Question about CTX Computers & Internet
My CTX VL701 EX701F monitor keeps going black with just a horizontal light showing, it happened for briefly at first and then returned to the screen but the length of time its black is increasing - any idea whu?
  • mrib Aug 19, 2008
    Thanks, I dont feel confident enough so will call in the professionals with their soldering iron!
    Thank you.
    Brigadier General:
  • 6,966 Answers
If you are referring to a conventional CRT monitor, then the fault you have described is indicative of a cold solder in the vertical section. Often, this would be any of the pins of the vertical IC. The vertical IC is the only IC that is heatsinked and sits at the back of the flyback transformer.
This of course would require a fair familiarity of electronic components/circuitry and safety procedures, use of a DVM and a soldering iron. It would be to your added advantage access to a service manual or at the very least a schematic diagram with voltage readings. Should you be uncomfortable performing a DIY (do-it-yourself), perhaps your best bet would then be to seek the services of a qualified professional.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Aug 19, 2008
Hello, A family member gave me a CTX S760 17- LCD Monitor. When I hook it up and start my PC the screen looks GREAT for about 15 sec or so and then goes black. Same thing will happen if I power off the...
christoph972, This really sounds like a SMPS going into SHUTDOWN MODE after detecting a fault in the "cold-cathode-fluorescent-lamp" electronic ballast circuit which is called an INVERTER CIRCUIT, or it has a problem all by itself. The big question is? ? ? WHAT is causing the fault? I need you to do the flashlight test to evaluate the condition of the LCD monitor's "switch-mode-power-supply". With a KNOWN-GOOD, fully booted pc that has the WIN-desktop showing, reconnect the S760 to the pc. then and only then push the "ON" button for the monitor and note what happens. After the screen goes black, shine a bright flashlight at different angles about 1" from the LCD screen. Get back to me with the results of test. Did you see or not see the WIN-DESKTOP? Also visit YOUTUBE and search for and view videos of typical lcd monitor disassembly and or lcd repair. FYI only!! The longer ones (8-12min) will be more informative. The symptom you have with this freebie monitor is classic! It could possibily be repaired for $12 or less. Get back to me here at fixya by posting another comment to the above stuff you already did. I"m louie12fix onfixya or lmistyrel
Oct 08, 2009 | CTX S760 (Beige) 17 in. Flat Panel LCD...
Hi we have a ctx monitor PV720A that stays on for a couple of seconds then goes black
glenn659, possible cause is bad internal switch-mode-power-supply" failure or SMPS is detecting something wrong with lcd cold-cathode-fluorescent-tube backlighting circuit, (INVERTER) and it goes into SHUTDOWN mode to try and prevent a catastrophic failure from occuring. Glenn, visit youtube, search for video clips on LCD monitor disassembly and also also research BAD Capacitors or Swollen Capacitors and also the "WHY DO LCD MONITORS FAIL PREMATURELY" Certainly your's will be in the top two causes! Did you do the flashlight test with your monitor "on" and connected to a known good PC with the WIN-desktop screen showing. Even though screen is BLACK it might still show the desktop when you hold the light about 1" from screen. Some will, some won't depends on condition of the power supply. In any case get back to me with your plan of action you intend to take after viewing YOUTUBE stuff. Bye for now. I'm louie12fix on fixya or
Oct 02, 2009 | CTX Computers & Internet
Horizontal black lines across the screen
you can try contacting Lumaco they are a British monitor repair specialist.
It might even be cheaper to buy a new one.
Jun 19, 2009 | Relisys TL 766 Monitor
Monitor displays breifly then goes to blank screen
If tried the monitor on two other computers with the same result -- definitly your monitor is faulty. Take it to the repair shop. To make double sure, run your computer with another monitor. If everything is fine now; you can blame the monitor.
Dec 17, 2008 | Dell Dimension 4600 PC Desktop
CTX VL701 16" Monitor
I made contact with US supplier and am waiting for part reference number.
Jul 24, 2008 | CTX VL701B (Black) 17 in.CRT Conventional...
Dell Latitude cpx
Symptoms of a Bad Video Driver
Monitor Resolution issues:
screen flickers, screen is cloudy, screen shows horizontal lines, screen goes black, goes blank, goes into sleep mode, goes into power mode, size magnifies or reduces, video is jittery, fonts change, screensaver will not appear, cannot extend display on dual monitors.
Download it from here
May 28, 2008 | Dell Latitude CPX Notebook
CTX S762G power on but nothing is showing up on the screen
bad capacitors on the inverter board, need service at electronics tech site or replace the monitor
May 02, 2008 | Computers & Internet
Computers & Internet Logo
139 people viewed this question
Top CTX Computers & Internet Experts
Rommel Balcita
Jerry Greenberg
Jerry Greenberg
Are you a CTX Computer and Internet Expert? Answer questions, earn points and help others
