumble dryer does not get hot, however. There are thermal overload cutouts fitted to many machines. If they fail, the current will not be passed to the heating element. Replacement is again, fairly straightforward.
Tumble dryers will often have thermostats fitted. A heater control one, and an exhaust thermostat. The first keeps the temperature correct. The second, as its name suggests, monitors the temperature of the exhaust (in case the airflow in the machine is impeded) Once again, replacement is not too much of a problem.
http://www.repairclinic.com/Dryer-Troubleshooting
Please look, at the link above, it will show you how to perform troubleshooting. procedures and repair.
If you feel you don't want to do it yourself, please call a Hoover Tech, and get it looked at. Ask for a "Quote" for the repair, so you get an idea of whats what.
Apr 08, 2010 | Dryers
Hoover Nextra 6 1400 6+4kg - the tumble dryer
under top cover there are 2 thermal cut outs to reset.situated centre front
Sep 12, 2009 | Hoover Nextra HNWL 3136 Front Load Washer...
Hoover TC650 Tumble Dryer will not heat up
Not all that familiar with the Hoover Dryer line but in general if you have 12 volts being fed to the heater element.. you identified why it isn't heating .. Your husband is correct in that heater power should be line voltage.. You may have a non-resettable thermal fuse that has opened or a relay that feeds power to the heater is not being commanded to turn on by the logic on the control board. If your husband is handy and technically competent, he should verify that there is 220VAC at the input termnal block of the dryer itself ( carefully) to make sure you don't have one phase missing.. Those are the chief suspects... not sure that helped you but you now have a few ideas where to look...
Regards,
Rick
Nov 28, 2008 | Dryers
My Hoover TC650 condensor dryer has a fault. When turned on it makes a noise (buzz) but the drum does not revolve. If I turn it by hand and then quickly close the door and press the button it will...
i saw your question and never worked on a hoover dryer so i checked it out go here to see video
https://www.how-to-repair.com/help/hoover-candy-tumble-dryer-drum-not-turning-and-belt-ok-faulty-capacitor/
i have to tell you on all the dryers i've ever worked on they never had a cap in them,only washers,on a dryer that isn't a condenser dryer if you get the dreaded buzzing sound and start it like you did,open the door,hold in the door switch and spin the drum with your other hand while someone else pushes in the start button and it would start it would be the motor,i've seen a condenser dryer and the problem always was with the filter,people that had just bought one didn't know you had to clean out the filter box,never took one apart,i saw that nobody answered you so i hope this video helps you out and i learned that condenser dryers have a cap in them.
Dec 30, 2017 | Hoover Dryers
Tumble Dryer not getting hot
its your thermostat mate they cost 30quid simle to fit
Jul 06, 2008 | Dryers
Hoover tumble dryer
I think you may have a bad relay on the motor, where power is re-applied after the push start is released
Oct 11, 2007 | Hoover HDC6 Electric Dryer
Dryers Logo
189 people viewed this question
Top Dryers Experts
