Question about Refrigerators
Difficult fault on samsung side by side fridge freezer SRS615DP
Hi my fridge freezer will run un-till it gets down to temp then will stop running , but will continue to read 3 and -15 on display. after a while it begins to flash. if you turn the power off and back on it will read true temps of about 16. After advice of a fridge mechanic i replaced the temperate sensors, followed by the main computer board , followed by the defrost sensors, but problem continues. Where is the problem,??????
  • 5 more comments
  • withington Aug 20, 2008
    have replaced computer board with brand new one cant be problem what is the solution
    replaced both temp sensors inthe fridge not the problem
    modle srs615dp removed both covers fan are running correctly and nothing is frozen up or iceing over , not the problem
    no thermo state as imaware of this is done by the temperature sensores will double check with machanic
    tryed a complete defrost for more than 48 hours and did not help
    no pannel was not heavey and there was no ice build up what so ever fridge only runs for about eight hours not enough time to ice up
  • withington Aug 21, 2008
    did not pat to here get a good teck someone must have the same problem and able to find an answer
    Master:
  • 521 Answers
Advise of a good tecnician required after complete verification of all the parts.also check for blockage of ventilations.sometimes a silly problem makes things worse.
Posted on Aug 21, 2008
  • 1,031 Answers
,SAMSUNG ARE RENOWNED FOR THESE FAULTS, SINCE YOU HAVE CHANGED DEFROST SENSOR YOU CAN CONFIRM IF THE SENSOR IS WORKING,PUT A MULTIMETER ACROSS THE END OF THE WIRESES AND HOLD THE WHITE END IN YOUR HAND TIGHT, YOU WILL NOTICE THE RESTANCE CHANGING, IF NOT IT IS FAULTY, TO THE RIGHT OF THE EVAPORATOR YOU WILL SEE BLACK AND RED WIRES CHECK YOU HAVE A CIRCUIT THROUGH THIS ITEM, IT IS A THRMAL FUSE, IF ITS OK THEN METER OUT THE TWO HEATERS, IF THEY ARE OK THEN YOU HAVE A POWER MODUE FAULT.
Posted on Aug 20, 2008
  • 813 Answers
U have to go with a good technesion
    Genius:
  • 2,035 Answers
You need to contact the repair mechanic and get it checked ,this could the problem with
  • The thermostat (also called the bi-metal switch)
  • Good luck....
      Brigadier General:
    • 6,966 Answers
    Based on your description and to recap:
    • fridge freezer will run until it gets down to temp then will stop running - indicates that compressor is good, thermal cutoff switch is good (thermostat);
    • continue to read 3 and -15 on display. after a while it begins to flash - indicates probable computer board error or its sensors;
    • turn the power off and back on it will read true temps of about 16 - this is simulating a reset that reverts unit back to factory default;
    • replaced the temperate sensors, main computer board, defrost sensors - no change therefore not the cause of the problem.
    A couple of things you can try:
    • evaporator on the fridge side may need thawing/cleaning;
    • replace the Evaporator Cover Assembly. Samsung has long replaced this original design/component (Jan 2007);
    • check for fan/blower action. They may be frozen, stuck or providing insufficient air flow.
    Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
    Good luck and kind regards. Thank you for using FixYa.
    • Louie  Role
      Louie Role Aug 20, 2008
      Hi again,
      Appreciate the postback/comment.
      A query pls, was the cover a tad heavy when it was removed?
      This page might shed additional insights/related information.
    • Refrigerators Master
    • 19,396 Answers
    On some fridge this can be normal if the gap between real temperature and displayed temperature is not too big.
    This happens because when you unplug the fridge it reset the computer and re-read the sensor value when you plug it back, displaying real temperature.
    Additionally some fridge/freezer have more than one temperature sensor, you should post make and model to get more information on the specific case.
    If you are not satisfied with the solution you can ask help from more experts.
    If you have more queries ask us by posting them here.
    If you are satisfied, please do not forget to accept or vote the solution, so that Fixya can reward expert.
    Many thanks
    Posted on Aug 19, 2008
    • Ginko
      Ginko Aug 20, 2008
      Did you also try a complete defrost, it is a basic operation, but must be done whenever there is a problem with the fridge.
    • Ginko
      Ginko Aug 20, 2008
      At this point, the only explanation is that one of the newly installed termic sensors is faulty or not properly installed.
      This can happen even with new parts.
      Defective part should be individuated, removed, tested and eventually replaced again.
      Guru:
    • 1,894 Answers
    The problem must have been solved by the replacement of board..
    i think you must consult the mechanic again for this
    Hi I have pressed the vacation button on my side by side refrigerator/freezer as we are going away for 8 weeks. The display has lit up but there is no difference in the way the fridge is operating - same...
    The settings will reset to a lower settting as the fridge/freezer will not be disturbed . So wait for the fridge to run and shut down and it will continue to run in this low mode to save power but to keep the food in prime condition. The fridge alone will not be shut down.
    Aug 31, 2011 | Samsung SRS20DTD Side by Side Refrigerator
    Kenmore refrigerator stop cooling but fan working
    The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
    The problem could be the electronic control if you have one or the mechanical linkages.
    If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
    check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
    You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
    Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
    Apr 06, 2010 | Kenmore 53642 / 53644 Side by Side...
    Side by side refrigerator the refrigerator does not get cold but freeze works fine
    Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
    Jan 01, 2010 | GE GSS25JFM Side by Side Refrigerator
    Fridge freezer side by side running constantly but not cooling.
    Make it a habit to defrost it every week. You see, when ice forms around the evaporator tubes (which runs around the walls of fridge and freezer), heat exchange reduces (that means heat is no longer absorbed from the things inside the refrigerator) and cooling stops. See whether freezer walls or fridge walls are damaged. Do not use knives or any other sharp tools to remove ice. Do not forcefully remove items that are difficult to take out from the freezer. Defrost and remove them.
    Aug 12, 2009 | Freezers
    Fridge condensation - freezer thawing
    OK now I'm wondering are theses numbers your getting 4 -9 the actual temps of the refrigerator and the freezer? and do they feel this cold and correct to you? I know the refrigerator side shouldn't be below 34 or so and definitely not below 32. If this is correct and the numbers are not settings but temps. (Now if you have a touch pad its electronic. If it has knobs it has a separate defrost and thermostat and are electro-mechanical)
    If electronic Your control board and possibly defrost control are out.
    It would more likely be the sensors going to the board(s) It will both sensors have the possibility of causing your problem. 1 will control the run of the compressor (and this one could and probably is connected to the inside coil) and 1 will control the air damper tween the refdg and freezer compartments, and may turn on the inside fan operation too.
    (this would be my first suspect if these are degrees numbers). Look at the thermostat control see if it is attached to the indoor coil (usually the tube leavign the indoor section. If its not attached its not sensing the coil temp and when goes into defrost wala its not senmsing temps like its designed to do. Look for a broken clip or possible a plastic wire tie that holds this sensor in place.
    Please get back to me with what you see - find on this look up.
    Mar 14, 2009 | Samsung Refrigerators
    Samsung fridge freezer model number srs615dp. The temperature displays -16 and 3 degrees. After approx 10 hours the display flashes. Turn off the power and on again and it displays 4 and 14 degrees and...
    Hi just wondering if you figured out the problem with your Samsung fridge yet.
    It is definately a problem with the defrost part of the fridge. After approximately 4 to 10 hours dependent on many different factors it enters into defrost mode to get rid of any excess ice in both the fridge and the freezer. During the defrost stage the compressor will not run. If any fault occurs during the defrost stage the fridge will not restart unless you turn it off and back on again which restes the pcb and takes it out of defrost mode and the timer starts again.
    Please let me know how you went with it.
    Jul 04, 2008 | Frigidaire FRT18B4A Top Freezer...
    Fridge is in lock mode
    Please press the white wine key and interior lamp button together for 3 seconds.
    Jan 09, 2008 | Refrigerators
    Hot point Fridge/ freezer
    All the cooling is in the freezer and the control in the fridge side only controls a damper to let in cold air as needed. To do what you want you have to replace the thermostat to a lower temp rated unit
    Nov 22, 2007 | Samsung RS2578BB Side by Side Refrigerator
    RS21 DCNS FRIDGE COOLING FAULT
    There is a fan behind the plastic. This distributes the cold air throughout the fridge. What happens is this fan stops turning due to freezing up. A temp solution is to unplug the samsung for 6-12 hours to allow the ice to melt from around the fan. This is a known design fault. It is easy to dismantle the plastic cover and defrost the frozen fan with a hair dryer, this way the fridge will only be off for about an hour
    Aug 14, 2007 | Samsung RS2630SH Side by Side Refrigerator
    Samsung RS2555SL humming noise
    don't know this model specifically, but have had loads of problems with these samsung fridge-freezers. the no water in drinks dispensor is probably due to the water bottle at the bottom of the fridge being frozen. this is endemic with samsung the noise you hear is ice hitting fan. samsung use two systems for fan. the one i think you have is separate fans for fridge and freezer and a separate evaperator for fridge and freezer. take of the back plate of the fridge and you will find the fan mounted in it. disconnect the plug and socket connection. you will probably find ice build up round the fan blade. melt off with hot water. the bar you had showing on the "8" is a fault code - the most common fault being the defrost termination sensor. unless you are experienced, this is not really a diy appliance
    Apr 02, 2007 | Samsung 26 Cu. Ft. Side-by-Side...
    Refrigerators Logo
    593 people viewed this question
    Top Refrigerators Experts
    Charles T Nevin
    Charles T Nevin
    John Tripp
    John Tripp
