Question about Daewoo 17N5 17 in.CRT Conventional Monitor
No power can any one help how to fixed my monitor thanks a lot
No power
Posted on Jan 05, 2009
Try different mains cable to monitor.if no good.unplug.
nxt turn upside down and take back off monitor.any fuses? if so check they ok.
if no good take to local tv repair shop.type that deals in second hand tvs.
you can probably pick up a good CRT for £30 from a cptr fair or newspaper adds though: as people like TFT monitors.
byway.i dont.
Posted on Aug 19, 2008
Monitor is flickering
Welcome to Fixya Support,
I am happy to assist you.
Monitor Flickering May due to following Reason
1. Deffective LOT
2. Deffictive Filter IC or Deffective horizontal IC
To fix this issue,you have to check LOT, if LOT working fine, you have to search for burn out capacitor along with filter IC and replace with new one. After this your monitor must work properly, without any flickering.
Thank you for using Fixya Support. If any problem leave a comment or feedback we will deffinately help you.
Have a Nice Day!
Best Regards
Fixya Expert
Chandrashekhar.
Dec 06, 2010 | LG 700M 17" CRT Monitor
Voltage and polarity for Hyundai B70A
Your monitor needs a 12volt 5amp power supply with + 5,5mm tip. Most universal power supplies will not supply enough amps to power an LCD monitor. If you need an adapter we do have them in stock at:
http://www.ccl-la.com/parts_lcd.htm
I hope this helps, if so please rate this solution.
Buddy
Corporate Computer
www.ccl-la.com
Jan 16, 2010 | Hyundai ImageQuest B70A 17" LCD Monitor
Vertical lines on laptop monitor
This would need a screen replacement
Lots of people do this themselves
Ebay is a good source for laptop parts most of which are NEW
Aug 26, 2009 | Computers & Internet
Samsung Syncmaster 173V Wave like pattern on 2 monitors
1. change the power supply out put capacitors.& main filter capacitor.
2. near 2 LOT 47mf / 250v cap.
3. degousing PTC
4. LOT
Dec 19, 2008 | Computers & Internet
IBM E54 CRT Monitor - Exceeds the Display Width
1. first replaced the TIP 122 fet. back side of lot.
2. change the 424j / 1600v pf.
3. IRF 630 ( after power output section )
Nov 17, 2008 | IBM E54 15" CRT Monitor
Double Images / Shadows on the monitor screen
I read through other solutions to this problem because I had the same problem. I checked to make sure electrical cords were properly attached, and vola! problem solved! I had no idea this problem could be fixed just by checking the cord connections. Thanks a million for posting this solution. I had been putting up with the shadowing, streaking for months! You really made my day.
Jun 10, 2008 | Gateway FPD2275W LCD Monitor
Dell flat screen
REPLACE 2SC5707 IN POWER INVERTER BOARD.
This parts is used to fix Some dell and hp lcd monitor.
DELL E172FPb, E173FPb. HP Pavilion F1703, Pavilion F1503. If you can't get this item to work let me know, I can help I have fixed a lot of these monitor with no problem.
May 01, 2008 | Dell E173FPb 17" TFT LCD Monitor
NEC Plasma Sync 42MP3 Problem
Hi, This model has some design flaws and yes NEC admitted to them a year ago. The problem with your monitor (hopefully) is a bad power supply. Have a Tech with a voltage tool check the boards as well as the connections Reason, this monitor generates a lot of heat ( no cooling fans) primarily at the power supply and sits there. So the wires tend to go weak by the heat build up. What the problem is the power is not going to the correct board in the right voltage. hope this helps out!!!
Jan 06, 2008 | NEC PlasmaSync 42MP3 42 in. Television
Daewoo 17N5 17 in.CRT Conventional Monitor Logo
73 people viewed this question
Top Daewoo Computers & Internet Experts
Paul Bade
richie46
Gregg Errera
Gregg Errera
Level 1 Expert
Are you a Daewoo Computer and Internet Expert? Answer questions, earn points and help others
