Question about Tascam 2488 Portastudio Multitrack Recorder System
Vocal mic
Will the h input at the front of the machine used for guitar,can it be used for a vocal track to . thanks
    Novelist:
  • 189 Answers
You can plug a mic into the front H input on the 2488, but depending on the type of mic you may get a weak signal. The typical voice mic is low-Z (low impedence) and the instrument input (H) on the front of the 2488 is High-Z. A high-Z input is expecting the relatively higher voltage put out by a high-Z mic (or passive guitar pickup). On the other hand there are high-Z mics out there and most computer mics are high-Z. These produce the voltage that a high-Z input is expecting.
If however your mic is low-Z you will get a weak signal on the high-Z (front H) input on the 2488. You should in this case connect an impedance matching adapter between the mic and the input. It steps up the voltage of the mic, giving it a stronger signal.
To tell what impedence (Z) you mic is use the following to match the rated ohms on your mic with the impedence:
low-Z = 150-300 ohms
medium-Z = 600-2000 ohms
high-Z = 10,000 ohms or more
If you already have a high-Z mic you can plug it into the front H input directly. For a high-Z mic plugging it into any of the other low Z inputs on the back will produce a distorted signal.
Hope this helps.
bd.
Posted on Aug 21, 2008
SOURCE:
Hi i want to record guitar and vocals using my mz n510 what do i need
Just plug a mic into the mic input or the mixer into the line input. Watch your levels!
User manual http://www.minidisc.org/part_Sony_MZ-N510.html
May 01, 2012 | Sony Net MD Walkman MZ-N510 MiniDisc...
I have a standard DP 02 (non cf) and I want to add vocal tracks to a previously recorded song (tracks 1 and 2) and I don't get any sound from my mic. The mic/line/guitar switch is set to mic/line but the...
you have to make sure the song tracks(1 &2 ) are not armed. then you can assign your vocal to any of the other tracks. after you do this , make sure you arm the track. you should be able to hear your mike.
Apr 09, 2011 | Tascam Dp-02cf Digital 8-track Recorder
Using a Tascam US 122 with Cubase SX, when recording vocals red light (clipping) on the Tascam and in the Cubase mixer, I need to know how to set levels on Tascam, so there will be no clipping on vocal...
Make sure the switch is set to "mic/line" and not "guitar"
Your input level will be set by the "input L" or "input R" knob, depending on which side you are using. Start with them all the way down and then sing into the mic, turning them up until you get a signal about halfway up the bar in Cubase. That should give you plenty of headroom for clean vocals.
It may be difficult to get a good sound if you have one of those cheap mics that has a "1/4" jack instead of a 3-pin XLR jack. You might want to go to your local music/pro audio store and invest in a "condenser" microphone, which is good for vocals in the studio.
Feb 26, 2011 | Tascam US122 Audio/MIDI Interface with...
I was just wondering if its best to record seperate tracks at different times of if its ok to mic my guitar and mic the vocals using two inputs but recording at the same time?
Whichever works best for you is best. You can always lay down a scratch track for each like this and then lay down another track to replace whatever you didn't like using the scratch track as a guide. Erase the scratch tracks that you don't need before you mix down. I hope this helps.
Nov 26, 2009 | Fostex Mr 8hd CD 8 Track Recorder with CDr
I need to output guitar and vocal separately. No matter how I hook it up guitar comes thru the vocal channel
Hi there. Use the "pan" pots to assign the guitar to left channel and all other pans to right channel. Also, turn all effects off or down all the way. (Effects return all the way down.
Thanks
Paul
May 03, 2009 | Digi-Tech Digitech Vocalist Live 4...
Cannot record both mic and electric guitar in daw
Disagree with previous post. The GTrack is designed to record vocals and a mono insrtument at the same time. That's its main selling point. It should also allow monitoring of both the vocals and guitar alongside the playback from the computer. In your computer's Control Panel, go to sound preferences, select the usb microphone and click on advanced tab. It is likely yours is set up to record 1 channel at CD quality - this is how many ship for some reason. Set it to 2 Channels CD quality.
In Sonar, set your track input as USB Left for the vocals, and USB Right for your guitar.
Mar 31, 2009 | Samson G-TRACK USB RECORDING MICROPHONE...
Tascam DP-02cf
You've got two inputs on the DP-02 so you can record two sources at once.
Depending on how you want the electric guitar recorded (mic the amp, or direct line in) you can in the first case plug your guitar mic into one of the mic inputs on DP02 and plug your vocal mic into the other mic input. You also have the option of plugging the guitar directly into the DP02 (using the hi-z input - I believe it is labelled 'guitar' or something on the DP02. I any event I believe it's the one on the left). This way you only need one mic for use recording the vocal part.
To avoid any 'bleed' between channels you can use the headphones while recording this way and you'll avoid having the unamplified guitar sound coming through over the vocal mic.
Once you have the mics or guitar and mic plugged into two inputs, you need to assign the inputs to a channel (track) to record on. You do this by pressing the select button for the input and then pressing the select button for the track where you want to record the input. Do this for both inputs so that they are recording on different tracks. Then arm the tracks for recording by pressing the record button for each track and the lighted buttons will flash above each armed track. Then just press play and record and you'll be recording. You can go back and redo it as many times as you like and record over what is there, or preserve a take and assign a new track (or tracks) for another take. You've got 8 to play with.
Hope this helps.
bd.
Sep 01, 2008 | Tascam 2488 Portastudio Multitrack...
Samson
try using the instrument input lets see if its going to change something.
Jun 04, 2008 | Samson G-TRACK USB RECORDING MICROPHONE...
Using the effects on the 2488 mk 11 for vocals
Use a single effect vice a multi effect and assign it to the channel vice the input and that should get you going. I'm sure you could just set the effect to the input and not the channel but this works for me. If your tracking your instruments/tracks to different channels, and you should be, then assigining the effect to the channel wont hurt you.
Apr 05, 2008 | Tascam 2488 Portastudio Multitrack...
Can not record vocal and guitar at the same time
The monitoring switch should not affect the recording at all. Maybe you have a defective mic?
Does it record from the line input if you set it to Line In mode?
Mar 27, 2008 | Samson G-TRACK USB RECORDING MICROPHONE...
Tascam 2488 Portastudio Multitrack Recorder System Logo
153 people viewed this question
Top Tascam Audio Players & Recorders Experts
Michial Gueffroy
 Grubhead
Grubhead
Ekse
Are you a Tascam Audio Player and Recorder Expert? Answer questions, earn points and help others
