Question about Zhone (6218-I2-200) Router
Zohne 6218-12-302 I want to open port on my Router ZOHNE 6218-12-302 ... Please help me ... Error! Port 20309 does not appear to be open... My Down load speed is 2~4 k/s !!! Thats mean there is fire wall on my port! wat can i do Plz Help me & thank you... Elshnaf@hotmail.com Fagerelislam@yahoo.com
    Scholar:
  • 51 Answers
Follow the Guide Found HERE.
It is for a different version than your router, but the steps and options are basically identical, so No Worries!
It shows you EVERYTHING YOU NEED to do exactly, in a Few, Very simple steps.
*** It is CUSTOM! Just choose the application that you're opening the port on. (There's a List in the Link Above.)
And then follow the steps it provides.
I Hope This Helps.
Posted on Jan 30, 2009
I have a netgear wpn824 v2. I have a PS3 60g I have it hard wire to the Netgear, it works ok untill i need to download updates. the error messages pop up. I am with virgin and when i connect direct I have...
A. Determining the IP Address and MAC Address of a Computer:
Note: Please use the computer for which the Ports are to be opened:
For Windows 2000/XP users:
1. Please click on Start and select Run.
2. Type in cmd and click on OK.
3. In the Command Prompt, please type ipconfig/all then press Enter or Return key.
4. Please make sure that the Ethernet adapter has an IP Address that is the same range as the router (e.g. 192.168.1.2 for the computer and 192.168.1.1 for the router).
5. Please note down the IP address and Physical address.
B. Reserving an IP Address:
1. Please open any web browser like Internet Explorer or Netscape Navigator.
2. Connect to the router by typing http://routerlogin.com/basicsetting.htm or http://192.168.1.1 in the address field and click Enter or Return key.
3. A window will prompt for a user name and password. The default username is "admin" and the default password is "password".
Note: If it does not take password as the password, you might have changed it when you have run the NETGEAR Setup CD so please try other passwords. If you cannot remember the password, you need to reset the router and run the Setup CD to reconfigure it.
4. When the setup page opens, click on LAN IP Setup under Advanced tab.
5. Click on Add under Address Reservation.
6. Under Address Reservation window, please select the radio button of the computer you wish to add from the Address Reservation Table.
7. If the computer you want is not on the list, please click on the Refresh button to update the table.
8. If the computer is still not on the Address Reservation Table, please type in the IP Address, MAC Address (Physical Address), and Device Name of the computer you wish to add.
9. Click the Add button when done.
C. Opening Pre-Defined Ports for Internet Services:
1. Click on the option with the name Port Forwarding/Port Triggering under the Advanced menu.
2. Please select the service type Port Forwarding. The router pre-defined services are listed there.
3. From the Service Name pull down list, select the service that needs to be hosted.
4. Enter the IP address of the computer in the Server IP Address box.
5. Click the Add or Apply button.
6. Repeat all steps to open more ports.
Note: If the name of the Internet service does not appear in the drop down list, you may manually open the ports for that Internet service. Please follow the steps below:
D. Opening Ports for Games, Applications or Custom Ports:
1. Click on Add Custom Service button.
2. Type the service name in the Service Name box and the lower range numbers in the Starting Port box.
3. If the application uses only a single port; type in the same port number in the Ending Port box.
4. If the application uses a range of ports; type in the higher range numbers in the Ending Port box.
5. Type the IP address of the computer in the Server IP Address box. Click Apply button.
6. It will then refresh to the Port Forwarding page, and will show the list of all ports opened in tabulation.
7. Repeat all steps to add more ports for more services.
E. To Edit or Delete a Service Entry:
1. Click on the Radio Button that needs to be Edited /Deleted, under the Port Forwarding page.
2. Modify the information from the Service Name, Starting Port, Ending Port, and the Server IP Address, and then click the Apply button.
Jun 29, 2009 | NetGear RangeMax WPN824 Wireless Router...
Tip
Solution for War Craft 3 behind Linksys routers.........
As the application requires certain ports to be opened on the router,try to follow the steps below to configure the router. Since you are connecting behind the router, you are going behind a NAT firewall.Therefore, you would need to allow ports for the remote access application to go through the firewall. You would need to know what port number application uses. You can check with the program manufacturer for the information, or see the Help menu.
For routers with old firmware versions (without the Cisco web interface):
1.Open Internet Explorer.
2.After "Internet Explorer" opens, please typehttp://192.168.1.1 into the "Address Bar" and click GO.
3.The "Enter Network Password" window will appear. Skip username and type admin (admin is the default password) as the password,and click OK.
4.You will need to click on the Advanced tab to the very right. Once the "Filters" area appears, please click on the Forwarding tab.
5.Once the "Forwarding" area appears, click the Port Triggering button. Once you've done this, a new window will appear.Enter the ports needed to be opened > Click Apply
For later firmware (that has the Cisco web interface)
4.Click on "Applications and Gaming" then click on the "Port Triggering" Sub tab. Enter the ports needed to be opened >Click Save Settings.
Example:
Customized Trigger Port Range Incoming Port Range
Application From ~ To From ~To
WARCRAFT 6112-6112 6112-6112
WARCRAFT 6113-6119 6113-6119
Hope this help everyone that has problem with the game.
on Jan 05, 2010 | Linksys Wireless-G Broadband Router
Tip
How to Upgrade Firmware of Linksys routers........
Example:
on Jan 05, 2010 | Linksys Wireless-G WRT54G Router
Im laggin on psu a game only 1 connection it only du it once a few days n it lasts 4eva please help its to do with modem or router
You need to do port forwarding. Call PS3 tech support to get the port numbers to opened to your Netgear Router. And follow this procedure.
Port Forwarding
A. Determining the IP Address and MAC Address of your PS3:
2. Connect to the router by typing or http://192.168.1.1 or http://192.168.0.1 in the address field and click Enter or Return key.
Apr 26, 2009 | NetGear MR814 Wireless Router
Cant dl anything from winmx!just started using a router
Port Forwarding
Apr 09, 2009 | NetGear WGR614 Wireless Router
Problem connecting with mates on fifa 09 on ps3.
here is the link for your port forwarding configuration:
http://kb.netgear.com/app/answers/detail/a_id/1166
here is the link for HOW IS PORT FORWARDING CONFIGURE:
http://kbserver.netgear.com/kb_web_files/n101145.asp
Instructions for RP614, MR814, WGR101, WGR614, WGT624, WGT634U, WGU624, WGM124, or WPN824 These routers do port forwarding by assigning port numbers to a "service" that is associated with the application you want to run.
To Let an Application Use Port Forwarding
  1. Type the router's address in an Internet browser's address bar. (By default the router's address is 192.168.0.1). The Setup Wizard appears.
  2. Enter the router's username and password.
  3. Under Advanced, click Port Forwarding on the left menu bar.
  4. A Port Forwarding Screen (Varies Slightly by Router)
  5. From the Service & Game (or Service Name) pull down, select the service that you will host. The services the router knows about are listed here. If the service does not appear in the drop down, add a service as described in the next section, then return to this step.
  6. Enter the IP address of your local server in the Server IP Address box.
  7. Click Add.
  8. Click Logout to exit from router settings.
To Add a Service for These Routers
To define a service not in the Service Name list, determine what port numbers are used by the service.
  1. Click Add Custom Service.
  2. Enter the first port number in an unused Start Port box.
  3. If only one port number is to be forwarded, enter the same number in End Port. To specify a range of ports, enter the last port to be forwarded in the End Port box.
  4. Enter any name you choose for the service.
  5. Click Apply.
Apr 03, 2009 | NetGear WGR614 54Mbps Wireless Router...
Cant enable port magic on router need usr name & password
By default;
Username: admin
password: password
Here are other steps you may want to consider in opening some ports on your router.
Port Forwarding
Mar 17, 2009 | NetGear WGT624 Wireless Router
Skype video call fails after short time
Feb 21, 2009 | NetGear DG834G Router
Problem with opening ports
I had the same problem, where I thought I needed to open the ports on my Wireless-G (for bittorrent downloads). Turns out, I had to open the ports on my DSL modem instead. After that, the port forwarding worked properly.
Hope this helps - please remember to rate :)
Sep 27, 2008 | Linksys Wireless-G Broadband Router
How to install netgear fvs318 vpn firewall?
Dec 15, 2007 | NetGear FVS318 Cable/DSL ProSafe VPN...
Zhone (6218-I2-200) Router Logo
980 people viewed this question
Top Zhone Computers & Internet Experts
Prashant M
Prashant M
Mike
Are you a Zhone Computer and Internet Expert? Answer questions, earn points and help others
